    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Anton_S
      Cristyan, I fixed the replay play button. Try version 0.7.2. It's in the first post.
      • F
        faust07
        Play and Reverse buttons work fine. Play, Stop and then Play again or Reset is running into problems...
        Emitted objects are not reset. Please test the model.
        MSP_EmiterTest_02.skp
          Ralphxyz
          faust07, Thanks for posting, the accumulation does not grow, is that a shortcoming of MSPhysics. or something you control?
          • F
            faust07
            This you can control with MSPhysics. The lifetime of the objects is very short, so that they will be deleted after 100 Frames.
              Anton_S
              Thanks for the report faust. I will fix it and also get the feature to save replay into model in the next release.
                aasssddff
                Where can I find documentation on how the servo works? There was a comment way back that had...
                CODE: SELECT ALL
                rightx Left - right arrows
                righty Up - down arrows
                leftx A - D
                lefty W - S
                key('1') 0-9
                key('a') A-Z keys
                key('enter') All the Windows function keys. (lctrl, rctrl, space, backspace, etc...)
                key('numpad1') 0-9 Right numpad keys
                key('+') Numpad operations (+, -, *, /)
                key('lbutton') Mouse keys (mbutton, rbutton, xbutton1, xbutton2)
                get_var('variable') ... for script.
                What do I do with this?
                  SynSuka3D
                  😒 Xbox controller please !!!!
                    Anton_S
                    Announcing version 0.7.3. Download in first post.
                    Faust07, I fixed the replay bug. I also added the feature to save replay into model. The replay is saved into model automatically just like in SP.
                    SynSuka3d, I added joystick controls similar to SketchyPhysics.
                    Here is a sample model: See controls in model
                    Note that in order for the joystick to work it must be attached to USB before SketchUp is opened; that is, restart SketchUp if joystick doesn't work in the first place.
                    • F
                      faust07
                      Good news, as always. πŸ‘
                      • F
                        faust07
                        The boat-car is a good example to learn the use of thrusters and joints (motor joint as a component copy).
                        Version 0.7.4 (May 26, 2016) has the same problem in Replay that Play, Stop and then Play again is running into problems...
                        Maybe it is my computer...
                          Anton_S
                          The emitter test you posted in one of the earlier post works as expected. Can you elaborate more on what problems you encounter?
                          • F
                            faust07
                            Sorry. Maybe I have the function of the stop button just now understood. I think that with the stop function the model can be held and saved in an intermediate state of the simulation. After that you should delete the replay storage, otherwise unexpected intermediate phases of the simulation arise if you start or play again.
                              Anton_S
                              Announcing version 0.8.0!
                              This version comes with many bug fixes and improvements. As well as with two new joints: CurvySlider and CurvyPiston. A demonstration of these two joints is available at 3DWarehouse: https://3dwarehouse.sketchup.com/model.html?id=d21984a9-477b-44d7-9eca-c191ae85afe4
                              • F
                                faust07
                                The new Curvy Joints improve animation along paths fundamentally. The possibilities are not yet in sight. Great is that you can take curved sections and even edges with the joint in a group without to weld them, and therefore the curve in turn can be moved. Your examples show this excellent.
                                Two questions:
                                What are the rules for the orientation of the joints to an individual curve - exactly parallel?
                                It seems that old Servo Joints with Oscillator as a controller are not functioning as in version 0.7.0? Tested for example, with birdy and orca.
                                  Ralphxyz
                                  Well I hopefully thought I'd try again.
                                  http://gettheworkdone.net/images/MSPhysics/6-13-2016_0.8.0.jpg
                                  the error at least looks a little different.
                                  Windows 10
                                    Anton_S
                                    Hello Faust,
                                    Curvy joint orientation has no effect on a curve or whatsoever. The curve may be parallel or not parallel to the actual joint - it doesn't affect the way joint behaves. The joint object just represents the origin of the joints. The edge closest to the origin of the joint is considered as the starting edge and all its connected edges are considered as the consequent edges. As long as the curve (or a set of connected edges/arcs) is created within the joint, with the angle between each edge set to a maximum of 45 degrees, the curvy joint will work fine. To my experience CurvyJoints operate better on iterative solver than on exact solver. So if you use curvy joints, setting a solver model to iterative 4+ passes will guarantee the optimal behavior.
                                    The servo joint was reworked in this version. Now instead of accel and damp, it uses angular rate, and the SP Mode was removed. If your joints relied on SP Mode, their controller values ranged from 0.0 to 1.0. Now that is changed. The controller values range from -min_angle to max_angle. So for your birdy the servo controllers should be changed to something like, oscillator(100)*30. The limits should be disabled or adjusted to -30,30.
                                    Ralph,
                                    Sometimes the zip file fails to extract all content. Try checking if Plugins/MSPhysics/win64/2.0/msp_lib_no_sdl.so exists.
                                      Anton_S
                                      Ralph, I reworked the main.rb to display more info about the loading errors.
                                      Place in .../Plugins/MSPhysics/ folder. Overwrite the original one.
                                        Ralphxyz
                                        Thanks Anton,
                                        http://gettheworkdone.net/images/MSPhysics/2016-06-13_18-25-06.jpg
                                          Anton_S
                                          Okay that's better. Based on the message, particular files are missing from the plugin's folder. As mentioned before this could be due to extraction issues, where the zip extractor fails to extract all the files. To ensure that its not the code error, go to C:/Users/Ralph/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/win64/
                                          and check if all of the following files are there:
                                          • libFLAC-8.dll
                                          • libmikmod-2.dll
                                          • libmodplug-1.dll
                                          • libogg.dll
                                          • libogg-0.dll
                                          • libvorbis.dll
                                          • libvorbis-0.dll
                                          • libvorbisfile-3.dll
                                          • SDL2.dll
                                          • SDL2_mixer.dll
                                          • smpeg2.dll
                                          If that's not the case, try re-downloading MSPhysics and extracting using 7-zip, as it might a better alternative to the standard windows extractor. If you don't want to go through all that manual extracting and moving mess, you can instead use PluginStore plugin to download and install MSPhysics by a few clicks.
                                            Ralphxyz
                                            When I download from the PlugIn store all I get is a .rbz file not the zip file.
                                            Does that go in the Plugins folder?
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 46
                                            • 47
                                            • 16 / 47
