    Help Needed to Reduce File Size
    12 Posts 3 Posters 2.3k Views 3 Watching
      The cushion can be mirrored along Y as the mesh is symmetrical. That will reduce the file size to <2mb
        measuredmove
        Thanks for the reply, Rich
        The mirroring part happens in the Animate program, prior to importing into Simlab as a 3DS file so when it is exported as a skp it is fully formed as a 3D object. So I'm not quite sure where you suggest the mirroring takes place. Leave it as a one-sided 3d form to be mirrored once it is opened in SU?
        I tried that and it did reduce it by about a third which is pretty good-thanks! Probably the best I can hope for when using a 3ds import.
        Thanks again.
        My 3D Catalogue
        https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
        SU8/Brighter3D/Gimp/SimLab Composer
          Pillow-Valencia%5BMulti%5D.skp
          Mirror the geometry to the back.
          To reduce the poly count export it to .dae and import to Blender and add a Decimate modifier with a .15 ratio then apply it.
          Pillow-Valencia-lo.skp
            measuredmove
            I don't have Blender yet but will download and give it a try.
            I have about 1200 of these created so I know what I'll be doing in my spare time for the forseeable....no batch process.
            My 3D Catalogue
            • jujuJ
              juju
              A job for Mootools 3Dbrowser with Polygon Cruncher?
                Yeah, Poly Cruncher can get it down to 100 Faces and 788kb in size.
                At this point the alpha in the png is contributing to 70% of the file weight. If you save the texture as jpeg you can save a further 500kb...
                Pillow-Valencia-100-jpeg.skp
                • jujuJ
                  juju
                  impressive, roughly 3.3MB to 203kB, that's some optimization!
                    measuredmove
                    Excellent! I think that may be what I'm looking for
                    Cheers. eveeryone
                    My 3D Catalogue
                      measuredmove
                      Just to update this info for anyone else trying to reduce the file size of a 3ds import into Sketchup.
                      Downloaded the trial version of Mootools 3ds Browser with Polygon Cruncher.
                      Batch processed a few .skp files but wasn’t able to open as they save in V16 and I’m still using V8.
                      (To save to other versions of SU may be an option in a later version of Polygon Cruncher but not possible right now)
                      Redid a batch process at 75% optimisation using the original 3ds files.
                      Opened in Simlab Composer, mapped the corresponding material file (using jpg not png) and was able to save/open in SU8.
                      The file size went from 3,230KB down to 707KB
                      I’m really happy with these results.
                      Pillow-Dupion[Blue-png].skp
                      Pillow-Dupion[Blue-Moo75].skp
                      My 3D Catalogue
                        As far as I am aware it saves as SketchUp v6. Not v2016.
                        At least my licensed version does.
                          measuredmove
                          I did contact Mootools Techsupport and they responded:
                          "No there is no way to export using V8 version. This is an idea to add to an upcoming version"
                          But I can work with my convoluted path for now to get these results. It's been a hit and miss search for quite a while so this is progress-for sure!
                          My 3D Catalogue
