    3D Truss Models
    1.5k Posts 31 Posters 935.3k Views 30 Watching
    • medeekM Offline
      medeek
      Version 1.2.7 - 01.26.2016
      • Added advanced roof options for hip rafter roof (sheathing, fascia).
      http://design.medeek.com/resources/images/truss_su56_800.jpg
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Couldn't resist adding in these options for hip roof since it was mostly there already from the gable roof module.
      Adding in the roof sheathing was also an excellent check to make sure I had the roof planes correctly modeled. I'm glad to report that it all checks out.
      At some point I also need to add more properties that tabulate, areas, lineal feet and weights. This information might be useful for engineering and material lists/estimating purposes.
      Also note that the fascia boards are not angle at the corners, this is to more easily allow for one to manually push-pull these board to increase or decrease their length.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I've uploaded a test L-Shaped structure with a hip roof:
        3D Warehouse
        I've created both hip roof primitives with the plugin, that was the easy part.
        I then placed a valley rafter with its centerline (top) inline with both roof planes. I think I've got it right. What I am unsure of however is the best way to terminate the framing at the intersection of the valley, lower ridge and flying hip. Once I have a handle on how a carpenter would actually construct that junction I think I can proceed to start work on a secondary roof module for both hip and gable rafter roofs.
        design.medeek.com
        • medeekM Offline
          medeek
          Rev. 5 is a slight variation of the previous roofs. I have shifted the secondary roof over by 24" to create a T-shaped building. The question is how to best frame the long and short valleys:
          3D Warehouse
          design.medeek.com
          • medeekM Offline
            medeek
            One method of framing this roof configuration is to extend the lower ridge past the joint until it meets the next jack rafter, then the flying hip and valley are miter cut to meet the lower ridge.
            I've created a version of the model above with this method of framing at the flying hip/valley/ridge joint:
            http://design.medeek.com/resources/images/truss_su57_800.jpg
            3D Warehouse
            What is the thinking on this method of framing this particular configuration?
            My other concern is the way I have the valley rafter miter cut where it meets the fascia and the corner of the building wall (top plate). Is there a more practical way or better way of making those cuts?
            design.medeek.com
            • medeekM Offline
              medeek
              Compare Rev 2 with Rev 3:
              http://design.medeek.com/resources/images/truss_su58_800.jpg
              3D Warehouse
              This version of Hip Roof 4 has the flying hip extending as a full hip to the exterior wall and then the lower ridge framing into it with the valley rafter framed in last.
              design.medeek.com
              • medeekM Offline
                medeek
                The intersection of the supporting valley rafter, valley rafter and lower ridge I had framed incorrectly. The corrected method is shown below:
                http://design.medeek.com/resources/images/truss_su59_800.jpg
                Also note that the segment of the supporting valley rafter between the upper ridge and lower ridge would need to be beveled or "backed" otherwise it clashes with the sheathing. I noticed this when I originally added the supporting valley rafter but confirmed my suspicion when perusing DeWalt's carpentry and framing handbook this morning. I probably should have pulled this book out before beginning this study but it only confirmed everything I had managed to discover myself once I started examining the model.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Now that I've got a gable and hip rafter roof I was thinking about adding in a dutch gable roof, but I'm a little unclear on the best method to support the end rafters. Has anyone ever seen something like this used?
                  http://www.islandcad.com/parts/hip_collar_bracket_612-l.png
                  I've checked all of my carpentry and construction books and there is absolutely no reference material on traditional framing of this type of roof, online is also quite scant, any resources, framing diagrams etc... would be quite helpful.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    This is my first crack at a dutch gable roof framed with rafters:
                    http://design.medeek.com/resources/images/truss_su60_800.jpg
                    Without the sheathing:
                    http://design.medeek.com/resources/images/truss_su61_800.jpg
                    Please examine the model here:
                    3D Warehouse
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Dutch Gable Rev. 2:
                      3D Warehouse
                      Same as previous except for doubled up common rafters at dutch gable.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Dutch Gable Rev. 3:
                        Doubled up gable common rafters with the dutch ridge/ledger is sandwiched between them. Found a paper by Larry Haun, Mar. 1995 "Framing a Dutch Roof" that was published in Fine Homebuilding magazine, that describes a very similar method of framing.
                        http://design.medeek.com/images/misc/DUTCH_GABLE1.jpg
                        View model here:
                        3D Warehouse
                        Disregard the common rafter sizes they are undersized but look at the method of sandwiching the dutch ridge/ledger between the last common rafters. I would probably also install some blocking between the double gable common rafters. I'm also not showing all of the ceiling joists and bird blocking etc...
