A plugin for quickly distributing objects in a 2D space?
I use Sketchup making seating arrangements for theater seating and banquet seating in a convention hall. To do this now I have my chairs and tables in groups and I use the copy tool to place them out evenly in one dimension and then copy that array in the other. What I would like though is a tool similar to the tool for creating tables in word (see image). What I imagine is a tool that lets me draw a shape, either a simple rectangle or even better, a random shape that the plugin would populate with my objects according to my specifications.
The tools I have found so far distribute objects either randomly for such things as people or trees, or perfectly even. For my theater seating however, I put my chairs next to each other along the row but leave a space so that people can reach the chair and sit down in the other axis. (see image)
Is there such a tool out there?
/Jonas
Maybe a dynamic component would help.
Or the Skatter plugin ($)...
Or the extremly versatile genious Randomly Replace Components by Sdmitch!
(2D or 3D)
(for me the best
Thank you so much for this suggestion. I quickly discovered how to build a dynamic component that creates copies in one direction using the scale tool. Any suggestions of how to use the same trick on the same components in the other directions? I would think that the "copy" counter will only be helpful in one direction. Is there a way to nest a dynamic component to accomplish this?
