    3D Truss Models
    1.5k Posts 32 Posters 1.8m Views 31 Watching
    • jujuJ
      juju
      Congratulations on the new job! Uprooting/moving is always uncomfortable, so wishing you as little discomfort as possible.
      Looking forward to the future development of both the truss and slab/foundation plugins.
      • medeekM
        medeek
        I haven't had any time this week or even this weekend to dive back into it yet but the icons for the Medeek Tools Menu (trim and extend for now) will look like this:
        http://design.medeek.com/resources/images/truss_su_menu_with_tools.jpg
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          The trim function is a work in progress. I had some help with a developer on the other board but it has a ways to go yet.
          design.medeek.com
          • jujuJ
            juju
            How's the new job going? Have you settled in already?
            • medeekM
              medeek
              Starting to get my bearings with the new job. Still haven't found a place to live yet, Airbnb has been interesting.
              design.medeek.com
              • medeekM
                medeek
                Version 1.6.8 - 08.20.2016
                • Added the Medeek Tools toolbar with Trim and Extend icons.
                • Added the trim function for (solid) groups and components.
                Only the trim function currently works with this latest release. I'm also not completely satisfied with the trim function as it tends to break down when dealing with components that have tranformed instances. I am still working on this one. The main reason I've released it is for a few of my SketchUp mentors to have the ability to test the trim function and hopefully help me work the bugs out of it.
                design.medeek.com
                • medeekM
                  medeek
                  I've created a SketchUp model tonight using the truss and foundation plugins to further examine a structural design I am working on.
                  http://design.medeek.com/resources/images/truss_su152_800.jpg
                  View and download model here:
                  3D Warehouse
                  (3dwarehouse.sketchup.com)
                  I think I will probably add a TJI roof that allows one to use two glulam beams with cantilevered rafters as shown in this model, this configuration seems to be fairly popular.
                  design.medeek.com
                  • facerF
                    facer
                    Medeek,
                    What function do the Bracket - Fixings shown in attached jpeg serve?
                    I assume they are Simpson Strong-Tie HDU2-SDS2.5 (as noted in your Skp model - entity info)
                    but why so far from the bottom plate - bolts to be added later or in situ?
                    Good work, keep them coming πŸ˜„
                    Brackets purpose?
                    • medeekM
                      medeek
                      The HDU5 at the corner is primarily for the lower shearwall, the HDU4 about 24" inboard is for the the portal frame load path in the wall above, notice the straps between floors that complete the load path. I have not shown the SB5/8X24 anchor bolts that will be placed in the forms before the concrete is poured. I showed the holdowns about 1-1/2" above the sill plate, actual height will be dictated by the extension of the anchor bolts above the sill plate and is not really critical. The holdowns could just as well sit directly on the bottom plate.
                      What I've shown in this window wall is a site built wood moment frame, what I have not shown is the required nailing patterns. I also forgot to add in the pad footings for the PSL posts, and possibly a few more A35 clips and straps, but overall it is mostly complete. I am still working on the lateral analysis of the total structure which may change the sizing of the straps and holdowns slightly. This is the typical work I do during my day job but its fun to throw together a 3D model to really look at how it all goes together.
                      design.medeek.com
                      • FrederikF
                        Frederik
                        After having updated the plugin, I now get the following error, when I open SU... 😞
                        Error Loading File C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial/medeek_load.rb
                        Error: #<NameError: undefined local variable or method pluginserial' for Medeek_Engineering_Inc_Extensions::MedeekTrussPluginModuleLoader:Module> C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial/medeek_load.rb:205:in module:MedeekTrussPluginModuleLoader'
                        C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial/medeek_load.rb:22:in <module:Medeek_Engineering_Inc_Extensions>' C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial/medeek_load.rb:20:in <top (required)>'
                        C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
                        C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial.rb:39:in register_extension' C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial.rb:39:in module:MedeekTrussPluginLoader'
                        C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial.rb:23:in <module:Medeek_Engineering_Inc_Extensions>' C:/Users/kim/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/medeek_truss_ext_trial.rb:22:in <top (required)>'
                        Cheers
                        Kim Frederik
                        • medeekM
                          medeek
                          I forgot to remove a "#" sign when I removed some debugging code in the trial version. Re-download and install again (Version 1.6.8). Sorry for breaking it.
                          design.medeek.com
                          • FrederikF
                            Frederik
                            No problem...
                            Glad you've solved the issue... πŸ‘
                            Cheers
                            Kim Frederik
                            • FrederikF
                              Frederik
                              Hhhmmm... Although I've downloaded ver 1.6.8, installed it, re-started SU, I still have this issue... ❓
                              Cheers
                              Kim Frederik
                              • medeekM
                                medeek
                                Manually remove the plugin folder and files and then do a clean install, let me know if that doesn't fix it.
                                design.medeek.com
                                • FrederikF
                                  Frederik
                                  I've removed the folder "medeek_truss_ext_trial" from
                                  C:\Users\kim\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                                  As well as the file "medeek_truss_ext_trial.rb"
                                  Then I opened SU and didn't get any errors...
                                  I opened the Extension Store and installed the plugin again, but after a re-start, I get the exact same issue...
                                  It does say that it's ver. 1.6.8, but are you sure that it's the correct file in the Extension store...??
                                  Cheers
                                  Kim Frederik
                                  • medeekM
                                    medeek
                                    Your right I may have forgotten to upload the correct version to the pluginstore, ack. Try downloading the plugin again reinstall, so sorry for the mess up.
                                    design.medeek.com
                                    • FrederikF
                                      Frederik
                                      It's working now... πŸ‘
                                      Cheers
                                      Kim Frederik
                                      • medeekM
                                        medeek
                                        Again I apologize for the delay in development, first it was my new job and then I re-injured my rotator cuff (old injury from 10 years ago) which has made sitting at my desk for prolonged periods very difficult.
                                        This morning I sat down and thought about hip sets since I've had some recent requests for the their addition to the plugin. What I show below is a fairly standard step down hip set with, with the midwest variant shown at one corner and the standard variant at the other corner.
                                        http://design.medeek.com/resources/images/truss_su153_800.jpg
                                        View model here:
                                        3D Warehouse
                                        Note, I have not shown all of the internal webs for clarity, those will be generated automatically and not be user definable.
                                        Please review carefully and let me know if anything looks amiss. I will also be adding in other variants of the hip set but I figured I would start with these two.
                                        A stepdown hip set provides a girder truss, with a hip jack truss running from the corners up the ridge until they meet the hip girder.
                                        The Midwest hip set also provides a girder truss, with hip trusses that step up to the peak.
                                        However in a Midwest hip set, you run a rafter (dropped) up from the corner of the front wall to the hip girder.
                                        All the bottom chords of the end jacks run to the hip girder, allowing for better attachment of the drywall on the ceiling.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          This is the Northeast Hip Set variant:
                                          http://design.medeek.com/resources/images/truss_su154_800.jpg
                                          View model here:
                                          3D Warehouse
                                          In a northeast hip set, you will find a short jack truss starting at the corner and running up the hip ridge. This hip jack stops at a sub-girder. All end jack bottom chords run to the hip girder, allowing for better attachment of the drywall on the ceiling. Hip cats must be field cut and installed between the hip trusses. Works well with dual-pitched hip systems.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            This is the California Hip Set:
                                            http://design.medeek.com/resources/images/truss_su155_800.jpg
                                            View model here:
                                            3D Warehouse
                                            The problem I am having with this variant is the conflict between the 2x6 hip rafter and the top chords of the step down hip trusses.
                                            design.medeek.com
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 76
                                            • 77
                                            • 25 / 77
