    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 977.4k Views 172 Watching
      Deano45
      Hello, New to MsPhysics. I've installed SU16-x64 and AMS 3.1.3. But keep getting bug splats.
      I thought it might be my Desktop, So i tried my laptop and got the same bug splat. The install is pretty simple am i missing a step?
      Thanks Deano
        Anton_S
        Just in case if it's installing issues, try deleting both plugins - ams_Lib and MSPhysics - and try installing them again.
          About Multi-languages ?
          I can translate it in French but in easy way (ressource), not in swimming in any file! πŸ˜‰
          http://s6.postimg.org/n7ej65ma9/GIF_msp01.gif
            Anton_S
            Thanks Pilou, there are still changes and additions that need to be done. I might contact you once the project is suitable for localization. Thanks again.
              Perfect! πŸ‘
              Does the Universal, and CorkScrew Joints are now working ?
              • pcberdwinP Offline
                pcberdwin
                I've installed the latest files into Sketchup 2015 and get a bugsplat every time I run a simulation. Is there an error log I can post or send you? Thanks.
                  Motors on wheels!
                  On a Static Ground
                  **Draw a Joint (motor) on the axe of the piece (wheel) who will run!
                  Group this joint (motor) with this piece (wheel)! (SU Group)
                  CONNECTE this Joint (motor) to the parent piece (car) with MAJ &/or CTRL !
                  (Connection MSPhysics)**
                  Miracle we can Copy / rotate etc...the wheel + motor around the car!
                  Each motor can have different acceleration etc...
                  Better to put all joints on the same layer for hide them
                  And use component for at the end when all works fine replace the box car by a Bugatti! πŸ˜„
                  http://s6.postimg.org/6d57679xt/GIF_auto.gif
                    πŸ’š
                    http://s6.postimg.org/wt8k5tudt/GIF_bugatti.gif
                    • F Offline
                      FikeFab
                      Can someone help. Ive tried deleting and reloading the MSphysics and ams files but keep getting this load error.
                      Error Loading File C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                      Error: #<LoadError: 126: The specified module could not be found. - C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so>
                      C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                      C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb:23:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require'
                      C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:119:in register_extension'
                      C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:119:in <module:MSPhysics>' C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:101:in <top (required)>'
                        RobiBue
                        have you made sure that the file msp_lib.so exists in the above mentioned directory/folder?
                          PituPhysics
                          Me too. I re-installed the Windows 10 x64 + SU16 and again this is a problem. But the last time it worked. I don't understand.
                            Anton_S
                            Very strange. It seems the download fails from time to time. I will update the download link.
                            Edit: I updated the download link.
                            • F Offline
                              FikeFab
                              I would not work on 64 bit. Downloaded the 32 bit version of SU and worked fine. Haven't tried new link.
                              • cottyC Offline
                                cotty
                                It's 64-bit compatible.
                                my SketchUp gallery
                                • soloS Offline
                                  So it will work with SU 2016 64 bit?
                                  • cottyC Offline
                                    cotty
                                    I'm sure because I've created the above animations with it. πŸ‘
                                    my SketchUp gallery
                                      There are no cursors like SketchyPhysics for control the movements of Object, Motor etc...
                                      • cottyC Offline
                                        cotty
                                        You can control the movement of the chains model from here with keys?
                                        my SketchUp gallery
                                          And a little problem πŸ˜„
                                          How motorise an only sphere alone? (Auto-moved on the ground and controled by key)
                                          Here I must connected one white(s) to another one (little red)! File skp
                                          http://sketchucation.com/forums/download/file.php?id=136098
                                            Yes Very cool but How gives the control to keys?
                                            It's automatic?
                                            • 11
                                            • 12
                                            • 46
                                            • 47
                                            • 10 / 47
