    Introducing Viz - parametric modeling for SketchUp
    extensions
    85 Posts 21 Posters 32.9k Views 21 Watching
    • F Offline
      fluid
      We just released an early beta of Viz, our parametric modeling extension for SketchUp.
      If you want to give it a try, you can download it here.
      Please keep in mind it's an early beta, it might have bugs, and it supports only SketchUp 2013/2014/2015/2016 on Windows.
      Any suggestion or feedback is welcomed.
      [flash:2jknqt9v]https://www.youtube.com/v/3ZBGbHVPfRE[/flash:2jknqt9v]
      http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/02/Revolve1-1030x640.jpg
      http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/02/Revolve2-1030x640.jpg
      http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/02/Terrain-1030x640.jpg
      http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/02/Nodes-1030x639.jpg
      http://www.fluidinteractive.com/wordpress/wp-content/uploads/2016/02/HemiSphere-1030x640.jpg
      • PixeroP Offline
        Pixero
        ๐Ÿ˜ฎ โ˜€ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
        OMG!
        I love you!
        ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
        One of my highest hopes for SU comes true.
        • PixeroP Offline
          Pixero
          Ouch.
          I get a instant bug splat when clicking on "Start Viz" in a empty scene.
          I'm on SU 2016 Windows 8.1 64 bit.
          • JQLJ Offline
            JQL
            I'll be damn!... I love you too... I'll try bugsplatting too...
            www.casca.pt
            Visit us on facebook!
            • jiminy-billy-bobJ Offline
              jiminy-billy-bob
              ๐Ÿ˜ฎ ๐Ÿ˜ฒ
              • JQLJ Offline
                JQL
                I had the same bugsplat as Pixero.
                Win 10 SU 2016 Pro 64bit
                EDIT: I still love you... but I hope you can fix it!
                www.casca.pt
                  Works fine for me ๐Ÿ˜„
                  Better if you have 2 screens! ๐Ÿ˜‰
                  Window 8.1 64 bits SU 2016 Make
                  Now a little new headache for make something with nodes mood! ๐Ÿ’š
                  • F Offline
                    fluid
                    Just uploaded a new version, fingers crossed...
                    • JQLJ Offline
                      JQL
                      Playing with it! You can uncross your fingers! Going to rewatch the videos so I can know what to do with this 1m cube
                      www.casca.pt
                        New version is always living! ๐Ÿ˜„
                        But nodes are not an evident thing! ๐Ÿ’š
                          cesaro36
                          ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ Awesome!
                          • JQLJ Offline
                            JQL
                            [attachment=0:lkd2v9s1]<!-- ia0 -->alwaysfun.jpg<!-- ia0 -->[/attachment:lkd2v9s1]
                            Yup, nodes names are hard to read and relate to functions.
                            I was searching for an array tool and I found a lot of array functions that get the max and min value of an array, but I had an hard time finding the array.
                            www.casca.pt
                              Nodes is a very powerful work function but no sure that is the more simple thing!
                              There is so much connections, possibilities, that is a real jungle! ๐Ÿ˜„
                              That is in fact an hidden coding! ๐Ÿ˜‰
                              Grasshopper is the Rolls Royce of that! The Bible ๐Ÿ˜„
                              • PixeroP Offline
                                Pixero
                                The version 1.02 works but I'm having some problems getting the window to stay on top of SU.
                                Sometimes it refuses and ends up under the SU window which is a bit frustrating.
                                A larger/re sizable node window and some node categorization would be great but I guess it's coming?
                                More nodes wanted too. Different noises and cellular patterns for example.
                                Is there a way of using an image as input? For for example height based on gray scale values.
                                And curves. We need curves.
                                Any way of creating custom nodes apart from functions?
                                I like that the nodes have built in value sliders so you wont need to create every single input node by hand. ๐Ÿ‘
                                Are there cases where a output node (Geometry sink) wont be used? If not maybe it's a good idea to have the output node always in the editor?
                                Looking good and very fun to work with. Great job so far. ๐Ÿ˜„
                                • PixeroP Offline
                                  Pixero
                                  Another thought, what if there were categories like "Math" or "Array" that incorporated all/several math functions and let you choose which function from a drop down menu on the node as a way of having less nodes to search through.
                                  That way it would also be easy to quickly try different nodes like "add" or "multiply" to see the result.
                                  Is it possible to have "triangulate" with options to the direction of the triangulation?
                                  Also it would be great if it supported Thomthoms Quads for easy texturing.
                                  • PixeroP Offline
                                    Pixero
                                    I have a feeling a Beta forum would be a good idea as there probably will be lots of questions and suggestions. Better to have several topics than just one.
                                    • alexschreyerA Offline
                                      alexschreyer Extension Creator
                                      Superb! Can't wait to try this out.
                                      Author of "Architectural Design with SketchUp":
                                      http://sketchupfordesign.com/
                                      • JQLJ Offline
                                        JQL
                                        That would be my main suggestion and I think Rich could set you up here.
                                        Following on the slider's subject, I like them but they return huge values.
                                        I have a 1m cube and translation slider slides easily up to 14000m so values ranging 1m 10m or 0.5m are impossible to tune with the slider.
                                        I also agree on categorization, and I think it would be worth it to have some icons in the future as people doing graphic modelling, could probably relate nicelly with that.
                                        I'm using Substance Designer on a regular basis and visuals of their nodes work nicelly there.
                                        They have color separation by set of nodes.
                                        In this case I can't tell yet what categories there are, but some are geometry creators, some are modifiers some are functions, so there should be something to start with.
                                        Also, on the node workflow itself, something I feel it's lacking is a faster way to replace inputs. If I drag a vector into an input that is already used it does nothing and I would expect it to replace it.
                                        Also changing a big amount of output lines from one node to another node would be great.
                                        Here's a gif for clarifying what I'm talking about:
                                        www.casca.pt
                                        • F Offline
                                          fluid
                                          Thanks for all the feedback! Rolling up the sleeves for next version...
                                          There is a lot of new nodes to be added, and node categorization too.
                                          @Pixero:
                                          • What do you mean for "Any way of creating custom nodes apart from functions?"
                                          • Look at the Fx node for math for a list of math functions
                                          • Image inputs will be added soon
                                          • There are cases when you need multiple geometry sinks, and cases when you need none, for now probably it's a good idea to let the user choose
                                          @JQL: we'll add sliders so you can set the range/numeric type, as well as a way of quickly replacing connections
                                            Will be a free product ?
                                            • 1 / 5