                        If the roof gets large enough then one could go to a double ply dutch ridge, or even a deeper LVL member, assuming there is no internal support available from internal walls.
                        I think I'm now ready to add the dutch gable roof into the plugin.
                        design.medeek.com
                        • pbacotP Offline
                          That looks like a nice way to do it!
                          • medeekM Offline
                            medeek
                            There is more than one way to skin a cat with this stuff but if I'm going to put something out there I want it to conform as best as possible to current construction methods. Some of these details may be above and beyond what is required but this is the stuff that keeps me up a night.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I've also realized that for hip roofs I need an option to set the depth of the hip rafters since they are often larger members than the common or jack rafters.
                              Here is the new icon for secondary roofs:
                              http://design.medeek.com/calculator/sketchup/images/mdkplg_tool_icon24_7.png
                              This category will contain the following items:
                              • Gable Roof Minor
                              • Hip Roof Minor
                              • Dutch Gable Roof Minor
                              • Gable Dormer
                              • Hip Dormer
                              • Shed Dormer
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.2.8 - 02.02.2015
                                • Added Shed Rafter Roof with Ledger (all advanced options enabled).
                                • Added ceiling joist option for Shed Rafter Roofs.
                                • New submenu item and toolbar icon added for secondary (minor) roofs.
                                http://design.medeek.com/resources/images/truss_su62_800.jpg
                                View model here:
                                3D Warehouse
                                I used this option to create a monitor style roof line but it can also be used for porch roofs, carports etc... I still need to add a standard shed roof with and upper and lower birdsmouth cut.
                                Also note that with both gable and shed roofs the ceiling joist option is available, with the option to raise them above the top plate. In this model the shed roof ceiling joists are raised 6 inches.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  I've created a listing in the SketchUcation PluginStore:
                                  SketchUp Plugins | PluginStore | SketchUcation
                                  SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                  (sketchucation.com)
                                  design.medeek.com
                                  • pbacotP Offline
                                    Looks nice!
                                    • medeekM Offline
                                      medeek
                                      More "Fun with Roofs".
                                      This roof was generated by first creating a hip roof primitive then deleting all but 3 components which were then copied and rotated into place for the lower roof hip corner. The shed roof /w ledger component was created with one primitive and then copied and rotated into place. Overall a fairly painless process now that I am somewhat familiar with navigating my way around SketchUp. The fascia required a couple of trims.
                                      The pyramid at the top required no manual intervention. Approximately 10-15 minutes of work for a fairly substantial roof.
                                      http://design.medeek.com/resources/images/truss_su63_800.jpg
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Testing the real world application of the Medeek Truss Plugin. This model combines a double fink truss, raised heel fink truss, monopitch truss and shed roof with ledger. While creating the shed roof special attention to the birdsmouth cut was required to ensure that the fascia height of the rafters and trusses lined up. Also note the use of the raised heel type truss on the upper roof portion. Structural outlookers were specified for all gable overhangs.
                                        5:12 pitch roofs with rafters and trusses 24" o/c. I did not apply a level cut to the rafter overhangs but that would probably be a given. Span of the double fink is 48 feet with 2x6 top and bottom chords.
                                        http://design.medeek.com/resources/images/truss_su64_800.jpg
                                        http://design.medeek.com/resources/images/truss_su65_800.jpg
                                        View models here:
                                        3D Warehouse
                                        3D Warehouse
                                        If anyone has some real world applications using the plugin that they are willing to share I would be very interested to see how it is being used and it would also give me some direction for further development and improvements.
                                        design.medeek.com
                                          What a plugin! 😎
                                          Sorry for the diversion! πŸ˜‰
                                          • medeekM Offline
                                            medeek
                                            I've ran into this structural question before, where you have a stairway next to an exterior wall. My first thought is to call out a balloon framed wall up to the 2nd story top plate(s) but then that makes the rim board and double top plate of the first story discontinuous. What is the preferred solution or how have you seen this done in similar circumstances.
                                            Here is a quick mock up in SketchUp to better explain what the two options are:
                                            http://design.medeek.com/images/MISC/NAMATAME1.jpg
                                            http://design.medeek.com/images/MISC/NAMATAME2.jpg
                                            You can also view and download the 3D SketchUp model here:
                                            3D Warehouse
                                            design.medeek.com
                                            • 75
                                            • 76
                                            • 6 / 76
