    House builder wall tool stopped functioning
    extensions
    8 Posts 3 Posters 1.9k Views 3 Watching
      denali
      hey all! so I am green green green to this, but I did manage to get the house builder up and running on my SU but after building the floor on my building and then 2 walls, the wall tool just stopped working.... i open it enter my info and click ok and it doesn't give me any options for the wall location. Just stays on the previously used tool/function. glitch? easy fix I don't see? I tried locating the extension in my program files but couldn't locate them and I tried reloading the .rbz folder to no avail. any ideas? I am using the 2016 version btw. was having a blast until this happened haha thanks so much for any help!
      ian
      • Bob JamesB Offline
        Bob James
        Works fine for me in SU16 except for:
        1. The dialog box opens as just a bar which needs to be stretched out to see the input options
        2. The corner options pictures do not appear when selecting a corner type
          denali
          hmm interesting I'm thinking I will have to uninstall and reinstall both sketchup and the house builder extension. the floor and everything else works just not the walls... or i can manually draw them for this project haha well thanks for your time πŸ˜„
          • sdmitchS Offline
            sdmitch
            Face to Frame is part of HouseBuilder???
            FYI. the latest version on my blog does have graphical depictions of the exterior corner selected.
            http://sdmitch.blogspot.com/
              Bob James
              My apologies, denali. 😳 Since I use face-to-frame for my house building, I jumped in before I thought about it. Sorry.
              sdmitch, I am using the version Updated: 2013-04-29 14:45:00 downloaded from SketchUcation. I'll get the latest from your blog.
                denali
                i thought it looked different, but i just questioned if i was saying i had the right thing. I tried uninstalling and re-installing SU but it still isn't working. Either the wall tool or the gable wall tool, but the floor and roof tools work great. the 2 walls i built i can modify and install windows in and everything but it won't create them. Must be a glitch in the .rbz I downloaded but I can't find the housebuilder portion in the SU program file to delete it and try again. Maybe I will try deleting it from the downloads folder and see if that helps. πŸ˜„
                  Bob James
                  In case you need to download it again:
                  @tig said:
                  Over the last several months there has been considerable confusion about 'House-Builder' versions metric/imperial...
                  Here are the [current] definitive links...
                  Metric:
                  http://sketchucation.com/forums/viewtopic.php?p=519210#p519210
                  Imperial:
                  http://sketchucation.com/forums/viewtopic.php?p=556663#p556663
                  And it works
                    denali
                    thanks bob! i had tried reloading it before, but this time it worked! up and running!
