    I've got a problem with Sketchup [ clipping plane issues]
    22 Posts 8 Posters 8.9k Views 8 Watching
    • grizzlerG Offline
      grizzler
      @rich o brien said:
      If you delete that large plane I see in the video does it help? You mention things are in meters, how large is that plane?
      I've a feeling it is related to axis placement but we'd need a model to examine. Either PM or here depending on whether it can be shared or not.
      I just recently added the plane there as I needed to rotate on one of the faces. I've done another tiny clip showing me scrolling in at a constant but SLOW rate, and it still plays up http://screencast.com/t/YJnEMrRy
      I can get rid of this problem by using Parallel Projection, but I don't want to work like that, especially as I don't in my other drawings.
      Would you mind tell me how I go about sharing a drawing? Do you just mean sharing via the 3D warehouse? If so then I'm afraid I can't do that presently due to the limiations of where I am at the moment. I might be able to do it tonight when I get home.
      • cottyC Offline
        cotty
        You can add the skp directly as an attachement to your post (under the text-field).
        my SketchUp gallery
        • Jean LemireJ Offline
          Jean Lemire
          Hi folks.
          Try this:
          1 - Make everything visible (Unhide All and make sure all layers are visible).
          2 - Select All.
          3 - Create a group with the selection. All the model including any stray geometry is now one group.
          4 - Open the Outlinerwindow.
          5 - Right click on the newly created group to bring up a contextual menu.
          6 - Choose Zoom Extend in this menu. This will zoom so that only the group fills the screen.
          If the group do not fill the screen, you have something tiny and/or far that is enlarging the bounding box of the group. If this is the case, try the procedure below.
          If it nicely fills the screen there still migth be a problematic geometry but is is in line with the line of sight. Orbit the model at least 90Β° and try again.
          To delete stray geometry that is difficult or even impossible to spot, try this:
          1 - Try to orbit, pan and zoom so that you can see your model sufficiently to select all of it.
          2 - Repeat steps 1 and 2 from above procedure.
          3 - Press and hold down the SHIFT key to Add/Subtract from the selection.
          4 - While still pressing the SHIFT key, do a window select of all of your model. This deselects it. Any stray geometry remains selected.
          5 - Delete the selection.
          If the problem persits, it migth happens that the stray geometry is in line with the line of sight. Again, orbit the view by about 90Β° and repeat the procedure.
          Just ideas.
          • grizzlerG Offline
            grizzler
            I've cleaned up all the drawing and left on filter bank item that exhibits the problem. I'm preparing myself for a barrage of comments beginning with "you idiot, you had >insert setting here< active!" πŸ˜„
            Clipping Plane plus zoom in/out issues
              You've got hidden entities scattered all over. Turn on Hidden Geometry and hit Zoom Extents. Take a look around and clean up the junk.
                You have one longer 'hidden line' that is almost 2 miles away from the origin !
                Erase that [and have a general tidy up - e.g. why all the unattached dims?] and everything will be fine !
                • grizzlerG Offline
                  grizzler
                  Wow. And there's me thinking I kept it tidy! 😳
                  For some reason when I read the last two posts, the voice narrating them in my head was that of my Mum - just like when I was a child being told to tidy my room πŸ˜„
                  Consider me told off.
                    Jean Lemire
                    Hi Grizzler, hi folks.
                    I applied all the ideas in my previous post.
                    See attached SU files for ideas:
                    SU oddity.skp
                    SU oddity 2.skp
                    • F Offline
                      Faizan15
                      this problem occurs only with parallel projection mode. It will be removed if you switch to perspective or 2 point perspective.
                        mpaw79
                        I've found that Advanced Camera Tools cameras can cause problems with clipping. Sometimes you grab a an unlocked camera without knowing it or reset the view of an unlocked camera unexpectedly and that particular camera's FOV volumes become gigantic.
                        From the ACT menu under Tools -> show all cameras & show all FOV volumes. Delete any obviously crazy, misplaced, or forgotten about cameras and their companion scenes.
                          ACT can add a camera and its 'frustum' that is so big, that it makes the model's bounds so big, that it instigates the clipping issue !
                          • 2 / 2
