    Moving grouped objects to new layer
    3 Posts 3 Posters 368 Views 3 Watching
      ptc123
      I often need to move a grouped object from one layer to another. Is there away to have the group take on the color of the new layer?
      • BoxB Offline
        Change the setting in the layers window via the little submenu to Color by layer.
        Yours will look a bit different as this is the PC version.
        • TIGT Online
          Alternatively - if you don't want to color everything by layer [i.e. only some objects to get their layer's color], then you can use Ruby to get the layer of the selected object[s] and then get the layer.color, from that you can make a new material [named after the layer] using that color's RGB specification, and apply that new material onto the selected object[s].
          By naming the material after the layer you can test if that material has been made previously, and reuse the existing material, rather than make a new material every time...
          I that's the requirement then I can easily post a code-snippet to do this...
