    Split Face Problem
    17 Posts 4 Posters 2.5k Views 4 Watching
    • mootM Offline
      moot
      Thanks again, you make it look easy πŸ˜‰
      I did searches on rove internal faces but looks like plugin?
      Can you recommend one?
      You can lead a horse to water, but you can't make 'em think!
        There are plugins to do that but it's certainly not difficult to do it with native tools. After intersecting the cylinders, I just hid an end of a cylinder and deleted the internal faces by selecting them and hitting Delete. I would suggest you learn to do it that way before you start looking for an extension to do it.
        • mootM Offline
          moot
          Will do, thanks...
          • BoxB Offline
            Rove is a typo. Dave meant to say Remove internal faces.
            • mootM Offline
              moot
              @dave r said:
              There are plugins to do that but it's certainly not difficult to do it with native tools. After intersecting the cylinders, I just hide an end of a cylinder and delete the internal faces by selecting them and hitting Delete. I would suggest you learn to do it that way before you start looking for an extension to do it.
              I was trying... I wrestled with the 'intersecting'... got frustrated... what I ended up doing was starting over (as suggested in other posts)...
              I took my original Strt-Core,
              saved as X-Core,
              made a copy of the cylinder, rotated it, and placed it into the other cylinder and pulled the ends/faces of the cylinders until I got the length I wanted...
              The real problem I had was that when I printed, one cylinder in the model was .0xx above the axis of the other cylinder... it took me a few 'move' operations to get both cylinders on the same horizontal axis in order to print properly... which leads me to ask, is there any tool to 'align' objects to one axis, i.e., the bottoms of the cylinders will lay flat on the build table when built?
              Once I got the X-Core right I was able to save it as my Tee-Core, push the face of one cylinder into the center of the crossing cylinder and it printed fine. πŸ˜„
              Thanks for all the help in giving me some clues/tips... I still have a lot to learn (like how the transform stuff works), but at least I think I'm making some headway in rough seas...
                Hmmm... I'm glad it worked but it seems that it was much more difficult than it should be and in your screenshots, you have some triangulation that really shouldn't be needed.
                Do you want just the tee without the extension of the crossing cylinder that you have in your original image and like I drew?
                • mootM Offline
                  moot
                  oh ya, getting the two cylinders aligned was very difficult for me... I noticed that 'triangulation' also... when I pulled the faces to make the X-Core that seems to have closed up. πŸ˜• This is what pulled from...
                  The pics are some of the pieces I need for the 'proof of concept' model I'm working on.
                  I have to make others that will include adding a ~12[sup:1t7rp2vh]o[/sup:1t7rp2vh] cylinder coming out from the top of the tee... and other variations for a variety of 'connectors'... anyway, although the extra geometry is not needed, the pieces print and that is what I need to get done now. These models are primarily needed to do the sand casting molds, the drawings can be fixed later, if needed.
                  I appreciate the offer... but I don't want to impose on your time... you've given me quite a lot of help already... and I'm sure I'll need more πŸ˜‰
                  How 'bout some idea's on an easier way to 'align' pieces? πŸ˜•
                  I'm just about to try figure out my outside-corner-tee-with-12[sup:1t7rp2vh]o[/sup:1t7rp2vh]-core... needs to be like the X-Core with one cylinder folded up 12[sup:1t7rp2vh]o[/sup:1t7rp2vh] from horizontal...
                    Alignment shouldn't be difficult. Make sure when you drag out the circle that you are dragging the radius on axis. If you are dragging out the radius of the circles at random angles, you'll be creating all sorts of problems for yourself.
                    Since the diameter of the tubes is the same, you should be able to simply copy and rotate the first one to make the other part. If you are roating on axis, the alignment should be automatic. When you are moving entities, make sure you are grabbing the entity by a logical point that you can move to another logical point.
                    • mootM Offline
                      moot
                      Thanks, I think I'm getting the hang of it... one thing I find is that when moving an object, i.e., I'm looking at the bottom of one of the cylinders, any slight movement of the mouse to either side shifts the object... I would like to be able to select the object to be moved and then be able to use the up/down, left/right arrow keys to start moving the object and then type in the distance to move, if necessary... seems like until you start movement in a direction I can't type in a value πŸ˜•
                      I did re-do the X-Core and got rid of the 'triangulation'
                        You'll need the mouse to give direction to the move but you can lock the direction based on the axis with right, left, up arrows. If you were able to use the cursor keys to move, it would be in some increment and it would be extremely difficult to make precise moves.
                        One thing just occurred to me that might be causing you difficulty. Check under Model Info>Units and make sure the box for Enable Length Snapping is unticked. Length snapping would create a problem similar to incremental moves with the cursor keys.
                        • mootM Offline
                          moot
                          Thanks, I'll give it a try. Even though you wouldn't have 'precise' control with arrow keys, it gets you into the ballpark faster and then enter a precise value, imho... guess I'm just used to PhotoShop, Word, methods of moving and modifying images...
                          Here is my latest variation... may not be the cleanest drawing... but it prints fine πŸ˜„
                          Oh, yes, I unchecked all 'snapping'... everything, move, rotation, etc., still seems to jump and I use typed in value...
                          Thanks again.
