    [REQ/Q?] Flattening and exporting scenes as skp files.
    38 Posts 8 Posters 5.7k Views 8 Watching
    • pbacotP Offline
      How is this scheme a different result than exploding the model port in LayOut?
      Because you want to "draft" 2d in SketchUp? It would have been easier if LayOut were more like SketchUp (which everyone wanted).
      • JQLJ Offline
        JQL
        Well pbacot, that's the real question here: why?
        Exploding the model in layout breaks the connection between sketchup and layout.
        Exporting scenes from sketchup to an outer file will not:
        1. You can work on a 3D model;
        2. Export your scenes as 2D;
        3. Insert your scenes in Layout or into another Sketchup File (See Note 1);
        4. Work in Layout VERY fast as the models are 2D, and with better LAYOUT inferences as the model is 2D;
        5. Or work with the other Sketchup file and draft in Sketchup (See Note 2);
        6. Then you can insert this sketchup file in Layout as before and work VERY fast as it's 2D and, with better Layout inferencing as it is 2D;
        7. And you can go back at the original model and work with it;
        8. And you can export the model scenes again, overwriting the previous ones;
        9. And you can simply reload them in the 2D drafting Sketchup file or in Layout (Or in the 2D drafting Sketchup and then in Layout.)
        Note 1: Inserting into another sketchup file, makes a Sketchup model referenced. Sketchup get's a link with that file and if it get's replaced or edited, it can be reloaded at any time. The same thing happens with Layout, of course.
        Note 2: It's only useful to insert in Sketchup if you want to design 2D stuff into those scenes without changing them. As a new export will overwrite them you'd loose your changes to them. Inserting them in sketchup allows for references in note 1 and you can be using sketchup as a sort of a drafting tool instead of Layout, as it's hard to draw with Layout and it's a breeze to draw with sketchup.
        NOTE3: Of course Sketchup could benefit from true line styles for drafting.
        NOTE4: Of course Layout could be faster and have better drafting tools.
        NOTE5: Of course if Layout would flatten 3D models instead of rendering them as true 3D, it would be much faster and this wouldn't be needed.
        NOTE6: But note 3 to 5 aren't there now, nor in the foreseeable future... Unfortunatelly, so this is another area where plugin developers can make our life easier by circumventing frustrating issues.
        www.casca.pt
        Visit us on facebook!
        • pbacotP Offline
          You could ovewrite just the same. I'd keep the original "live" SketchUp ports in place. This way you avoid all the positioning and scaling (unless you've worked that out in process.
          Unless you can automate a lot of this, there are so many steps. Every little update can cause time and room for errors. I find enough of that just in the regulars SU-LO flow.
          BTW my SU-LO flow almost always ends up with a pdf in PowerCADD and I do my secondary drafting in there. So I've added some steps myself to avoid working in LayOut. What I'd want is PowerCADD to reference LayOut files directly.
          • JQLJ Offline
            JQL
            I'm not sure of what you're saying here, but I think you're talking about the idea of inserting the 2D exported files into a new file and the probability of editing them in the new file.
            If that's the case, then I can see almost no flaws in the process. It's the same process I use for Xrefing Sketchup components:
            1. I have a model;
            2. I export components from that model into a folder.
            3. I never work directly on the components on that folder.
            4. I import those components (all of them) into a new Sketchup file;
            5. I work on that sketchup file without modifying inserted components (I lock them if I must);
            6. I reload those components as I need to;
            7. I insert this new file in Layout and reload it as I need to.
            The main flaw is that you can't edit the components directly or you'll loose your editions with reloading. It really doesn't matter to me, as There's a zillion ways of doing all kinds of drafting without ever touching those components.
            Another flaw I see is that it's kind of stupid to setup all scenes in sketchup and then don't use them directly in Layout. That's true, but the problem is that Layout takes so much time loading those, that we really can't work with it if we have to be constantly reloading heavy stuff.
            I'm having a hard time and I have a Titan X GPU and an Overclocked 5820K processor. There are better than these, but these are certainly better than the majority of laptops used to work with LO.
            That is true, definetelly, but it's something that I setup one time only.
            It's just the same with Layout. The hardest time I have is setting up my sheets and viewports. Then it's a matter of working with sketchup and reloading.
            It sounds simple enough, but the reloading part is incredible. It just takes ages on complex projects! I literally get distracted while waiting and often start doing something else.
            Usually that happens and I find something I must fix and so it starts all over again.
            With my suggestion the process of seting up has an extra level of complexity, but I'm counting on less reloading times between all apps and a lot more speed on the drafting workflow.
