    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Smoothing advice? Updated
    23 Posts 6 Posters 4.6k Views 6 Watching
    • Bryan KB Offline
      Here's the base model. It was created by Push/Pull, Add New Segment (+), then scaled on individual sides.
      If I need to rebuild it using a different workflow or technique, that's fine as well.
      body geometry.skp
        Even with all of the surfaces smoothed as much as possible it will still look faceted, because there are inner partition faces which prevent the outer skin becoming perfectly smooth...
        Removing them helps... but you need to do more work...
        • Bryan KB Offline
          Ah ha! That's certainly a huge improvement! That's really quite interesting how the inner faces have that affect. I never knew this.
          More work? Sure. Do you have any tips or advice? Thanks!
          • ely862meE Offline
            ely862me
            You still have some lonely and hidden edges here and there and they also cause that faceting(plus the weak shadowing sketchup engine).
            Here's what I would do, I would keep about 8 profiles and I would create a mesh between them with the Curviloft plugin(the face button), nice and clean.
            Elisei (sketchupper)
            Come and See EliseiDesign
            • Bryan KB Offline
              Thanks Elesei. I used Curviloft on my seaplane model and was pleased with the results using the same technique of a few profiles and "connecting" them. However, some members here pointed out that the face count was very high and it was. But again, the results were very good.
              Is that final result on the far right? If so, then that's the technique I'll use. That's exactly the amount of smoothing I'm looking for.
              • ely862meE Offline
                ely862me
                It doesn't matter the faces count if you can still work easily with the model.
                For your model, you exaggerated with the curves segments, you could have kept them less segmented(you know that you can change the segmentation of the arcs, when you draw them).
                Yes the far right model is the model achieved with the Curviloft. Keep in mind to work the settings of Curviloft to have more or less segmentation in your mesh and also to achieve a flowing shape. I added more segmentation for mine because the profile are far enough.
                I have changed the arcs on a profile and then scaled that profile to match all the others(I believe you did the same with yours- push/pull and scale?)
                The result is cleaner and you can play with the curviloft's settings as you want with a wonderful result.
                1.skp
                • Bryan KB Offline
                  Thanks Elesei. I'll try that and post the results in a few days. (I did not download the model, but I very much appreciate you making it available.)
                  Also thanks to everyone else for their help and advice!
                  • Bryan KB Offline
                    Working almost prefect. Except... what the heck is that?
                    • ely862meE Offline
                      ely862me
                      See the hidden geometry, most likely an edge snapped.
                      • ely862meE Offline
                        ely862me
                        There is something. If I recall well, you have there a small segment that creates a small crease throughout the body. If you remove that segment I believe it will be alright.
                        It doesn't matter how far the sections are it will create the same amount of segmentation.
                        • Bryan KB Offline
                          Thanks Elisei. I did look at the hidden the geometry but I did not see anything obvious.
                          I think I may have the 2 vertical sections just slightly too far apart. I'm going to try moving them closer together and see what happens.
                          • Bryan KB Offline
                            Cool. I'll check that. It's supposed to be a smooth transition from a curve to straight line. If it's not, then the result would make sense.
                            • Bryan KB Offline
                              After much playing around and thanks to everyone's advice, here's what I ended up and pretty much exactly what I wanted.
                                I think you will find the remaining 'lines' around the hull are bulkheads, they can be deleted to improve the shape further.
                                • Bryan KB Offline
                                  Thanks, yes, that's exactly what they are. ๐Ÿ‘
                                  • Bryan KB Offline
                                    Here's how the shape is evolving.
