    [Plugin] Wood working rubys Update
    19 Posts 15 Posters 27.1k Views 15 Watching
      dedmin
      @jhoutman said:
      Attached is a zip file that is an update to the woodwrk.rb. It now includes ktkoh mortise tenon ruby. In the directory woodwrk2, is a readme.txt. One must copy the runwoodwrk.rb into the plugins directory. This file can be edited to delete out any ruby's that you don't want etc.
       :+1:  :+1:  :+1:
        madhav
        thanks mate πŸ‘
          mgfranz
          I cannot get the plugins to work, I installed the directory woodwrk2 to the plugins directory, and copied the runwoodwrk.rb file to the plugin directory but nothing shows up.
          One thing that does concern me, the runwoodwrk.rb states that sketchup.rb is required, I don't have that .rb in my plugin directory, but no errors are thrown either.
          "If you like what you do, it will never be work..."
          In memory of Sam Maloof, 1916-2009
            I used to have this plugin but deleted it because it doesn't really work for me with my work flow. Have you checked under window>Preferences>Extensions to see if there's a box that needs to be checked?
            As to sketchup.rb, it is in the Tools directory not in Plugins so you do have it.
            Have you seen the Wudworx plugins for both mortise and tenon joinery as well as dovetails?
            • E Offline
              ettengerg
              How do I use the drill script to put a hole exactly where I want it. I typically use the guidelines to locate the
              Center but the script gives me an invalid point error.
              • designerbursaD Offline
                designerbursa
                Optimization of the plates that make up the dimensions of furniture panels, could you make a plugin?
                  tashnag
                  Create board and resize board wont work for me.
                  I had the original version from a different post, and they worked fine, but had issues with the DADO.
                  Now dado works fine but create and resize board dont work. Any ideas why?
                    tashnag
                    Was there ever an answer to this?
                    thanks
                      AMIII
                      Hi There,
                      Just installed this in Sketchup 2015 and can't seem to get to work. Followed the instructions below
                      1. Delete woodwrk.rb (if you have it) from Plugins folder.
                      2. Copy woodwrk2 folder into your Plugins folder
                      3. Copy runwoodwrk.rb in woodwrk2 folder into Plugins folder.
                      4. Edit runwoodwrk.rb to delete or comment out those portions that you don't want.
                      One thing I did notice is the it plug in is not showing up in Preferences -> Extensions
                      Has anyone had luck with this one in 2015 ?
                      AMIII
                        akigrimm
                        Does not seem to work for me. In SU 2016 I did put the plugin under USER application Data, since I understand this is where the plugins are located now. The dialog box opens i enter all the specs but no component is drawn.
