    Things past revisited
    14 Posts 8 Posters 2.2k Views 8 Watching
    • tuna1957T
      tuna1957
      love it πŸ‘
      • pbacotP
        Wonderful to see what can be done. Don't even have a idea how you get those bumps or displacements and whatever so fine. I feel I could run my hand over that wall. And just everything.
        Evocative as all get out. Thanks for posting.
        • massimoM
          massimo Moderator
          Thank you all for the very kind words guys. πŸ˜„
          @Box Well...I don't think I deserve such a beautiful post. 😳
          @pbacot the first image had displacement, but for this one I used only bumps. It's a layered material (a layered base + a coating), but I've used only one map tonemapped (changing gamma, contrast, brightness etc.) directly in Thea for the different slots.
          Btw here is the map if someone is interested. πŸ˜‰
            Why bump and not normal?
            How layered is the paint material?
            • HornOxxH
              HornOxx
              Massimo - exact this render was one of my all time favorites - now more than ever!
              Box had been able to bring it to the point:
              @box said:
              ...and...is the difference between art and decoration...
              never trust a skinny cook
              • massimoM
                massimo Moderator
                Thank you very much HornOxx. πŸ˜„
                @Rich
                I don't know. I use both of them. Perhaps with B&W images you can easily tune them or even tonemapping them directly in Thea in order to have other useful maps.
                Well it is a material with a basic layer with a plain color in the diffuse slot and a bump, no reflectance, and a coating layer on top with reflectance, roughness and bump map.
                • marked001M
                  marked001
                  damn, man... awesome.
                  you did the volumetric light in studio?
                  http://www.revision21vis.com
                  instagram: revi21on
                  • massimoM
                    massimo Moderator
                    Yep, it's simply a cube intersecting the corridor with a medium material applied on it. As you can see from the SS the camera is placed outside the cube.
                      Does this the remember of the tricycle of Shining ? πŸ˜‰
                      • massimoM
                        massimo Moderator
                        Who knows? πŸ’š
