    Change order of objects in dynamic component?
    Scheduled Pinned Locked Moved Dynamic Components
    5 Posts 4 Posters 7.9k Views 4 Watching
    • halroachH Offline
      halroach
      In the dynamic "Component Attributes" window, is there a way to change the order of the components (objects)?
      It seems like the only thing that affects the order is the last created/pasted component which appears at the bottom of the list.
      FlexTools - Super Quick Windows, Doors, Slats...
      • TrixtaT Offline
        Trixta
        I also have this question. So I'll just follow along..
        Win7 & SU14 Pro
          pcmoor
          use outliner
          select and and drag the sub_components to the corresponding parent level or other location of your choice, leaving the one sub component you want first (leave at least one otherwise the container will delete itself), then drag the moved components one at a time back and they add under the previous, as mention above for copies
          Outliner is the idea tool for many operations on nested groups / components
          • 2 Offline
            2Harry
            **"use outliner"
            This only lets you change the parenting of the sub-components it seems. The components are listed alphabetically in Outliner so no way to change the order here that I can see.
            But the listing of components in the Component Attributes window doesn't follow the Outliner anyway. As halroach points out, the components there are listed with the last created at the bottom of the list. A bit of a pain when the number of components grows so large that the parent attributes disappears off the top and you have to keep scrolling up and down.
            It would also be nice if you could change the order of Component Options on that particular window so you could group the parameters in some kind of logical sequence. I guess the solution to that is to get so competent building DC's that you have those sequences already planned out before you start!**
              pcmoor
              Controlling List Ordering for Component Dialog Box
              Is there a way to control how the various components are arranged in the COMPONENTS ATTRIBUTES dialog box? I have a single CABINET component that consists of seven sub-components. The way the various components are seq…
              SketchUp Community (forums.sketchup.com)
