    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • F
      faust07
      After revising the scripts for v0.9.0 my test models work better than before. To record simulation to Replay is much faster too. Thanks! πŸ‘ πŸ‘ πŸ‘
      • F
        faust07
        The option to save the replay data in the model file has been lost ...?
          Anton_S
          Pilou, it's possible to create tracks, but only through scripting.
          Faust, my bad. I disabled the saving of Replay animation into model because it affected performance; that's why you noticed huge performance boost in this version. I was trying to rework it, but then completely forgot about it. The fix is underway.
          • F
            faust07
            Hi Anton, do you see an opportunity to revise your MIDI-Piano for version 0.9.0?
            • chriC
              chri
              To help you, to add control panel , please , take a look on the next pictures
              click on the second picture to anim
              If you 'd like , you can test by yourself with my SKETCHUP file and change parameter.
              Chri
              TEST CONTROLER.skp
              • Bryan KB
                Anton, I'm having problems with the UI. Here is a screen shot. It will not size into my window nor can I resize it nor does it have tabs.
                Win 7, SU 2015, 64 bit.
                Any help would be very appreciated.
                  Anton_S
                  Bryan, I'm not sure what's going on there. Does this show up every time you open it? Have you tried refreshing it (F5)? If the problem still persists, open explorer, and paste this into the address bar: %appdata%\SketchUp\SketchUp 2015\SketchUp\Plugins\MSPhysics\css. Then verify that the folder contains chosen.css, dialog.css, and tabs.css.
                  • Bryan KB
                    Thanks.
                    The files are there and F5 did not change the layout. Tabs are still not showing.
                      What version of Internet Explorer do you have installed?
                      • Bryan KB
                        v11
                          Anton, are you using ENV variables to obtain the path?
                          • Bryan KB
                            Thanks Anton. It's odd because the program installed without any trouble.
                            Is there a specific order the AMS library and MS Physics should be installed? I ask because I installed MS first, then AMS second.
                              Anton_S
                              Bryan, the order doesn't matter. I tested it on Win7 with IE11 and it works very well. I could reproduce what you have only by renaming/removing the CSS folder. So I don't know. It looks like the dialog.html can't determine the CSS paths or the CSS folder or the files within it are missing.
                                Anton_S
                                Brian, I'll test it out on my Windows 7 with IE11. So far it works fine on my Win7 and IE9.
                                Thomthom, as far as I recall I don't use ENV variables to obtain the paths. I rather modify one of them, particularly ENV['PATH'], so that msp_lib.so knows where to look for the required Dlls and this is only necessary on the Windows side. And instead of overwriting the ENV['PATH'] variable with the new path(s), I simply append another path to it. I don't think that should hurt other plugins or anything. Of course, I acknowledge that it would be a good idea to reset it to original paths after all the loading is done.
                                Edit: On the OS X Side I use install name tool to set the relative load path to the required dylibs. This can be done with xCode by adding a post build script.
                                  Anton_S
                                  Hi faust. I updated the MIDI piano a few days ago. It should work fine now πŸ˜„
                                  • F
                                    faust07
                                    Hi Anton. Thank you very much! I've found it already. I enjoy the magic sound. PituPhysics updated his MSPhysics models too. So there is much stuff to learn. πŸ‘
                                    On my side, on Win7 and Win8.1 with IE11 MSPhysics works like a charm (except to record Replay...). 😎
                                    • Bryan KB
                                      All paths and files are verified in the right location. Everything seems to work except the UI menu tabs.
                                        Anton_S
                                        Bryan, if everything worked fine, your UI should have looked like this:
                                        The screenshot that you posted above resembles a UI with missing CSS/JS files, which make it look/work improperly. Can you once again ensure that all of these files exist in your SU2015 plugins folder because at the moment I have no idea what could be the other cause:
                                        • MSPhysics/css/chosen.css
                                        • MSPhysics/css/tabs.css
                                        • MSPhysics/css/dialog.css
                                        • MSPhysics/css/expander.css
                                        • MSPhysics/js/jquery.js
                                        • MSPhysics/js/chosen.js
                                        • MSPhysics/js/ace/ace.js
                                        • MSPhysics/js/ace/ext-statusbar.js
                                        • MSPhysics/js/dialog.js
                                        • MSPhysics/js/expander.js
                                        • Bryan KB
                                          The only difference I see is that the file path I have includes "Roaming"
                                          I really appreciate you taking the time to help with this. I'm sure we'll figure it out. Thanks again.
                                            Anton_S
                                            Announcing 0.9.1.
                                            Refer to CHANGELOG for info: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                                            Faust, the save Replay data to model should be working now.
                                            Bryan K, I think the dialog displayed improperly because HTML files used HTML5 DOCTYPE deceleration. Try this version as it might be fixed here.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 46
                                            • 47
                                            • 19 / 47
