    Quick way to properly UV map cylinder section?
    5 Posts 3 Posters 727 Views 3 Watching
    • dereiD Offline
      derei
      I am trying to apply a texture on a curved surface that is not a complete cylinder. I was using a UV plugin that offers Cylindrical Mapping, but the issue is that it will try to map 360 every time, even if my geometry does not completely revolve.
      My texture is a label, so it should fit exactly on the surface. Any help appreciated.
      DESIGNER AND ARTIST DEREI.UK
      • HornOxxH Offline
        HornOxx
        Hi Derei, I hope, that is what you are looking for
        Fredo Tools / ThruPaint is a perfect tool for mapping, adjusting and even scaling or
        rotating any texture on your cylinder.
        Before doing so, adjust the size of your texture as desired so that it appears as
        a already "fitting" material in your SU material window ...
        http://sketchucation.com/pluginstore?pln=FredoTools
        https://www.youtube.com/watch?v=l2QjLlUQVrY
        never trust a skinny cook
        • dereiD Offline
          derei
          Brilliant ! Thanks ! πŸ˜„
          • panixiaP Offline
            panixia
            actually this is a good practice if you use the native sketchup projected method..
            but's 90% of the time a reduntant step in trupaint, because, as you properly said it has a visual scaling functionality.
            moreover in this particular OP case
            the faster way is to symply pick the "tile 1x" option from tru-paint right click menu. πŸ‘
            (or, if you prefer, type in your vcb "1*" which actually will lead to the very same result)
            • HornOxxH Offline
              HornOxx
              @panixia said:
              the faster way is to symply pick the "tile 1x" option from tru-paint right click menu. πŸ‘ (or, if you prefer, type in your vcb "1*" which actually will lead to the very same result)
              thanks for pointing this out
              some "not every day" things one forgets so easily πŸ˜„
