    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
      Anton_S
      Thanks Pilou, there are still changes and additions that need to be done. I might contact you once the project is suitable for localization. Thanks again.
        Perfect! πŸ‘
        Does the Universal, and CorkScrew Joints are now working ?
        • pcberdwinP Offline
          pcberdwin
          I've installed the latest files into Sketchup 2015 and get a bugsplat every time I run a simulation. Is there an error log I can post or send you? Thanks.
            Motors on wheels!
            On a Static Ground
            **Draw a Joint (motor) on the axe of the piece (wheel) who will run!
            Group this joint (motor) with this piece (wheel)! (SU Group)
            CONNECTE this Joint (motor) to the parent piece (car) with MAJ &/or CTRL !
            (Connection MSPhysics)**
            Miracle we can Copy / rotate etc...the wheel + motor around the car!
            Each motor can have different acceleration etc...
            Better to put all joints on the same layer for hide them
            And use component for at the end when all works fine replace the box car by a Bugatti! πŸ˜„
            http://s6.postimg.org/6d57679xt/GIF_auto.gif
              πŸ’š
              http://s6.postimg.org/wt8k5tudt/GIF_bugatti.gif
              • F Offline
                FikeFab
                Can someone help. Ive tried deleting and reloading the MSphysics and ams files but keep getting this load error.
                Error Loading File C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                Error: #<LoadError: 126: The specified module could not be found. - C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so>
                C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb:23:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require'
                C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:119:in register_extension'
                C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:119:in <module:MSPhysics>' C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:101:in <top (required)>'
                  RobiBue
                  have you made sure that the file msp_lib.so exists in the above mentioned directory/folder?
                    PituPhysics
                    Me too. I re-installed the Windows 10 x64 + SU16 and again this is a problem. But the last time it worked. I don't understand.
                      Anton_S
                      Very strange. It seems the download fails from time to time. I will update the download link.
                      Edit: I updated the download link.
                      • F Offline
                        FikeFab
                        I would not work on 64 bit. Downloaded the 32 bit version of SU and worked fine. Haven't tried new link.
                        • cottyC Offline
                          cotty
                          It's 64-bit compatible.
                          my SketchUp gallery
                          • soloS Offline
                            So it will work with SU 2016 64 bit?
                            • cottyC Offline
                              cotty
                              I'm sure because I've created the above animations with it. πŸ‘
                              my SketchUp gallery
                                There are no cursors like SketchyPhysics for control the movements of Object, Motor etc...
                                • cottyC Offline
                                  cotty
                                  You can control the movement of the chains model from here with keys?
                                  my SketchUp gallery
                                    And a little problem πŸ˜„
                                    How motorise an only sphere alone? (Auto-moved on the ground and controled by key)
                                    Here I must connected one white(s) to another one (little red)! File skp
                                    http://sketchucation.com/forums/download/file.php?id=136098
                                      Yes Very cool but How gives the control to keys?
                                      It's automatic?
                                        pcberdwin
                                        I just upgraded to 2016 and still get the bugsplat 😲
                                          Anton_S
                                          My brother checked MSPhysics 0.3.0 and AMS Library 3.1.3 on his Windows 7 laptop and he didn't get any bugsplats. I can't resolve the bugsplat without a detailed feedback of the bugsplat environment that would help me reproduce the bug. These are key factors that I'm looking for:
                                          1. Version of an operation system.
                                          2. Version of SketchUp
                                          3. Is the SU 32bit or 64bit?
                                          4. The way the bugsplat occurred. Did it bugsplat when starting SU or after playing a certain model?
                                            pcberdwin
                                            Windows 10 Home 64
                                            SketchUp Make 16.0.19912 64
                                            It doesn't matter what is in SketchUp when I Toggle Play, it crashes right after that. I can open Toggle UI fine and set physical properties to MSPhysics but when I press play it crashes. Also, I can do anything else in SketchUp and use any other plugin without any crashes.
                                            I don't know if this is related but there's been a big problem with one of the latest Windows 10 updates that breaks some functionality for people with Nvidia. For example, I cannot open Minecraft for Windows 10 without it crashing. It's a known bug and really it's up to Microsoft or Nvidia to fix. It has something to do with DirectX wrappers? I don't know if this would be related to what's happening with MSPhysics.
                                            • 11
                                            • 12
                                            • 46
                                            • 47
                                            • 10 / 47
