    Annoying axis
    9 Posts 3 Posters 868 Views 3 Watching
      matsuo_lano
      Hi all!
      In the previous version(s) of SketchUp (currently using v2016) I had no trouble aligning the axis as displayed on the attached image. How can I achieve this with the current version? I tried using 'alt' to lock the axis, rotated my model and view, drew construction lines to assist, all without luck!
      You try to rearrange me 'till I'm sane
        Could you upload the component SKP?
          matsuo_lano
          As requested!
          2016 format
            So you want the component's axes oriented as in your first screen shot? The solid axes can't be positioned exactly as you've marked them in the screen shot but you can set them like this:
            Simply right click on the component, choose Change Axes and position them as desired.
            click to see animation
            • BoxB Offline
              I don't quite understand what issue you are having, perhaps I misunderstand your problem.
              Edit; I see from Dave what you want.
                matsuo_lano
                I'm using Component Stringer by Chris Fullmer, and someone made me a tutorial. One step requests me to align the axis as displayed, or else the placement of the components will fail.
                  matsuo_lano
                  This is the mentioned tutorial
                  copypath_V6.skp
                    If you look at the axes for that component, you'll see they are aligned exactly as I showed in my previous post.
                      matsuo_lano
                      My bad πŸ˜‰
                      It almost worked, two segments are out of alignment. I can fix those by rotating them
                      Thanks!!
