    MSPhysics 1.0.3 (16 October 2017)
    928 Posts 171 Posters 1.3m Views 172 Watching
      Anton_S
      @faust07 said:
      Hi Anton, do you see an opportunity to revise your MIDI-Piano for version 0.9.0?
      Hi faust. I updated the MIDI piano a few days ago. It should work fine now 😄
      • F Offline
        faust07
        Hi Anton. Thank you very much! I've found it already. I enjoy the magic sound. PituPhysics updated his MSPhysics models too. So there is much stuff to learn. 👍
        On my side, on Win7 and Win8.1 with IE11 MSPhysics works like a charm (except to record Replay...). 😎
        • Bryan KB Offline
          All paths and files are verified in the right location. Everything seems to work except the UI menu tabs.
            Anton_S
            Bryan, if everything worked fine, your UI should have looked like this:
            The screenshot that you posted above resembles a UI with missing CSS/JS files, which make it look/work improperly. Can you once again ensure that all of these files exist in your SU2015 plugins folder because at the moment I have no idea what could be the other cause:
            • MSPhysics/css/chosen.css
            • MSPhysics/css/tabs.css
            • MSPhysics/css/dialog.css
            • MSPhysics/css/expander.css
            • MSPhysics/js/jquery.js
            • MSPhysics/js/chosen.js
            • MSPhysics/js/ace/ace.js
            • MSPhysics/js/ace/ext-statusbar.js
            • MSPhysics/js/dialog.js
            • MSPhysics/js/expander.js
            • Bryan KB Offline
              The only difference I see is that the file path I have includes "Roaming"
              I really appreciate you taking the time to help with this. I'm sure we'll figure it out. Thanks again.
                Anton_S
                Announcing 0.9.1.
                Refer to CHANGELOG for info: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                Faust, the save Replay data to model should be working now.
                Bryan K, I think the dialog displayed improperly because HTML files used HTML5 DOCTYPE deceleration. Try this version as it might be fixed here.
                • Bryan KB Offline
                  Thanks Anton. Will do.
                  • F Offline
                    faust07
                    Thanks for the improvements! But still have some problems:
                    • Full Screen Mode is not properly stored in MSP UI (still active but no check mark in the box).
                    • If one will store a large simulation in Replay there should be an information about the processing in the status bar. It could be that minutes nothing happens and the user doesn't know what's going on.
                    • there are problems to save and to open model files with large simulations stored (- No temporary space available, - partial the access to the directory in which the model is to be saved is denied by the system, - bug splats, - SketchUp crashes etc.)
                      Anton_S
                      Thanks for feedback, faust. I'll see what I can do about it. I was thinking about saving replay data into a separate file (that would be placed right where the model is), but hesitated because I was worried that two files would make it inconvenient. However, right now I'm thinking that saving Replay data into a separate file won't be a bad idea. You have any thoughts about it?
                      • F Offline
                        faust07
                        Yes that is a good idea. These data should possibly be stored in a subdirectory with a copy of the model to ensure that the model geometry and the replay data match later. A warning that by changing the Physics-relevant geometry no replay is possible, would be good.
                          Anton_S
                          Faust, I'm thinking of making it simpler. The file would be stored at the same location of the model, named [model_name].mspr. It will load whenever the associated model is opened, and be written to whenever the associated model is closed (if replay data is changed). If for instance the geometry doesn't match or the data becomes corrupt, it will display an error message, and then erase the associated mspr file. I want to avoid creating subdirectories and saving copies of the model because it might make it a little complicated. If the user wants to make changes to the model, they could first make a copy of the model and the associated mspr file, then proceed making changes.
                            Anton_S
                            Okay faust, I updated it. Upgrade to 0.9.2 and replay data would be saved to a separate file.
                              junaramaro
                              my sketchup 2016 crashes when starting the simulation... don't know if i'm just wrong... without putting any parameters...i just click the play button... then boom, a bug splat T^T....
                              • F Offline
                                faust07
                                Anton, regarding separate replay data file:
                                after long tests and reducing my ice-mountain-model to the minimum the following results:
                                Small models with moderate simulations work very well (up to 15 - 20 Mb mspreplay file size).
                                Large models with much physics simulated and emitted objects (mspreplay files larger 20 Mb) work until you save and exit the model.
                                Opening the model again, crashes or stops during loading the replay data. The replay file is then lost.
