    Introducing SUbD for SketchUp...
    renderpluginsextensions
    66 Posts 19 Posters 39.8k Views 19 Watching
    • dereiD
      derei
      @pilou said:
      Why not use the Interactive Joint Push Pull by Fredo6 ? 😉
      [attachment=0:3h8qbjv8]<!-- ia0 -->jointpp.jpg<!-- ia0 -->[/attachment:3h8qbjv8]
      i use it... but my question was about SUbD pushpull, to understand what is its purpose.
      Now I got my answer.
      DESIGNER AND ARTIST DEREI.UK
      • dereiD
        derei
        After a quick play with SUbD, i noticed that one feature would be GREAT to have:
        -some sort of "selection sets" for creased edges/vertices. When selecting more edges and crease them together, maybe i want to come back to same set to adjust them further. Every time I have to manually select them all, which is a bit of a pain when there are many. But if there would be a way to select all edges that were creased in the same set, would be awesome.
        How I am thinking it can be accomplished: using attribute dictionaries, for example. Giving a sort of unique ID to all edges that were creased simultaneously, so when the selection tool looks for which edges to select, it will filter them out by this unique id.
        I already saw that the creased edges are displayed in a "red" color, which red value varies depending on how creased it is. So, i am assuming those edges are already recognized... maybe selecting them as a "set" would be a easy step to add.
        • panixiaP
          panixia
          Pilou, that's great and i use it a lot, but unfortunately, not in this kind of models, because as it is it doesn't support quads.. 90% of the cases it will break them. 😞
          • panixiaP
            panixia
            @derei said:
            Please see attached.
            [attachment=0:33qnbrf7]<!-- ia0 -->push.jpg<!-- ia0 -->[/attachment:33qnbrf7]
            i noticed you are also triyng to edit the subdivided mesh. unless you just converted it to "plain mesh" from the right click menu, editing the smoothed mesh is pointless, because when you toggle off sub-d, it will revert back to the original control cage.. and all of the editing done directly on the limit mesh will be lost.
            • dereiD
              derei
              @panixia said:
              [attachment=0:15logg0u]<!-- ia0 -->push.jpg<!-- ia0 -->[/attachment:15logg0u]
              Thanks 😄 ... i found out that myself. The hard way.
              • panixiaP
                panixia
                  Yes - Crease Sets is something I already have on the radar. At the moment I'm thinking of something like a dialog that let you manage a list of creases - such that you can easily locate and manioulate them. One challenge to resolve is how to represent creases with varying creasing - like, what do you do if you adjust a crease with non-uniform crease.
                  • gillesG
                    gilles
                    I create a cube, make it a group, click Toggle subdivision on/off, and…
                    "OOPS! an error occurred…"
                    Error; #<NoMethodError; undefined method `commit_operation' for nil;NilClass>
                    /users/gilles/library/application support/sketchup 2015/sketchup/plugins/tt_subd/commands.rbs;416;in `rescue in set_subdivided'
                    /users/gilles/library/application support/sketchup 2015/sketchup/plugins/tt_subd/commands.rbs;349;in `set_subdivided'
                    /users/gilles/library/application support/sketchup 2015/sketchup/plugins/tt_subd/commands.rbs;433;in `toggle_subdivision'
                    /users/gilles/library/application support/sketchup 2015/sketchup/plugins/tt_subd/commands.rbs;42;in `block in <module;Commands>'
                    SketchUp;1;in `call'
                    SketchupMake version 15.3.329
                    Macbook pro OS X 10.8.5 (12F45)
                    • JQLJ
                      JQL
                      Here you go Thomthom, I hope this helps (click on gif):
                      It isn't represented at the bottom (as this editor is actually a color gradient editor) but you could have a Value/Lighness slider next to a values input box for precise manipulation of crease values.
                      www.casca.pt
                      Visit us on facebook!
                        Ah, yes - there is a bug that happen only on OSX 10.8. I have a fix for this - I'll release a patch as soon as I can.
                          I've just released a patch for this - version 1.0.1. Download it from the SUbD website (http://evilsoftwareempire.com/subd/download) or from SketchUcation PluginStore. It should be live on Extension Warehouse after the weekend as well.
                          • gillesG
                            gilles
                            Works fine thank you.
                            Nice tool to play with.
                              @Gilles : et en français au cas où! 💚
                                rv1974
                                Neil explains why OpenSubdivs shine
                                https://youtu.be/ENA2FAF_PIc
                                Notice how important Creasing sets(based on angle value, see at 7.20) are. Hope Thomthom will deliver them soon.
                                NB The second part is interesting too
                                • 4 / 4
