    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      Dutch Gable Rev. 2:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Same as previous except for doubled up common rafters at dutch gable.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Dutch Gable Rev. 3:
        Doubled up gable common rafters with the dutch ridge/ledger is sandwiched between them. Found a paper by Larry Haun, Mar. 1995 "Framing a Dutch Roof" that was published in Fine Homebuilding magazine, that describes a very similar method of framing.
        http://design.medeek.com/images/misc/DUTCH_GABLE1.jpg
        View model here:
        3D Warehouse
        Disregard the common rafter sizes they are undersized but look at the method of sandwiching the dutch ridge/ledger between the last common rafters. I would probably also install some blocking between the double gable common rafters. I'm also not showing all of the ceiling joists and bird blocking etc...
        If the roof gets large enough then one could go to a double ply dutch ridge, or even a deeper LVL member, assuming there is no internal support available from internal walls.
        I think I'm now ready to add the dutch gable roof into the plugin.
        design.medeek.com
        • pbacotP
          That looks like a nice way to do it!
          • medeekM
            medeek
            There is more than one way to skin a cat with this stuff but if I'm going to put something out there I want it to conform as best as possible to current construction methods. Some of these details may be above and beyond what is required but this is the stuff that keeps me up a night.
            design.medeek.com
            • medeekM
              medeek
              I've also realized that for hip roofs I need an option to set the depth of the hip rafters since they are often larger members than the common or jack rafters.
              Here is the new icon for secondary roofs:
              http://design.medeek.com/calculator/sketchup/images/mdkplg_tool_icon24_7.png
              This category will contain the following items:
              • Gable Roof Minor
              • Hip Roof Minor
              • Dutch Gable Roof Minor
              • Gable Dormer
              • Hip Dormer
              • Shed Dormer
              design.medeek.com
              • medeekM
                medeek
                Version 1.2.8 - 02.02.2015
                • Added Shed Rafter Roof with Ledger (all advanced options enabled).
                • Added ceiling joist option for Shed Rafter Roofs.
                • New submenu item and toolbar icon added for secondary (minor) roofs.
                http://design.medeek.com/resources/images/truss_su62_800.jpg
                View model here:
                3D Warehouse
                I used this option to create a monitor style roof line but it can also be used for porch roofs, carports etc... I still need to add a standard shed roof with and upper and lower birdsmouth cut.
                Also note that with both gable and shed roofs the ceiling joist option is available, with the option to raise them above the top plate. In this model the shed roof ceiling joists are raised 6 inches.
                design.medeek.com
                • medeekM
                  medeek
                  I've created a listing in the SketchUcation PluginStore:
                  404 Not Found
                  (sketchucation.com)
                  design.medeek.com
                  • pbacotP
                    Looks nice!
                    • medeekM
                      medeek
                      More "Fun with Roofs".
                      This roof was generated by first creating a hip roof primitive then deleting all but 3 components which were then copied and rotated into place for the lower roof hip corner. The shed roof /w ledger component was created with one primitive and then copied and rotated into place. Overall a fairly painless process now that I am somewhat familiar with navigating my way around SketchUp. The fascia required a couple of trims.
                      The pyramid at the top required no manual intervention. Approximately 10-15 minutes of work for a fairly substantial roof.
                      http://design.medeek.com/resources/images/truss_su63_800.jpg
                      View model here:
                      3D Warehouse
                      design.medeek.com
                      • medeekM
                        medeek
                        Testing the real world application of the Medeek Truss Plugin. This model combines a double fink truss, raised heel fink truss, monopitch truss and shed roof with ledger. While creating the shed roof special attention to the birdsmouth cut was required to ensure that the fascia height of the rafters and trusses lined up. Also note the use of the raised heel type truss on the upper roof portion. Structural outlookers were specified for all gable overhangs.
                        5:12 pitch roofs with rafters and trusses 24" o/c. I did not apply a level cut to the rafter overhangs but that would probably be a given. Span of the double fink is 48 feet with 2x6 top and bottom chords.
                        http://design.medeek.com/resources/images/truss_su64_800.jpg
                        http://design.medeek.com/resources/images/truss_su65_800.jpg
                        View models here:
                        3D Warehouse
                        3D Warehouse
                        If anyone has some real world applications using the plugin that they are willing to share I would be very interested to see how it is being used and it would also give me some direction for further development and improvements.
                        design.medeek.com
                          What a plugin! 😎
                          Sorry for the diversion! πŸ˜‰
                          • medeekM
                            medeek
                            I've ran into this structural question before, where you have a stairway next to an exterior wall. My first thought is to call out a balloon framed wall up to the 2nd story top plate(s) but then that makes the rim board and double top plate of the first story discontinuous. What is the preferred solution or how have you seen this done in similar circumstances.
                            Here is a quick mock up in SketchUp to better explain what the two options are:
                            http://design.medeek.com/images/MISC/NAMATAME1.jpg
                            http://design.medeek.com/images/MISC/NAMATAME2.jpg
                            You can also view and download the 3D SketchUp model here:
                            3D Warehouse
                            design.medeek.com
                            • jujuJ
                              juju
                              Hi Nathaniel,
                              I noticed that Extension Warehouse has two links for your plugin, the one should be removed, not so?
                              ERROR: The request could not be satisfied
                              (extensions.sketchup.com)
                              • medeekM
                                medeek
                                For some reason there are two copies on Extension Warehouse, you're right. I'm looking into it.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Example of a porch roof using the hip roof and shed roof primitives. I'm wondering if it might not be worthwhile to add in a feature to create this type of combination roof automatically. Shed Roof w/ ledger & hip ends.
                                  http://design.medeek.com/images/MISC/NAMATAME3.jpg
                                  View updated model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • pbacotP
                                    Both shed and hip add-on roofs would be useful, porches and partial 2-story structures.
                                    • medeekM
                                      medeek
                                      http://design.medeek.com/support/trusspluginmanual/images/structural_outlookers.jpg
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Started the manual as a MS Word document however that doesn't work so well for hyperlinks. Starting over with an html manual page:
                                        404 - File or directory not found.
                                        (design.medeek.com)
                                        (design.medeek.com)
                                        Couple of pages up, only about 25 more to go...
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.2.9 - 02.12.2015
                                          • Added Shed Rafter Roof (all advanced options enabled).
                                          • Initial menu now defaults to last picked option of session for that sub-menu item.
                                          A typical application might be a clerestory roof with a upper shed roof and lower shed roof with a ledger board:
                                          http://design.medeek.com/resources/images/truss_su66_800.jpg
                                          View model here:
                                          3D Warehouse
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.3.0 - 02.14.2016
                                            • Added tail bearing truss type, configurations: (Fink).
                                            • Metric input enabled for tail bearing truss type.
                                            • Advanced options enabled for tail bearing truss type.
                                            http://design.medeek.com/images/MISC/tailbearingtruss1.jpg
                                            View model here:
                                            3D Warehouse
                                            I have shown 3 configurations of the same roof to display the differences with non-structural vs. structural outlookers (horz. & vert.). I am not exactly sure how to treat the gable end truss for this truss type since I have never dealt with this type of truss before. Specifically, where structural outlookers are employed. Any sample outputs showing the gable end truss with a dropped top chord for a tail bearing truss would be very helpful.
                                            Theoretically, one could forego the gable end trusses altogether and just balloon frame up to the roof diaphragm but I would like to provide the option for gable end trusses if it is a typical method used in real construction of this type of roof.
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 76
                                            • 77
                                            • 13 / 77
