    Object Animation & Scene Rendering
    6 Posts 3 Posters 805 Views 3 Watching
    • ntxdaveN Offline
      ntxdave
      I have looked at several threads about animation and rendering lately and wondering what is the best combination for creating animated scenes, object animation and rendering (NPR is fine with me).
      I model car wash equipment layouts and would like to be able to produce a higher quality product that is animated. I have read about and looked at some videos about plugins like Proper Animation, SU Animate and a couple more.
      Here are links to 2 versions of an animation I created using the trial version of the Keyframe Animation plugin:
      https://www.youtube.com/watch?v=mTWJbDgYr2I
      https://www.youtube.com/watch?v=NRlDLbGFe40
      Now, here is what I would like to do to take this to the next level:
      • Put the equipment inside of a building
      • Provide a "walk through" type of view of the building
      • Show other aspects of the complete car wash (i.e. payment stations, vacuum system, office, and support equipment)
      • Enhance the entire car wash and equipment with enhanced materials from a rendering engine
      • Provide a video or, even better, a WebGL version of the animated car wash and equipment
      • Find a tool that would allow me to animate some additional pieces equipment that spray water and foam
      Any suggestions would be greatly appreciated.
      Press F1...thank me later
      • ntxdaveN Offline
        ntxdave
        @pilou said:
        I believe that the free Hobby (and Pro) Twiligh V2 is capable to render animation! 😉
        Thanks for your reply Pilou, I will give it a look.
          I believe that the free Hobby (and Pro) Twilight V2 is capable to render animation! 😉
          • emerald15E Offline
            emerald15
            This thread leads directly to the issue I’m trying to resolve.
            I’m using Twilight Render and want to produce a video (just camera movement at present, no object animation). Previously I would just out-put directly from SU to an AVI format. However, Twilight will only output the frames, (which I have successfully achieved already).
            My problem is that I need software that will now assemble the frames into video format….and I’m running Windows 10.
            Previously I’ve used Virtualdub – bit it appears un-stable on Win 10 (saving sometimes fails).
            I’ve tried Win Movie Maker, but can’t seem to speed up the frame rate (the editor has a 1min. minimum setting… my test movie is only 4 secs). The best I’ve achieved is ‘crawl’ through the frames at approx.. 1 sec each instead of at least 30 per sec.
            I downloaded Filmora but it keeps crashing (again now Win 10 compatible). Seems more suited to video editing rather than frames assemble.
            I’ve come across Debug Mode’s Wax / Frame Server which might suit, but again, don’t think it’s Win 10 compat.
            I don’t particularly want to back to Win8 as Win 10 has improved my system in other ways.
            Does anyone have any suggestions, please?
            I realise this question would better be directed to the Twilight forum – I have asked, but no replies as yet. It’s also a bit of a ‘heads up’ to ntxdave if you go down this route.
              Try Blender ! 😉 it's free! 😄
                emerald15
                Thanks so much Pilou. I've checked out the tuts & Blender looks exactly what I need and more. About to download it... I'll let you know how I get on... still a bit of a learning curve to climb! 😄
