Sketchup 2013
I am using Sketchup 2013 version only.
When downloading models from the warehouse, most models are made by newer versions and do not work on mine.
Is there a seperate warehouse for older models, or settings in warehouse?Thanks in advance
Just get a copy of Make 2016 to open the file and save it in 2013.
When you click the download button it gives you a choice of SU version. Click the one that works for you.
Yeah Box thank you.
I found this out later also. Good tip.
I will for sure also try pbacot's idea to get Make 2016. -
You should also read at this link regarding SketchUp 2013.
