SU: styles bugged
For some reason, some of my SketchUp styles are bugged: sketchy edges, straight lines and the style builder competition winners.
I slightly recall I had the same problem before but can't remember what caused it and how to fix it.
Anyone have a clue?
Turn off Use Maximum Texture Size. I think your styles will look fine, then.
You're totally right. Thanks Dave!
You're welcome.
I periodically run into the same thing after I've had Use Maximum Texture Size enabled for a project and forget to disable it again. I rarely need it enabled but once in awhile it comes in handy.