                                The completely reduced file example (in my post with questions and examples) after saving Replay data, exit and reopen the model Replay runs but nothing happens.
                                In the test file you can see an other problem too - the viewport problem with emitted objects if you try it often enough. Running the simulation the viewport goes, comes back, running replay the viewport stays away. (think that some emitted object fly into space with high speed before end of its lifetime ...)
                                Thanks for your efforts!
                                  Anton_S
                                  Junaramaro, more details would be preferred, like OS version, SU version, and of course the model that crashed.
                                  Faust, thanks for testing. I'll see what I can do there.
                                    micceo
                                    Hi! Curious about this plugin but can't get it started.
                                    I'm on SketchUp 2016, 16.1.1449 64 bit, Windows 10 Version 1511 (10586. 494)
                                    Tried the .exe-setup and the .rbz, but it ends with the same error.
                                    Error Loading File C;/Users/Användaren/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                                    Error; #<Exception; An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons;
                                    • Encoding;;CompatibilityError; incompatible character encodings; Windows-1252 and UTF-8
                                    C;/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb;197;in require' C;/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb;197;in load'
                                    C;/Users/Användaren/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in register_extension' C;/Users/Användaren/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;90;in <module;MSPhysics>'
                                    C;/Users/Användaren/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb;72;in `<top (required)>'
                                    Plugin dir
                                     Directory of C;\Users\Användaren\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                                    2016-07-31  14;17    <DIR>          .
                                    2016-07-31  14;17    <DIR>          ..
                                    2016-07-31  14;13    <DIR>          ams_Lib
                                    2016-07-31  14;18             1 577 ams_Lib.rb
                                    2016-07-16  20;17    <DIR>          as_flatten
                                    2016-07-16  20;17             3 070 as_flatten.rb
                                    2016-07-31  14;13    <DIR>          MSPhysics
                                    2016-07-31  14;17             3 498 MSPhysics.rb
                                    2016-07-26  17;59             3 498 MSPhysics.rbx
                                    2016-07-31  14;05    <DIR>          SketchUcation
                                    2016-07-31  14;05             5 508 SketchUcation.rb
                                    2016-05-21  00;35    <DIR>          su_advancedcameratools
                                    2016-02-24  12;28             1 715 su_advancedcameratools.rb
                                    2016-05-21  00;35    <DIR>          su_dynamiccomponents
                                    2016-02-24  12;28             1 780 su_dynamiccomponents.rb
                                    2016-05-21  00;35    <DIR>          su_sandbox
                                    2016-02-24  12;28             1 706 su_sandbox.rb
                                    2016-05-21  00;35    <DIR>          su_trimble_connect
                                    2016-02-24  12;28             1 339 su_trimble_connect.rb
                                    2016-05-21  00;35    <DIR>          su_webtextures
                                    2016-02-24  12;28             1 299 su_webtextures.rb
                                     Directory of C;\Users\Användaren\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MSPhysics
                                    2016-07-31  14;13    <DIR>          .
                                    2016-07-31  14;13    <DIR>          ..
                                    2016-07-31  14;17            53 883 body.rb
                                    2016-07-31  14;17            16 487 body_context.rb
                                    2016-07-31  14;17             5 978 CHANGELOG.md
                                    2016-07-31  14;17            24 128 collision.rb
                                    2016-07-31  14;17             8 561 common_context.rb
                                    2016-07-31  14;17             1 269 contact.rb
                                    2016-07-31  14;17               230 controller_context.rb
                                    2016-07-31  14;17             9 154 control_panel.rb
                                    2016-07-31  14;13    <DIR>          css
                                    2016-07-31  14;17           100 030 dialog.rb
                                    2016-07-31  14;17             1 174 djoint_angular_gear.rb
                                    2016-07-31  14;17             1 166 djoint_linear_gear.rb
                                    2016-07-31  14;17             1 206 djoint_rack_and_pinion.rb
                                    2016-07-31  14;17             6 759 double_joint.rb
                                    2016-07-31  14;17             2 682 Examples.md
                                    2016-07-31  14;13    <DIR>          external
                                    2016-07-31  14;17             1 992 FAQ.md
                                    2016-07-31  14;17               613 hit.rb
                                    2016-07-31  14;13    <DIR>          html
                                    2016-07-31  14;13    <DIR>          images
                                    2016-07-31  14;17             6 904 joint.rb
