    [Plugin] LSS Toolbar 2.0 Beta
    68 Posts 39 Posters 79.2k Views 39 Watching
    • B
      boilingsnow
      I ve already tested it. LSS toolbar also works in sketchup 2014. Thank you so much.
      The follow edges tool is brilliant.
      • Bob JamesB
        Bob James
        I get the attached error (and similar other errors with other buttons) when trying to use the Toolbar
          This tool has an overly complex installation requirement. πŸ˜’
          Some files go in the Plugins folder but some others go in the Resources folder.
          It's explained in the tool's installation guide.
          It must find some files in the Resources folder because in several places like this:
          Plugins\lss_toolbar\lss_crvsmth.rb
          The tool has code:
          resource_dir = File.dirname(Sketchup.get_resource_path("lss_toolbar.strings")) html_path = "#{resource_dir}/lss_toolbar/crvsmth.html"
          If ' resouce_dir' is not found, then the empty folder path used for the html file will mean it's broken !
          Use this in the Ruby Console to find your Resources folder:
          ` File.dirname(Sketchup.get_resource_path("."))
          C:/Program Files (x86)/SketchUp/SketchUp 2014/Resources/en-US)`
          If you have this tool's files in the right places the strings file should be found too, when using.
          ` File.dirname(Sketchup.get_resource_path("lss_toolbar.strings"))
          If you don't get a 'path' some files are mis-filed...
          The returned paths will vary depending on your setup and SketchUp version etc...
            mtr
            For the correct path, you must extract Plugin content into Sketchup/plugin and Resources content into Sketchup/Resources.
            See below:
            https://image.slidesharecdn.com/lsstoolbaroverview-120827110847-phpapp02/95/lss-toolbar-overview-3-728.jpg?cb=1346084753
            See install guide here:
            https://sites.google.com/site/lssoft2011/home/lss-toolbar
              jandizondesign
              I get this error when I try to use the stick group tool.
              All other tools work fine.
              If possible, how do I fix this?
              Error: #<NoMethodError: undefined method to_a' for "":String> C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1078:in settings2hash'
              C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1073:in read_defaults' C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1153:in create_web_dial'
              C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1282:in activate' C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:23:in select_tool'
              C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:23:in block in initialize' SketchUp:1:in call'
                AcesHigh
                See below:
                problem is that we are told all the time here at Sketchucation we should in no way do manual installations of plugins like it was done in old Sketchup 8 times...
                  DreamPsi
                  First and Foremost I would like to say this plugin is amazing and thank you for you time and effort. for it makes my life easier,
                  now with that said I seem to have run into a problem with the stick group tool on your lss toolbar for sketchup 2016 when I click on it nothing happens, it doesn't bring up the html page for editing, but all the other tools work just fine.
                  i use windows 10 os
                  i was thinking it just might be a file pathing problem seeing how sketchup 2016 uses two different directories for plugins and resources.
                  I.E for the resources folder is located in C:\Program Files\SketchUp\SketchUp 2016\Resources\en-US
                  meanwhile for the plugins them selves is located in C:\Users\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                  but if all the other tools work i don't think its a pathing problem. i tried looking at your code to see if there was a discrepancy but i couldn't find anything wrong with it logic wise although I'm not too good with programming πŸ˜’
                  i saw on one of your youtube posts that it might be six months before you get around to updating lss toolbar πŸ˜•
                  please help i installed the plugin to the correct folders and unistalled then reinstalled and nothing seems to work.
                  oh and by the way your lss_arch is also pretty amazing. which i like a lot reminds me of the functionality of the good ol halflife 2/ source level editor i started using when when i got into modeling and level design. 😎
                    DreamPsi
                    Hi first of all i think your plugins are amazing, thank you for your time and effort on them
                    but with your lss toolbar plugin in sketchup 2016 most of them work but the stick group plugin
                    doesn't for some reason i get this in the ruby console window whenever i click on it in the tool bar
                    Error: #<NoMethodError: undefined method to_a' for "":String> C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1078:in settings2hash'
                    C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1073:in read_defaults' C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1153:in create_web_dial'
                    C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1282:in activate' C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:23:in select_tool'
                    C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:23:in block in initialize' SketchUp:1:in call'
                    it doesn't even load up the dialog html command window for this specific function
                    everything is installed in there right places please help
                    ok I have seemed to have found a solution for the stickgroup function in sketchup 2016.
