    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Anton_S
      Just in case if it's installing issues, try deleting both plugins - ams_Lib and MSPhysics - and try installing them again.
        About Multi-languages ?
        I can translate it in French but in easy way (ressource), not in swimming in any file! πŸ˜‰
        http://s6.postimg.org/n7ej65ma9/GIF_msp01.gif
          Anton_S
          Thanks Pilou, there are still changes and additions that need to be done. I might contact you once the project is suitable for localization. Thanks again.
            Perfect! πŸ‘
            Does the Universal, and CorkScrew Joints are now working ?
            • pcberdwinP
              pcberdwin
              I've installed the latest files into Sketchup 2015 and get a bugsplat every time I run a simulation. Is there an error log I can post or send you? Thanks.
                Motors on wheels!
                On a Static Ground
                **Draw a Joint (motor) on the axe of the piece (wheel) who will run!
                Group this joint (motor) with this piece (wheel)! (SU Group)
                CONNECTE this Joint (motor) to the parent piece (car) with MAJ &/or CTRL !
                (Connection MSPhysics)**
                Miracle we can Copy / rotate etc...the wheel + motor around the car!
                Each motor can have different acceleration etc...
                Better to put all joints on the same layer for hide them
                And use component for at the end when all works fine replace the box car by a Bugatti! πŸ˜„
                http://s6.postimg.org/6d57679xt/GIF_auto.gif
                  πŸ’š
                  http://s6.postimg.org/wt8k5tudt/GIF_bugatti.gif
                  • F
                    FikeFab
                    Can someone help. Ive tried deleting and reloading the MSphysics and ams files but keep getting this load error.
                    Error Loading File C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                    Error: #<LoadError: 126: The specified module could not be found. - C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so>
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                    C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb:23:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require'
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:119:in register_extension'
                    C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:119:in <module:MSPhysics>' C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:101:in <top (required)>'
                      RobiBue
                      have you made sure that the file msp_lib.so exists in the above mentioned directory/folder?
                      • P
                        PituPhysics
                        Me too. I re-installed the Windows 10 x64 + SU16 and again this is a problem. But the last time it worked. I don't understand.
                          Anton_S
                          Very strange. It seems the download fails from time to time. I will update the download link.
                          Edit: I updated the download link.
                          • F
                            FikeFab
                            I would not work on 64 bit. Downloaded the 32 bit version of SU and worked fine. Haven't tried new link.
                            • cottyC
                              cotty
                              It's 64-bit compatible.
                              my SketchUp gallery
                              • soloS
                                So it will work with SU 2016 64 bit?
                                • cottyC
                                  cotty
                                  I'm sure because I've created the above animations with it. πŸ‘
                                  my SketchUp gallery
                                    There are no cursors like SketchyPhysics for control the movements of Object, Motor etc...
                                    • cottyC
                                      cotty
                                      You can control the movement of the chains model from here with keys?
                                      my SketchUp gallery
                                        And a little problem πŸ˜„
                                        How motorise an only sphere alone? (Auto-moved on the ground and controled by key)
                                        Here I must connected one white(s) to another one (little red)! File skp
                                        http://sketchucation.com/forums/download/file.php?id=136098
                                          Yes Very cool but How gives the control to keys?
                                          It's automatic?
                                          • pcberdwinP
                                            pcberdwin
                                            I just upgraded to 2016 and still get the bugsplat 😲
                                            • 11
                                            • 12
                                            • 46
                                            • 47
                                            • 10 / 47
