    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 957.7k Views 172 Watching
      Anton_S
      Version 0.5.0 has been released!
      Update change log: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
      Download available in first post.
      • F Offline
        faust07
        Great news, Anton. Short question: I want this Topic not bloat with simple examples and tests. Should I better open a new topic as entitled "MSPhysics examples and tests"?
          sekramer10
          Hello,
          Does this work on SU 2016 64bit ?
            gepponline77
            Hi, I'm just trying it on SU2016 make. It all seems to work but i cannot understand how to use piston or servo motor or motor.
            If i press UI button i expect a window with interactive controller to appear but it's not, or better, a window appear, with many tabs, but the joint tab is empty when in play mode.
            So, how to move an object connected to a servo joint?
              PituPhysics
              • Drawing 1 group.
              • Create a Joint.
              • Select the "Joint Connection Tool" (red/green, rotary arrows)
              • Click onto group
              • Hold the left Ctrl / Shift
              • Click onto Joint
              • Done!
              /OR/
              • Drawing 2 group.
              • Click on one of them. Be it an "A".
              • Create a Joint on "A" group.
              • Show UI, Remove the check mark from the "Connected Collide" check box.
              • Controller:
              righty * 10 /OR/ rightx * 10 for right arrows. 10 is the velocity.
              key('up') /// key('down') /// key('left') /// key('right')
              lefty /OR/ leftx for WASD
              key('w') * 10 for "W" button on keyboard
              key('lbutton') for left click on mouse ( lbutton, mbutton, rbutton )
              get_var('variable') for script.
              • Select "A" group and joint. (Hold the left Ctrl OR Shift)
              • Right click / Make Group
              • Select "Joint Connection Tool"
              • Select "B" group
              • Hold the left Ctrl OR Shift and click onto Joints.
              • Done!
              Not complicated.
                gepponline77
                Maybe I didn't explain well my problem.
                I know how to use joints!
                The problem is that if use hinge, or motor or slider, all work well. I simply have to drag my object to move it.
                If i use piston or servo, in Sketchyphysiscs, when i press play, a popu control panel with a slider appear and it allow me to mov emy object.
                With MS, nothing appear and i can't move my object
                  PituPhysics
                  I'm sorry, I misunderstood. In the MSPhysics at present there is no "Controller Panel".
                  Anton is likely to put into it as well. For the time being, you can control the keyboard.
                  • soloS Offline
                    @sekramer10 said:
                    Hello,
                    From the requirements section of the website:
                    http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/README.md
                    SketchUp 6 or later. SU2016 64bit is recommended!
                      gepponline77
                      Could you please explain me how?
                      For example, if i place a servo joint connected to an object, what should I do to move that object in play mode?
                        PituPhysics
                        Write this codes into Joint / "Controller":
                        rightx         Left - right arrows
                        righty         Up - down arrows
                        leftx          A - D
                        lefty          W - S
                        key('1')       0-9
                        key('a')       A-Z keys
                        key('enter')   All the Windows function keys. (lctrl, rctrl, space, backspace, etc...)
                        key('numpad1') 0-9 Right numpad keys
                        key('+')       Numpad operations (+, -, *, /)
                        key('lbutton') Mouse keys (mbutton, rbutton, xbutton1, xbutton2)
                        get_var('variable')   ... for script.
                          gepponline77
                          Sorry but for me is really unclear.
                          What should i have to write?
                          Controller field is a single line field.
                          So eventually i can insert only a row of what you have write above.
                          I paste "rightx Left - right arrows" in the controller field, press the play button and press left and right arrow but nothing happen.
                          Of course is my fault.
                          But could you gave mme an example step by step of using a piston joint?
                            PituPhysics
                            I made an test model: piston test.skp
                              PituPhysics
                              I made an test model: [attachment=0:1hwdkrag]<!-- ia0 -->piston test.skp<!-- ia0 -->[/attachment:1hwdkrag]
                              Succeeded solve?
                              • F Offline
                                faust07
                                Very good example and important notes above. It works.
                                  Anton_S
                                  Yes, I can see that you already did. However because there aren't many tutorials on how to use MSPhysics and because its generally not done, the topic could be quite empty for a while, but don't worry once the project is done, I'm gonna help you fill it in.
                                  Yep, I'm planning to put in all the feature of SketchyPhysics and more.
                                    gepponline77
                                    Thanks PituPhysics, now I can move my objects.
                                    Still some doubts about parameters (like controller and min-max position)
                                    But it start to be clearer
                                      pnickles
                                      SU2016 Plugins folder location:
                                      C:\Users[USERNAME]\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                                        PituPhysics
                                        Just write this: %APPDATA%\SketchUp\SketchUp 2016\SketchUp\Plugins
                                        The USERNAME is will be automatically detected. Or here is shortcuts 2014+ in zip archive:
                                        Plugins Shortcuts.zip
                                          Anton_S
                                          Announcing 0.6.0. See change-log here: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                                          • F Offline
                                            faust07
                                            Usefully new options, functions and joints!
                                            What is meant with the Sliders Control Panel? A control panel for the slider joint in MSPhysics UI or a Joint Controller Panel with slider input similar to SP (couldn't find it...)?
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 46
                                            • 47
                                            • 39 / 47