            That's what I'm trying to avoid. I do a lot of drafting in sketchup right now. It's much faster to do it here than anywhere else and I can use materials and styles to create striking and clear presentations. Even if I lack linestyles... wich, to put simply, we should have!)
            If I wanted to use CAD, I'd probably be using Skalp to do this in dxf. But I hate CAD. I can't work with it anymore!
            What I wanted was someway to use Layout and Sketchup to definetelly don't miss CAD anymore.
            My Layout could have a set of 2D scenes mixed with 3D scenes that came directly from model and nothing would beat it! Now I want to beat in it most of the times!
            www.casca.pt
            • pbacotP Offline
              Yeah. but I always liked PowerCADD. Only thing it is really just a 2d graphic program with CAD precision and a lot of tools.
              I think you have more to deal with in terms of LayOut (like SU) being unable to handle large projects. My projects are smaller, the ways I use LO limited, and with 2016 LO, it's almost fast enough for what I do to be bearable.
              • JQLJ Offline
                JQL
                I wish I'd like CAD!
                I love SU though!
                www.casca.pt
                  glro
                  i probably don't understand everything that is written here, and this probably too simple for you, but what about:
                  setting the camera in the sky downwards for each scene
                  making a screenshot of each scene
                  this would give you pictures you could import in sketchup or layout (i am not sure for Layout), and you could draw on them
                  • JQLJ Offline
                    JQL
                    The issue is a bit more complicated than that.
                    Architects using sketchup need an easy workflow to convert their 3d models into accurate drawings, to represent buildings and to share with consultants.
                    The workflow involves 3d modelling of the most important parts, 2d drawing that is extracted from 3d,and 2d drawings that complement those and are still accurate
                    usually the later are done in cad, but I do them in layout or sketchup.
                    I want to streamline that workflow as sketchup is great at 2d drawing too if complemented with layout for text, lifestyles dimensipning and pagination.
                    the issues that arise from working with layout, are also less evident when you work with 2d sketchup models/drawings.
                    www.casca.pt
                      glro
                      I tried something: here is a scaffolding model
                      3d
                      i made a component out of it,selected it, and applied these lines of code
                      model = Sketchup.active_model # Open model
                      entities = model.entities # All entities in model
                      selection = model.selection # Current selection
                      for e in selection
                      echelle = Geom;;Transformation.scaling [0,0,0],1,1,0.00001
                      e.transform!(echelle)
                      and this is what i get
                      flat
                      is it something like this you are asking for?
                      • JQLJ Offline
                        JQL
                        Apparently it is. I'm not in my pc though... Would that work with a section?
                        www.casca.pt
                        • jiminy-billy-bobJ Offline
                          jiminy-billy-bob
                          That scales the model on the Z axis to something close to 0 (actually 0.00001). So make sure to run in a few times to be sure that any vertical dimension gets smaller than Sketchup's tolerance.
                          • JQLJ Offline
                            JQL
                            If that scales to close to 0 it means it will have all the geometry between 0 and 0.00001 right?
                            It will still be 3D not 2D, it looks exactly like what I want it even get's textures.
                            But isn't that, exactly the same 3D model with the same amount of information? Won't it probably give Layout the same amount of work on 3D calculations?
                            Also as it isn't 2D it will be hard to export to CAD in a later stage when sharing with people that need dwg or dxf. Or it might give us errors when drawing in the 2D sketchup file.
                            Also, as Jiminy pointed out, it's working in Z axis only, though that would probably be easy to make it work in any axis (I'm personally interested in a section plane's normal direction.).
                            It's a shame though, as it is really looking exactly as the ideal 2D output would look.
                            Thanks for your input glro and Jiminy!
                            www.casca.pt
                              jiminy-billy-bob
                              Well, if you run it a few times, the dimensions along the axis will get smaller than the tolerance, and Sketchup will merge everything.
                              I think...
                              • JQLJ Offline
                                JQL
                                Then how will Sketchup know it has to keep the visible entities and disregard the rest?
                                www.casca.pt
                                  glro
                                  i tried this
                                      for e in selection
                                  it works, 0 thickness, but colors are mixed
                                  and it cannot be undone, i suppose, because 1/0 doesn't exist
                                  all the geometry is in the flattened component, because the size of the file is about the same, before and after, and if i unscale by scaling the flattened component 1/00001, it works
                                      for e in selection
                                      echelle = Geom;;Transformation.scaling [0,0,0],1,1,10000
                                  It would be possible to scale along any axis
                                  I tried to export the flattened model to dxf, and import it into my CAD software, designcad 9000, but it doesn't work
                                  Then i tried to go back to sketchup from the dxf file exported from sketchup, and it worked, with one big difference: faces are not retrieved
                                  here is the dxf file, if you want to try with another CAD software
                                  flattened scaffolding dfx
                                    glro
                                    I think...
