    How to fillet multiple surfaces
    14 Posts 4 Posters 1.9k Views 4 Watching
    • G
      gepponline77
      Sorry, I've posted the wrong draw where i was trying to use the solid toolset.
      This is the correct one.
      I want to round only the intersections between the two solids,
      But manually it's an hard work and it doesn't seem to work well with round corners tool.
      test fillet.skp
        Out of the fact that your object is not clean (small volume walking in the big 3d Space) πŸ’š
        As said above you must separate your volume for not have internal holes!
        In fact you can erase the faces at the end! πŸ˜„
          rv1974
          1. Boolean union
          2. select desired edges.
          3. Fredo's fillet.
            But it won't work with the present quality of geometry.
          • G
            gepponline77
            Sorry but it's not clear to me what you mean.
            I don't want to round the edges of the "net" (yes, there is some strands that make a net).
            I want to round only the intersections between the net and the rounded cilinder.
            And in my net it seems there is nothing to clean..some strands and some holes between strands.
            Should i have to separate each strand of the net?
              Sorry crossing post so my following text is not adapted! 😳
              Move first the "round" spheric form!
              Call round corner
              erase the falses faces above
              call back spheric form
              et voilΓ  πŸ’š
              • G
                gepponline77
                no pilou! I don't want the net to be rounded!
                I need the intersection faces to be fillet
                Like in the picture attached.
                I need a fillet where there are blue lines.
                  πŸ’š
                  Yes and what is this ? πŸ’š
                  That block the round corner plugin!
                  • G
                    gepponline77
                    @pilou said:
                    πŸ’š
                    ops..but it blocks round plugin only if you try to do what you did, not what i need right?
                    • JQLJ
                      JQL
                      Or blender...
                      www.casca.pt
                      Visit us on facebook!
                      • G
                        gepponline77
                        ok!
                        Perfect!
                        That's what i mean πŸ˜„
                        I think I'll give up about this.
                        It takes too much work for benefits that it gives.
                        thank you so much!
                          No because because it's "invalid" object for it! I must first explode first your no clean general object!
                          Seems round corner don't make easilly that you want! 😲
                          You must use another prog for that!
                          Moi3D for example but it's not free!
                          So take DesignSpark mechanical (V1) or Fusion 360 or Onshape or 123DDesign or FreeCad etc...
                          Moi3D and DesignSpark have skp export! πŸ˜„
                          or make it by hand! πŸ˜‰
                          Here Moi3D 😎
                            Wings3D ManifoldLab πŸ˜‰
                            MeshMixer πŸ˜‰
