    Line length on circle scaled to ellipse is very wrong
    48 Posts 12 Posters 7.3k Views 12 Watching
    • bazB
      baz
      @box said:
      Use elastic next time Baz then you can get several measurements in one.
      Which was exactly where I came in...
      ... everybody chill, it's solved in at least four or five ways, go back to your lives!
      Thank you all for all your obsessive help. β˜€
      Baz
      PS: It's still a bug. πŸ˜›
        At the maximum display precision of SU with Caul program
        2118.238356
        Nurbs Prog 2118,2799 332 against your theoric 2118.2799 288074484
        Sketchup gives 2118,27 6442 with circle 1000 segments!
        For Baz πŸ˜‰
        http://i2.cdscdn.com/pdt2/4/1/0/1/700x700/auc3760180275410/rw/loom-bands-sachet-300-elastiques.jpg
          mac1
          conjuate ellipse.skpBaz: as noted the model was just proof of concept so not worried about segments yet. the 10X5 (semi) " better model reports 24.227n inches for 1/2 , has only 72 edges and looks very nice.
          Some way the number I posted above is not correct so forget about running you calculation. BTW that brings up a question. There are several eliptic intergals and the corresponding polynominal curve fits to those. Do you know which type your equation is for.
          • bazB
            baz
            @mac1 said:
            [attachment=0:1ln04vy0]<!-- ia0 -->conjuate ellipse.skp<!-- ia0 -->[/attachment:1ln04vy0]Baz: Do you know which type your equation is for.
            Sorry Mac, I have no idea.
              mac1
              bAZ;
              Complete integral of second kind required for ellipse;
              For drawing Wikipedia best for you. The have an animated approach but call it parallelogram approach, mine almost the same but equal for all practical purposes. Will find link for you https://en.wikipedia.org/wiki/Ellipse
              I used online calculator & my length is with .02+% of what they calculate.
              I only use 4 points for may drawing then did mirroring to get 1/2. Most of curve was made with Bezier cubic spline Order 3 with seven segments. The scale and my drawing over lay very close.
              I think know what problem is but need more test. Think may be adding segments ad infinitinum(sp?)my not be the way one wants to go. As you know SU has two sided faces so deleted duplicate vertices so could see what scale does and raised some questions I want to investigate.
                mac1
                160217.6 ellipse test.skp
                @caul said:
                @pilou said:
                And what is its result in this case ? (Ellipse 400*900)
                2118.2799288074484
                The result above is for major = 900, minor = 400, if your input refers to the semi axes multiply the result by 2.
                This is the correct value irrespective what Op thinks. On-line calculator spits out same number;
                In addidition I used two different methods to model ellipse ( 10 x 20 ") to verify the model approach SU uses is ok ( Two circle and parallelogram, plus the one noted above but it is slight mod of parallelogram ) methods;
                Attached the result I get for the 400x900 mm ellipse. The actual value is as above and I get 2112.236 => Good enough for me. I get same result if curve is exploded or left as curve. What I did seem to find is welding before scale helps and you have to be very careful to lock axis direction of scale.
                  Why not increase number of segments of arc circles for have a better precision?
                  • bazB
                    baz
                    You guys really have to get out more πŸ˜„
                      mac1
                      Check my very first post you can make the figure with 75 segs very nicely. I do not subscribe to philosophy more is better. For the OP use one would probably want>=10% etc margin on veneer one buys.
                        you right but as we as a computer under the hands it's funny to give it maximum to eat! πŸ˜‰
                        • BoxB
                          Can someone calculate the optimum sinewave formation for each of the individual nine tails used to flog this particular dead horse, please show all your working.
                          • 3 / 3