                    sketchup 2016 uses the newer version of ruby code. which makes the method to_a function not work unless you put it as lines.t_a first.
                    so in the lss_mshstick.rb
                    the problematic code is this
                    line1078 @settings_hash["stick_vec"]=[@stick_vec.to_a.join(";"), "vector_str"]
                    line1082 @settings_hash["bounce_vec"]=[@bounce_vec.to_a.join(";"), "vector_str"]
                    the new fixed code is this
                    line1078 @settings_hash["stick_vec"]=[@stick_vec.lines.to_a.join(";"), "vector_str"]
                    line1082 @settings_hash["bounce_vec"]=[@bounce_vec.lines.to_a.join(";"), "vector_str"]
                    so that fixed it for me though I'm still getting error msgs in the ruby console but its not affecting the function as far as I can tell.
                    so hope this helps you guys
                      DreamPsi
                      thanks I will try my hand... but seing how I'm rusty at programing that hand will probably find my face several times before finding the other hand lol.
                        driven
                        @DreamPSI,
                        I imagine you are now getting a 'less fatal' No Method error for 'lines'...
                        but you could try to fix it properly...
                        the to_a method used to take a String and 'split' it into an array...
                        as it's no longer available you need to 'split' any String yourself...
                        so to find what we need to 'split' we first need to know what @stick_vec is...
                        on line 108 @stick_vec=Geom::Vector3d.new(0,0,-1), but if you do a test in 'Ruby Console' it's not a String and @stick_vec.to_a will work, so we keep digging...
                        on line 1063 @stick_vec=Sketchup.read_default("LSS_Mshstick", "stick_vec", nil), will return a String and
                        on line 1073 we see it's being passed to the method that's failing using self.settings2hash...
                        so now we have a String and we know it was once in the format of (n,n,n) we can try splitting it using ','...
                        @stick_vec.to_a.join(";") >> @stick_vec.split(',').join(";")
                        but, there is another place as well, so use search and replace for @stick_vec.to_a to find it...
                        @bounce_vec.to_a possibly has the same solution...
                        • E
                          elizabeth001au
                          Please excuse me if I have missed something. I am excited about this plugin. Downloaded it today and went to use it. Can not
                          use any tool. Each tool give me the message " Cannot find file LSS_toolbar/pathface.html" I have read the installation instructions and have checked that everything is in correct folder. The same message repeats for each different tool. Thanks.
                            DreamPsi
                            open ruby script console, copy and then post the results here, when you try to click on the tool bar buttons
                            idk maybe you dled a baddy
                            • E
                              elizabeth001au
                              Thankyou DreamPSI. Yes, I was able to make the toolbar appear to be active. However, unfortunately this tool is not working with Sketchup Pro 2016. The last version it is compatible with is Sketchup 2013. This is due to some changes in API. Shame really...I was very keen to play with this, as it appears to be just what I need.
                                What tool exactly?
                                Seems Lss works fine in 2016!
                                Ah Yes The Stick tool : curious I have seen the Stick Dialog Box one time but then after to close it impossible to re-appear! 😞
                                http://s6.postimg.org/lilkfpzwx/lss.jpg
                                Someone can post the file lss_mshstick.rb modified for 2016 ?
                                  DreamPsi
                                  I would but unfortunately I had to reinstall windows ten due to a virus but if you look at the post by driven a few posts up you would see exactly where in the rb file you need to change the code to the corrected code. it can be edited in any text editor, I find notepad++ to be an excellent fast and easy app that's free for editing minor script changes
                                  ill will reinstall sketchup and re dl the lss tool bar and post the updated rb for mshstick.rb in lss tool bar plugin at a later date.
                                  • F
                                    frankleng
                                    @pilou said:
                                    What tool exactly?
                                    I had the same problem. NOw it works.
                                    lss_mshstick.zip
                                      NOw it works.
                                      Not yet! Even more it's bugsplat and crashes! πŸ˜‰
                                      • H
                                        haydenr
                                        I am also having the issue where it cant find the support html files. Every tool replies with the same pathing issue.
                                        • Bob JamesB
                                          Bob James
                                          This problem has existed for almost two years!! 😐
                                          See earlier post in this thread dated..Mon Sep 22, 2014 12:15 pm
                                          • C
                                            crazyteaboy
                                            Does this work with SU2017? The folders mentioned to copy the files to, the Plugin one doesn't exist!!! Will there be an update for SU2017?
                                            • 3 / 4
