    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 957.9k Views 172 Watching
    • cottyC Offline
      cotty
      Thank you, Anton, that helped!
      my SketchUp gallery
        RobiBue
        Just a heads up replying to my post:
        @robibue said:
        Hi, I'm using SU2015 and with
        ams_Lib 3.1.2 and
        MSPhysics 0.2.1
        I get the following errors:
        [pre:1doxyosj]Error Loading File ...[/pre:1doxyosj]
        Please help
        thanks
        Thank you,
        the new version "0.3.0" runs smoothly on SU 15 and 16
        Great work ❗ πŸ‘
          PituPhysics
          Hello Anton! For me it's not working. New installed SU16-x64 and AMS 3.1.3.
          http://sketchucation.com/forums/download/file.php?mode=view%26amp;id=135827
          • F Offline
            faust07
            Initial tests are promising. Great work Anton! πŸ‘ I can not resist to carry out detailed experiments with joints and scripts. Extreme wishes are an import function for SketchyPhysics models and detection of replay data by the Twilight renderer. 😐
              PituPhysics
              I'm sorry, my fault. 😞 Now work perfectly πŸ‘
                Seems terrific! 😎
                Nothing for multi-Languages System ?
                  Deano45
                  Hello, New to MsPhysics. I've installed SU16-x64 and AMS 3.1.3. But keep getting bug splats.
                  I thought it might be my Desktop, So i tried my laptop and got the same bug splat. The install is pretty simple am i missing a step?
                  Thanks Deano
                    Anton_S
                    Just in case if it's installing issues, try deleting both plugins - ams_Lib and MSPhysics - and try installing them again.
                      About Multi-languages ?
                      I can translate it in French but in easy way (ressource), not in swimming in any file! πŸ˜‰
                      http://s6.postimg.org/n7ej65ma9/GIF_msp01.gif
                        Anton_S
                        Thanks Pilou, there are still changes and additions that need to be done. I might contact you once the project is suitable for localization. Thanks again.
                          Perfect! πŸ‘
                          Does the Universal, and CorkScrew Joints are now working ?
                          • pcberdwinP Offline
                            pcberdwin
                            I've installed the latest files into Sketchup 2015 and get a bugsplat every time I run a simulation. Is there an error log I can post or send you? Thanks.
                              Motors on wheels!
                              On a Static Ground
                              **Draw a Joint (motor) on the axe of the piece (wheel) who will run!
                              Group this joint (motor) with this piece (wheel)! (SU Group)
                              CONNECTE this Joint (motor) to the parent piece (car) with MAJ &/or CTRL !
                              (Connection MSPhysics)**
                              Miracle we can Copy / rotate etc...the wheel + motor around the car!
                              Each motor can have different acceleration etc...
                              Better to put all joints on the same layer for hide them
                              And use component for at the end when all works fine replace the box car by a Bugatti! πŸ˜„
                              http://s6.postimg.org/6d57679xt/GIF_auto.gif
                                πŸ’š
                                http://s6.postimg.org/wt8k5tudt/GIF_bugatti.gif
                                • F Offline
                                  FikeFab
                                  Can someone help. Ive tried deleting and reloading the MSphysics and ams files but keep getting this load error.
                                  Error Loading File C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
                                  Error: #<LoadError: 126: The specified module could not be found. - C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/win64/2.0/msp_lib.so>
                                  C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                  C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb:23:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require'
                                  C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load' C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:119:in register_extension'
                                  C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:119:in <module:MSPhysics>' C:/Users/Brian/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:101:in <top (required)>'
                                    RobiBue
                                    have you made sure that the file msp_lib.so exists in the above mentioned directory/folder?
                                      PituPhysics
                                      Me too. I re-installed the Windows 10 x64 + SU16 and again this is a problem. But the last time it worked. I don't understand.
                                        Anton_S
                                        Very strange. It seems the download fails from time to time. I will update the download link.
                                        Edit: I updated the download link.
                                        • F Offline
                                          FikeFab
                                          I would not work on 64 bit. Downloaded the 32 bit version of SU and worked fine. Haven't tried new link.
                                          • cottyC Offline
                                            cotty
                                            It's 64-bit compatible.
                                            my SketchUp gallery
                                            • 46
                                            • 47
                                            • 6 / 47