                                    2016-07-31  14;17             5 022 joint_ball_and_socket.rb
                                    2016-07-31  14;17            48 285 joint_connection_tool.rb
                                    2016-07-31  14;17             5 729 joint_corkscrew.rb
                                    2016-07-31  14;17            10 167 joint_curvy_piston.rb
                                    2016-07-31  14;17             7 951 joint_curvy_slider.rb
                                    2016-07-31  14;17               677 joint_fixed.rb
                                    2016-07-31  14;17             7 489 joint_hinge.rb
                                    2016-07-31  14;17             4 307 joint_motor.rb
                                    2016-07-31  14;17             5 645 joint_piston.rb
                                    2016-07-31  14;17             5 645 joint_servo.rb
                                    2016-07-31  14;17             3 513 joint_slider.rb
                                    2016-07-31  14;17             5 683 joint_spring.rb
                                    2016-07-31  14;17             7 322 joint_tool.rb
                                    2016-07-31  14;17             5 900 joint_universal.rb
                                    2016-07-31  14;17             2 819 joint_up_vector.rb
                                    2016-07-31  14;13    <DIR>          js
                                    2016-07-31  14;17             1 107 LICENCE.txt
                                    2016-07-31  14;17             1 649 LICENSE.FLAC.txt
                                    2016-07-31  14;17            25 892 LICENSE.mikmod.txt
                                    2016-07-31  14;17                59 LICENSE.modplug.txt
                                    2016-07-31  14;17               950 LICENSE.NewtonDynamics.txt
                                    2016-07-31  14;17             1 625 LICENSE.ogg-vorbis.txt
                                    2016-07-31  14;17            25 873 LICENSE.smpeg.txt
                                    2016-07-31  14;17            49 927 main.rb
                                    2016-07-31  14;17             3 945 material.rb
                                    2016-07-31  14;17             1 424 materials.rb
                                    2016-07-31  14;13    <DIR>          models
                                    2016-07-31  14;17             4 881 MSPhysics.hash
                                    2016-07-31  14;13    <DIR>          osx32
                                    2016-07-31  14;13    <DIR>          osx64
                                    2016-07-31  14;17            15 179 Overview.md
                                    2016-07-31  14;17               428 README-SDL.txt
                                    2016-07-31  14;17             1 019 README-SDL_mixer.txt
                                    2016-07-31  14;17             2 948 README.md
                                    2016-07-31  14;17           120 465 replay.rb
                                    2016-07-31  14;17            10 556 scene_data.rb
                                    2016-07-31  14;17               753 script_exception.rb
                                    2016-07-31  14;17            12 618 settings.rb
                                    2016-07-31  14;17           135 307 simulation.rb
                                    2016-07-31  14;17             1 011 TODO.md
                                    2016-07-31  14;13    <DIR>          win32
                                    2016-07-31  14;13    <DIR>          win64
                                    2016-07-31  14;17            14 115 world.rb
                                      You have a non-ASCII character in your Windows user-name [Användaren]
                                      This is a well known and long running problem with Ruby.
                                      Although the newer Ruby with v2016 is more forgiving, there are still some issues...
                                      It's recommended you always avoid accents in your Windows user-name...
                                      Can you try with an alternative user-name ?
                                      The extension's author might be able to "force encoding" to UTF-8 for any strings it uses, like the user-path name etc - when in >=v2015...
                                      But that's his fix for the future...
                                        micceo
                                        I had "ä" as a suspected but didn't try another account.
                                        Searched the forums here, but no hit on UTF-8 or Windows-1252.
                                        Thank you for the swift response. I'll try out with another user account.
                                          Ralphxyz
                                          micceo, I had this problem! The solution was to use the 2015 Sketchup folder not the 2016 folder!
                                          re: /AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/
                                          Had to be: /AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/
                                          This was for Sketchup 15 PRO!
                                          Ralph
                                            Anton_S
                                            Ralph, you probably had another issue because I can reproduce this with SU2016 and Win10 on a custom-created account, named, Användaren.
                                            TIG, MSPhysics does have path.force_encoding('UTF-8') if RUBY_VERSION !~ /1.8/. However, it could be the case that I missed it somewhere. I'll check it out.
                                            Micceo, I'll look into it. Thanks for reporting.
                                            Anton
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 46
                                            • 47
                                            • 19 / 47
