    Vray rendering
    renderpluginsextensions
    2 Posts 2 Posters 1.1k Views 2 Watching
      rmpramitha
      When RT rendering in VRay, the process stuck in the middle of globle light manager.
      Following lines appear in the VRay progress window.
      Preparing renderer...
      Preparing scene for rendering...
      [RenderView] startCameraTime=0.000000, endCameraTime=0.033333
      [RenderView] numCameraTMs=2, numFrames=1, frameSamples=2
      Initializing built-in VFB.
      Starting DR 1
      dr host: 127.0.0.1:20211
      Connected to render host 127.0.0.1:20211
      Using 1 hosts for distributed rendering.
      Preparing camera sampler.
      Preparing scene for frame...
      Compiling geometry...
      Preparing ray server.
      Creating and initializing 8 thread(s).
      Allocating memory for build data of 37442 faces (149768 bytes, 0.1 MB).
      Initializing face build data.
      Creating 'done' event.
      Starting first thread.
      Waiting for thread completion.
      Releasing thread resources.
      SDTree statistics:
      Total number of faces stored: 37442
      Max tree depth: 37
      Average tree depth: 21.5812
      Number of tree nodes: 28897
      Number of tree faces: 171932
      Number of tree leafs: 12831
      Average faces/leaf: 13.3997
      Memory usage: 2.95 MB
      Scene bounding box is [11787.8,1366.62,2.66611]-[14058.1,2561.87,397.646]
      Preparing direct light manager.
      Preparing global light manager.
      Running RTEngine
      Setting up 1 thread(s)
      Please somebody give me a solution for this issue.
      • TedVitale_CGT Offline
        TedVitale_CG
        It could be a lot of things honestly. But most often its either a bad/overly complicated material, or a corrupted scene. Be sure you are using the latest version of V-Ray for Sketchup, found on http://www.chaosgroup.com under the downloads section after you log in. You can also submit your issue to support@chaosgroup.com.
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
