    Nested dynamic components
    Scheduled Pinned Locked Moved Dynamic Components
    31 Posts 4 Posters 16.4k Views 4 Watching
    • newnoobN Offline
      newnoob
      I still have problems after setting the axes which I can not explain myself.
      I've created a mother component in which I've nested two sub components of the same shape.
      The mother component can rotate between -90° and 0. One of the nested components can also rotate (around it's own set axis) between -90° and 0
      As long as I do not rotate the mother component the nested component just does what is should do which is rotating between 0° and -90°.
      But the problem starts as soon as I have rotated the mother component to -90°. When the mother component is rotated at -90° the nested component is behaving strangly. Instead of rotating to -90° and 0° it is sort of jumping to -90° and then bouncing fast back.
      I don't have a clue.
      grau weiß nested dynamic components versuch.skp
      • JQLJ Offline
        JQL
        Here it is:
        JQL grey and white Folding door DC.skp
        www.casca.pt
        Visit us on facebook!
          Garry K
          JQL
          If you copy, paste and rotate this DC and then use interact then it bounces back to the same plane as the original.
          You need to nest it one level deeper.
          • JQLJ Offline
            JQL
            Thanks Garry!
            I know that but I thought I was giving away too much in one time and this doesn't help learning. I was hoping that issue could be something asked later by anyone interested or even better, the issue could be solved alone.
            A step at a time, each step requiring the next...
            There are even more issues there waiting to be found.
            www.casca.pt
            • newnoobN Offline
              newnoob
              Thanks for the help JQL! I really appreciat it. (unfortunately I can't open your file with my SU Pro 2014) However I understand nuts.
              I have already a problem to understand what it means when you use symbols like ! and * in
              =Mother!Rotation-90*
              or
              RotZ = Rotation*90
              A principial logical problem which I have is that in my understanding the white component is only moving around axis z but the grey component is moving around axis z AND is sliding at the same time on axis x.
              But there is nowhere something refering to - change position on axis x - for the grey component. There is only RotZ = other!Rotation-90* - It does not seem reasonable to me that this is enough when the grey component is ALSO MOVING on axis x.
                Garry K
                Have you gone through this
                https://help.sketchup.com/en/article/115544
                Notice the axis:
                And here is the formula. Think of it this way
                The top most component (Mother) gets rotated 90 which rotates both the grey and the white panels.
                Then rotate the gray one -180
                  Garry K
                  Mother!Rotation refers to Rotation variable in Mother (should be named state)
                  On Click sets Mother!Rotation to either 0 or 1
                  RotZ formula Rotation*90 will be 0 when the state is 0 or 90 when the state is 1
                  RotZ in grey panel also references the variable Mother!Rotation and therefore it's value is either 0 or -180
                  Pretty simple actually
                  • JQLJ Offline
                    JQL
                    As Garry says, you have to learn the basics first.
                    Mother!Rotation is the "Rotation" attribute defined in "Mother" component. The idea is that you can reference attributes that exist in parent components or components nested in the same level.
                    When you want to do that, you simply click on the attribute you want to use, from the ones being shown:
                    1 - Edit the formula for RotZ inside the grey component;
                    2 - Start by typing "=";
                    3 - Then click on Mother's "Rotation" attribute;
                    4 - And sketchup will autocomplete "Mother!Rotation" inside the formula.
                    www.casca.pt
                    • JQLJ Offline
                      JQL
                      Garry, I'm know about your plugins but I'm not familiar with them as I never tested them...
                      When you say that you're creating your DC's from ruby, are you creating them from scratch from there or are you picking up some existing component template and filling it with stuff using ruby?
                      www.casca.pt
                        Garry K
                        It is all Ruby (except for door handles).
                        I have web dialogs for parameters. Cab Maker for instance has 8 tabs and around 240 graphics which change for each parameter. Lots of enabling / disabling of parameters depending upon what you select. Choose a library template (just a small text file) and I go read in the data and update the web dialog.
                        I think it is a much better work flow and the resulting skp is kept down in size. This way you can have 100's of choices for textures but I only load in the ones you want to use. This also means that most of the parameters are virtually infinitely sizeable and can be combined many many ways.
                        The only place that I use dynamic attributes is for doors opening / closing and drawers opening / closing.
                        • JQLJ Offline
                          JQL
                          That's really cool Garry! I'm amazed at what you achieved there. And it seems you have the same thing for doors and windows?
                          www.casca.pt
                            Garry K
                            Yes for doors, I'm working on windows and on a wall maker.
                            As you probably guessed - that bifold came out of my door maker.
                            • JQLJ Offline
                              JQL
                              That sort of thing interests me a lot more than cabinets.
                              You're talking about walls doors and windows all in the same plugin?
                              www.casca.pt
                              • newnoobN Offline
                                newnoob
                                Garry and JQL thank you for your extensive answers. I'll process them tomorrow.
                                Thanks to the explanation:
                                it makes now perfectly sense to me.
                                  Garry K
                                  JQL
                                  3 separate plugins.
                                  • jujuJ Offline
                                    juju
                                    @garry k said:
                                    JQL
                                    3 separate plugins.
                                    How's the window plugin coming along Garry?
                                    • newnoobN Offline
                                      newnoob
                                      @ JQL
                                      I've just checked out your fb-gallery and I like your attic renewal, the material choice and integration of old stuff which was already at the attic before the renewal gives it a warm and cosy feeling. I also like pure minimalistic designs where warm wood tones are mixed with grey concrete tones, like your office, this is like wood and stone. This in combination with some plant green always works for me. Furthermore I like the tiny garden. I am interested in the utilisation of small spaces, like micro houses, micro homes, capsule hotels.
                                        Garry K
                                        juju
                                        I haven't got very far with the window plugin. I have been concentrating on a wall plugin - then I'll go back to the window plugin.
                                        • newnoobN Offline
                                          newnoob
                                          Ok, I think I got it. I had a problem to understand what relates to what.
                                          Which purpose has:
                                          Custom
                                          Rotation 0
                                          The sole purpose of it is to display if the the state of onclick is set to 0 or 1 - is it?
                                          • JQLJ Offline
                                            JQL
                                            @newnoob said:
                                            @ JQL
                                            Thanks newnoob...
                                            We are working on a new site and we have some new projects on that line, so keep in touch!
                                            www.casca.pt