                                    yes, this would probably if objects within the global component would be alone (stray?)
                                    but if the objects within the global component, are components themselves, nothing is merged
                                      glro
                                      by scaling to 0.0001, the visible entities are kept visible
                                      • JQLJ Offline
                                        JQL
                                        Scaling to 0.0001 will keep this as a 3D that looks flat so face "draw order" comes from the 3D itself... I can understand that.
                                        It's pretty interesting that scaling it to 0 and then scaling it back up pops up the full model!
                                        I could see that as a very interesting presentation tool by itself.
                                        Imagine a flat plane with a google map in it, and then, suddenly a building and terrain start poping up from it... That would be very cool.
                                        But what you're saying is that if you export to dwg/dxf and open it back in sketchup, sketchup convert's it into 2D data, though it looses faces? Then all the invisible faces become visible and if I'm exporting a roof view I will probably see all the floors beneath it... That wouldn't work though what you have still looks very good.
                                        There is also an unmentioned issue that relates to camera, this only works in orthogonal projection mode, but I really can live with that as that is the kind of drawings I am after (2D orthogonal projections of the model.)
                                        Though I understand the potential of the concept there are also other questions envolved like defining axis, sections and export to a skp model per scene:
                                        1. I can imagine that definnig axis by scene camera or by a section plane is probably something trivial for plugin developers;
                                        2. Having a section can be a bit more troublesome though as there will be many sections in the model. The way you describe your plugin to work right now, it would probably be a matter of copying the whole model and a given section into a component. Then use the section inside that component to do something like Zorro2 plugin and slice the component through the section. This new component, that would now be sliced, could be scaled flat;
                                        3. Then the matter of exporting this flat component to an external file, would probably be easy too.
                                        So the problem I see is, still only one, the component isn't trully 2D but close to 0 thick:
                                        • so it probably isn't fast to work with;
                                        • it's probably innacurate to work with;
                                        • and it probably creates a lot of issues when exporting to standard industry formats like dwg/dxf/dwf.
                                        I'm thinking though, that if there was a way to make the component true 2D, it would be so lightweight and easy to use, that we could even not export it at all. It could be inserted in a new layer visible only in a new scene and both layer and scene could be named after the existing scene with a suffix/prefix related to the plugin:
                                        • "Scene 1" - Original model view;
                                        • "2D Scene 1" - Copy of Original model view, where only the 2D flat component is visible.
                                        glro, I'm sorry if I'm sounding rude by saying all this so bluntly, but the fact is that I really appreciate all the input so far, and I do think the potential of this plugin is huge!
                                        www.casca.pt
                                          Charlie__V
                                          Have you tried using section cuts in SU......up to the limits of what you desire to show in LO/ 2D.
                                          (think from the "back side" of the model)
                                          IOW:
                                          Think old western town movie prop. (facades only)
                                          I modeled a small developement a couple years back and to get a "street view" in 2D I used a section plane from behind to limit the info LO had to calculate. (I recall this working well)
                                          Charlie
                                            glro
                                            no, it has to be scaled at 0.0001, otherwise it doesn't pop up back
                                            no
                                            if it is scaled to 0.0001 exported to dxf imported to sketchup, faces are erased, but the model is still 3d, you can unscale it
                                            if it is scaled to 0.000, only then faces are erased and it is converted into 2D data
                                            1. Having a section can be a bit more troublesome though as there will be many sections in the model. The way you describe your plugin to work right now, it would probably be a matter of copying the whole model and a given section into a component.
                                            there is no plugin, only the few lines of code i pasted in the thread;i have not tried this code when a section plane is in the model.
                                            1. Then the matter of exporting this flat component to an external file, would probably be easy too.
                                            i don't see why being close to 0 would be a problem
                                            the flattened component is as accurate as possible, in 2D
                                            the size of the flattened component is not an burden for the graphic card, since it is flat, it is quicly shown; it can be for the RAM
                                            i have just followed your idea, because i was curious, and it has been fun so far; but i don't have much time to spend on it.
                                            if you send a model with a few scenes set as you wish them to be flattened, with or without a section plane, i can make a try, copy each scene flattened to an individual sketchup file so you can check the result
