    Compute Rotation and Scale from Transform Object
    26 Posts 9 Posters 6.4k Views 9 Watching
      Djarlo
      Thanks to both πŸ˜„
      heh must have missed that type too time and again i looked it all over to see whats wrong πŸ˜›
        tomasz
        @martinrinehart said:
        @dburdick said:
        I read your wonderful web-page description of the 4 x 4 matrix - ...
        Very kind words, indeed. Many thanks.
        For those not versed in the Transformation Matrix, my tutorial's Appendix T, introduces it, Appendix MM explains matrix multiplication and Chapter 16 explains how you can live without it (and includes a Matrix class, just in case).
        Thank you Martin for those wonderful tutorials. I wasn't aware that transformation.to_a[15] is a divisor for a translation! As far as I am aware SketchUp itself keeps it equal to 1, but some plugins modify Wt (i.e. Component Stringer).
          Ruts
          I have a question about the euler_angle method, especially about the xyz. I have searched the web and found information about this case, but it didn't result in an answer.
          Here's how I read this piece of code:
          when you call the method euler_angles you create an empty array under variable xyz as parameter. Then nothing happens with the array for the whole piece of code. At the end the array can be ==0 (contains one element which is equal to zero), ==1, ==2 or still empty. How can it be that the array can contain elements?
          • Dan RathbunD Offline
            Dan Rathbun
            Words in ALLCAPS are reserved for constants.
            Words in Titlecase are for Class and Module Identifiers, (which are also constants. Any word the starts with a capital character is a constant.)
            Bad:
            Selection = Sketchup.active_model.selection[0] Rotation = Selection.transformation.rotXYZ
            Good for variables:
            selection = Sketchup.active_model.selection[0] rotation = selection.transformation.rotXYZ
            πŸ˜‰
            I'm not here much anymore.
              Dan Rathbun
              @ruts said:
              ...when you call the method euler_angle you create an empty array under variable xyz as parameter.
              The secret is that Ruby does not really "have" variables, even though the books use that name. Ruby has references that point at objects, and a reference can be made to point at any class of object, and then later be re-assigned to point at any other object of any class, at any time.
              This is referred to as "weakly typed", but really Ruby references are not type locked at all.
              Because it (the argument) is just being used as a switch to tell the method what the coder wants as an output. An empty array object is simply the default, which tells the method the calling code expects an array as a return object.
              It cannot. You mis-understand. The method is not testing an array, it is testing a reference to the method argument to see if is pointing at integers 0 or 1 or 2, or still pointing at [] (the default empty array object,) and then returning either the indicated values, or an array of all three.
              IF you call the method with no arguments, or like euler_angle([]) you will get an array of 3 values.
              IF you call the method thus: euler_angle(0) you will get the x value returned.
              IF you call the method thus: euler_angle(1) you will get the y value returned.
              IF you call the method thus: euler_angle(2) you will get the z value returned.
              The 0, 1 and 2 subscripts come from the SketchUp API's extension of the Array class, where 3 element arrays can act like points and vectors.
              Still have not read the book, I see.
                Ruts
                I did delete the rotX/Y/Z methods, that's why I didn't understand where the variable xyz came from and why it could get value = 0/1/2. I do understand how methods with there variables work. Sorry was confused.
                On the other hand, I have been working with the euler_angle method for a while and now that I'm closely getting to a complete script I have noticed this method only partial works (for me?). Does it work for you guys? When I did draw shapes with a given rotation, the method didn't succeed to calculate the right angles for me so I did some research and made some changes. Here's the code I use:
                	def self.rotation(trans)
                		b = [trans.xaxis.to_a, trans.yaxis.to_a, trans.zaxis.to_a]
                		m = b.transpose.flatten!
                		if m[6] != 1 and m[6] != -1
                			ry = -Math.asin(m[6])
                			rx = Math.atan2(m[7]/Math.cos(ry),m[8]/Math.cos(ry))
                			rz = Math.atan2(m[3]/Math.cos(ry),m[0]/Math.cos(ry))
                		else
                			rz = 0
                			phipos = Math.atan2(m[1],m[2])
                			phineg = Math.atan2(-m[1],-m[2])
                			if m[6] == -1
                				ry = Math;;PI/2
                				rx = rz + phipos
                			else
                				ry = -Math;;PI/2
                				rx = -rz + phineg
                	return [rx.radians,ry.radians,rz.radians]
                First I found this document (page 5) that explains the calculations the way you do it. But it seems that you miss little pieces of code to make it complete.
                When I did calculate the angles it yet didn't calculate the right angles. So I did try some things and found out that the angles that were calculated represent the transpose matrix of the rotation that I need. So I fixed this by transposing the rotation matrix before the calculations.
                With these changes this piece of code does calculate the right angles. Did your code work for you?
                  Dan Rathbun
                  You realize that this topic thread is like 4 and 1/2 years old ?
                    Ruts
                    Yes, I have seen it. That does not mean that people can't come here and look for code that works? That's how I landed here. I was looking for some code that could convert the rotation matrix to euler angles. I found out that this code didn't work for me, so I did correct it and now I share it here just in case people experience the same problem as me. I'm just excited that I finally can contribute a little instead of always asking things!
                    Nothing wrong with that, right?
                      Dan Rathbun
                      @ruts said:
                      Yes, I have seen it. ... Nothing wrong with that, right?
                      I was referring to your asking questions of original posters, who might not remember, or might not even have been active here for some time.
                        Jernej Vidmar
                        Hello transformation gurus!
                        just to double check the euler_angle(xyz=[]) method ... is the condition:
                        if m[6] != 1 and m[6]!= 1
                        at the beginning correct? Why double checking the same variable against the same value? Or is it meant to be:
                        if m[6] != 1 and m[6]!= -1
                        Cheers,
                        Jernej
                          An olde typo - use 1 for the second test...
                          • 2 / 2
