    Warning messages in console at start up
    13 Posts 4 Posters 3.6k Views 4 Watching
      It it's encrypted it will be a pain to track down.
      But initially use something like Baregrep.
      http://www.baremetalsoft.com/?app=BareGrep%26amp;ver=3.50a%26amp;build=2006-11-02
      Paste your Plugins folder path into it and limit it to look through *.rb
      Search for a string like "fileutils".
      See what comes up if there's a "load 'fileutils'" in the list, then that's the culprit...
      I don't see this error.
      I just grepped all of the zillions of rb's [loading and otherwise] that I have, and there was nothing untoward - but if it's in an rbs it will be un-greppable anyway !
      Have you recently installed some extensions ?
      • PixeroP
        Pixero
        After manually removing the Corona files the warnings are gone.
        • PixeroP
          Pixero
          Thanks. This is what BareGrip found:
          SketchUcation\Data\Rubyzip\zip.rb	-	1 match in 59 lines.
          SketchUcation\Data\Rubyzip\zip.rb	4	require 'fileutils'
          TT_Lib2\c_extension_manager.rb	-	3 matches in 197 lines.
          TT_Lib2\c_extension_manager.rb	165	        require File.join( path, 'thirdparty', 'fileutils.rb' )
          TT_Lib2\c_extension_manager.rb	168	          require 'fileutils'
          TT_Lib2\c_extension_manager.rb	175	          # This cause the fileutils to fail to load. To work around this the
          TT_Lib2\thirdparty\fileutils.rb	-	21 matches in 1,521 lines.
          TT_Lib2\thirdparty\fileutils.rb	4	# = fileutils.rb
          TT_Lib2\thirdparty\fileutils.rb	602	  # For fileutils.rb, this vulnerability is reported in [ruby-dev;26100].
          TT_Lib2\thirdparty\fileutils.rb	1272	    $fileutils_rb_have_lchmod = nil
          TT_Lib2\thirdparty\fileutils.rb	1276	      if $fileutils_rb_have_lchmod == nil
          TT_Lib2\thirdparty\fileutils.rb	1277	        $fileutils_rb_have_lchmod = check_have_lchmod?
          TT_Lib2\thirdparty\fileutils.rb	1279	      $fileutils_rb_have_lchmod
          TT_Lib2\thirdparty\fileutils.rb	1290	    $fileutils_rb_have_lchown = nil
          TT_Lib2\thirdparty\fileutils.rb	1294	      if $fileutils_rb_have_lchown == nil
          TT_Lib2\thirdparty\fileutils.rb	1295	        $fileutils_rb_have_lchown = check_have_lchown?
          TT_Lib2\thirdparty\fileutils.rb	1297	      $fileutils_rb_have_lchown
          TT_Lib2\thirdparty\fileutils.rb	1382	  @fileutils_output = $stderr
          TT_Lib2\thirdparty\fileutils.rb	1383	  @fileutils_label  = ''
          TT_Lib2\thirdparty\fileutils.rb	1386	    @fileutils_output ||= $stderr
          TT_Lib2\thirdparty\fileutils.rb	1387	    @fileutils_label  ||= ''
          TT_Lib2\thirdparty\fileutils.rb	1388	    @fileutils_output.puts @fileutils_label + msg
          TT_Lib2\thirdparty\fileutils.rb	1450	    @fileutils_output  = $stderr
          TT_Lib2\thirdparty\fileutils.rb	1451	    @fileutils_label   = ''
          TT_Lib2\thirdparty\fileutils.rb	1475	    @fileutils_output  = $stderr
          TT_Lib2\thirdparty\fileutils.rb	1476	    @fileutils_label   = ''
          TT_Lib2\thirdparty\fileutils.rb	1501	    @fileutils_output  = $stderr
          TT_Lib2\thirdparty\fileutils.rb	1502	    @fileutils_label   = ''
          I don't think it's Thomthoms plugins causing it though.
          I have an idea that it might be the Corona beta but it has a .rbs.
          I'll try to remove it and see what happens.
          Great search tool by the way TIG.
            I don't think TT's Lib is to blame either - that 'require' is called using one of two paths, depending on the Ruby version - it comes shipped with SketchUp in newer versions, but is supplied by TT Lib is older SUp's Ruby < 2 ...
            So as you say, I would suspect that this 'Corona' beta RBS generated by the EXE conceals something like a load 'fileutils.rb' [or even a path to a separately shipped version it is requiring without checking it is already loaded...], when a simple loaded/version check and/or replacing it with require 'fileutils' is all that is really needed...
              Our posts crossed...
              Can you email the Corona developers and tell them of their problem...
                driven
                @tig said:
                ... but if it's in an rbs it will be un-greppable anyway !
                can it not be found by looking for what's loading around it?
                all = $"
                all.each_with_index{|path,indx| p all[indx-3..indx+3] if path.include?('fileutils')};nil
                on mine it shows /SKUI/core.rb just before and /FreeDXF/freedxf.rb just after...
                  @driven
                  Maybe, a clever idea...
                  Perhaps @Pixero can test it...
                  • PixeroP
                    Pixero
                    Not sure how to use that code but its definitely Corona beta since it returned when I moved the files back into plugins folder.
                    I pasted the code in the post above into the console and this is what I got:
                    ["C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/delegate.rb", "C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/singleton.rb", "C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/platform_specific/etc.so", "C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb", "C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/tmpdir.rb", "C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/tempfile.rb", "C;/Users/Jan/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/dos_time.rb"]
                    I'll let them know of the problem.
                      Looks like @driven's cunning-plan didn't work...
                      Tell the authors - it'll be easy enough to correct it...
                        driven
                        it shouldn't do any harm as it points the standard library instal both times...
                        [unlike RubyZip that someone hides in their Plugins folder....]
                        @Pixero, did you try that when Corona was installed?
                        it seems odd that it's seen on Start Up and rises an error, but it's not in the loaded files array...
                        • PixeroP
                          Pixero
                          Yes I tried it with Corona installed.
                          Now I've posted on their forum so I guess it's up to them to fix it.
