    I think I've finally had it with upgrades!
    18 Posts 6 Posters 2.0k Views 6 Watching
    • JQLJ
      JQL
      Have you checked DWG export options?
      www.casca.pt
      Visit us on facebook!
      • pbacotP
        Where is this? I don't have that under options. Is it different for windoews. And yes I have to choose 3d Model or 2d graphic, nothing about section cut.
        • JQLJ
          JQL
          www.casca.pt
          • bazB
            baz
            With regards the new trays, they take a bit of getting use to, however they are well suited to a two screen setup once you have made a few unpinned custom ones to suit your workflow
            Phillip, I too am having trouble getting used to the new trays, could you post a screen shot of how you have yours set up?
            Baz
            • pbacotP
              • John SayersJ
                John Sayers
                I've finally solved the problem with the kind help of Sketchup support.
                It was hardware acceleration that was causing the problem that disappeared when I disabled hardware acceleration.
                Thank you Ty.
                • P
                  pcmoor
                  [quote="baz":3302027s]
                  Baz
                  by all means...
                  you can create different size trays and park them on the other screen, plus I have DC option placed too
                  you can leave the default or some pinned as well? but I find that the placed ones less annoying.
                  • bazB
                    baz
                    [quote="pcmoor":m4lamnad]
                    Baz
                    by all means...
                    [attachment=1:m4lamnad]<!-- ia1 -->Capture-Screen1.PNG<!-- ia1 -->[/attachment:m4lamnad]
                    [attachment=0:m4lamnad]<!-- ia0 -->Capture-Screen2.PNG<!-- ia0 -->[/attachment:m4lamnad]
                    Ah I see, numerous trays on second monitor, will try that, thanks Phillip.
                    • JQLJ
                      JQL
                      Philip I see you have Outliner always open, I used to have that until I noticed it was delaying plugins a lot. Don't you use plugins?
                      www.casca.pt
                      • P
                        pcmoor
                        yes, there are significant delays whilst using a plugin, "rolling up" this dialog resolves this. At this stage I use the outliner a lot, so until this changes, I am quite happy to occasionally forget then roll it up.
                        • V
                          valerostudio
                          Change in workflow sucks, but as a person involved in the beta testing I can tell you that we test it, make sure it isn't junk and report back. The trays were annoying me initially and now they are part of my workflow. Trimble has done a great job with SketchUp I have to say. Imagine if it went over to Autodesk!!!
