    Texture mapping question
    5 Posts 3 Posters 680 Views 3 Watching
      karad
      Hi guys!
      I have a complicate question for anyone that can contribute something. I am using sketchup for this project. I must create a curved path as seen on attached file but I am not sure there is a way to bend a texture or material along the curved path. Is there another way I can recreate wood planks? Of course there is postproduction but I would like to broaden my knowledge of modeling. Thanks you in advance!
      curved path
      • ntxdaveN Offline
        ntxdave
        Have you looked at Fredo's ThruPaint which is part of his Fredo Tools?
        Not exactly sure it will do what you want but you should look at it to see.
        Press F1...thank me later
        • HornOxxH Offline
          HornOxx
          Dave is absolutely right - ThruPaint is the right tool.
          I'd only like to add the information, that all of Fredo6´s plugins require the additional plugin "LibFredo6" to run
          http://sketchucation.com/pluginstore?pln=LibFredo6
          never trust a skinny cook
            karad
            Thanks for the quick response! I will check it out and maybe come back for a result in case someone else might have the same problem!
              karad
              Thank you very much for the quick response! I will give it a try and maybe come back with some results!
