    [Plugin]Poly Checker
    7 Posts 5 Posters 1.6k Views 5 Watching
    • ithilI Offline
      ithil
      Hi All!
      I'd like to present my new script for SketchUp and SUbD.
      It helps to work with the plugin SUbD too.
      This plugin for checking topology mesh with support SUbD poly.
      The script color polygons depending on the topology.
      You can analyze your mesh and find the topology errors.
      And you can use the "Select > All with same Material"
      Menu
      Plugins(Extensions) >> Ithil Tools >> Poly Checker
      %(#FF0000)[Important!
      This script rewrite your materials!
      If you have material on the mesh, the script will warn about rewrite.]
      • Trianglee"Brown"
      • Correct SUbD polygon "DarkOliveGreen"
      • Face with 5 or more points "OrangeRed"
      • More than two faces connected to edges "Purple"
      You can customize the colors changing in the script code
      ithil_poly_checker.rbz
      • CadFatherC Offline
        CadFather
        Спасибо Ithil
        • StinkieS Offline
          Stinkie
          Thanks! 👍
          • dereiD Offline
            derei
            Thanks !! This is one I was thinking a lot lately that would be needed... since I started to do quad modelling.
            DESIGNER AND ARTIST DEREI.UK
              Excellent! I was thinking this was needed - though it would have ended up further down on my list at the moment. So happy to see more extensions aimed at the quad-workflow.
              I was also toying with the idea of another mode where you'd use a Ruby Tool and draw on top of the viewport instead of changing the materials - similar to what Solid Inspector 2 does.
              Are you considering making this tool open source? If you had the source on GitHub or BitBucket then I - or anyone else - submit additional improvements. (Just an idea.)
              • ithilI Offline
                ithil
                Hey.
                about my plugin code.
                If you want you can take any part of the file .RB 😃
                I'm not a programmer. These sites are too cool for my modest projects)
                  I'd argue they are perfect for this. 😄
