    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      With I-joist roofs don't think I would model in any of the web stiffeners, otherwise the model gets too heavy, same goes for small fasteners and hangers.
      I haven't even considered the option yet with the rafters resting on top of the beam (dropped ridge). The I-joist manufacturers do not allow notching at the top end and therefore a beveled bearing plate or strip is required with web stiffeners on both sides of the I-joist. Their detail shows a strap across the tops of the I-joists tying them together across the beam, I'm pretty familiar with this detail from some local jobs I've done recently. However, I'm also wondering about the beveled strip on top of the ridge beam, how is it made, thickness at the butt etc...
      With common sawn rafters how would you typically handle a dropped beam? Would you use a beveled strip or would you apply a birdsmouth cut at the ridge? I think I've seen both details but what is the preferred method if there is one.
      The problem is I'm not out in the field enough so I never get to see this stuff actually go together very often.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        When the plugin is loaded in a metric template it will now utilize a web dialog with metric sizes for glulam beams. The menu and glulam beam sizes are currently listed at the following link:
        404 - File or directory not found.
        (design.medeek.com)
        I probably don't list every combination possible or manufactured in each respective country or jurisdiction but hopefully I list the most common sizes. So far I have entered in data for the United Kingdom (Great Britain), South Africa, and Australia (and New Zealand).
        I can enter in more countries if provided the data (width, depth, locale name and ply thickness). Now that I have the web dialogs and html files setup it is not a big deal to add more entries.
        When the plugin is loaded in inches or feet then the US sizes or AWC NDS tables are loaded. So far I have only found one country that still uses the old units.
        (design.medeek.com)
        design.medeek.com
        • medeekM
          medeek
          Added dropped beam options for Gable Rafter Roof with Glulam Beam: Notched rafter and Bevelled plate.
          http://design.medeek.com/resources/images/truss_su37_800.jpg
          http://design.medeek.com/resources/images/truss_su38_800.jpg
          design.medeek.com
          • medeekM
            medeek
            Version 1.2.0 - 12.13.2015
            • Added ceiling joist option for Gable Rafter Roof.
            http://design.medeek.com/resources/images/truss_su39_800.jpg
            Note: In the image shown I have raised the ceiling joist 24", the default is zero, or resting on the top plate of the wall.
            design.medeek.com
            • medeekM
              medeek
              With regards to outlookers and I-joist roofs I also noticed in the TJ-4000 (Detail O) they only show the outlookers in a vertical orientation. Are we allowed to do a horizontal orientation (outlookers laid flat)? And if so how do we make that attachment?
              design.medeek.com
              • medeekM
                medeek
                Various configurations of a cambered truss:
                http://design.medeek.com/resources/truss/GEOMETRY/CAMBERED1.jpg
                design.medeek.com
                • medeekM
                  medeek
                  Things have been a little slow on the plugin development and also on visits to my plugin page the last few days as I have been busy working on some local engineering projects and have not had the time to work on any new features.
                  Then all of sudden this morning I noticed things were going a little wild on the site with a ton of traffic. Turns out my plugin has somehow found its way to the top of the stack on Extension Warehouse:
                  http://design.medeek.com/images/MISC/EXT_WAREHOUSE_12162015.jpg
                  Not sure how it ended up there but my server has registered a serious uptick in traffic.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.2.1- 12.16.2015
                    • Added gable end trusses (ladders) and ribbon boards to the floor truss type (Warren - System 42).
                    • Sheathing option enabled under advanced floor options for floor trusses.
                    http://design.medeek.com/resources/images/truss_su40_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.2.2 - 12.21.2015
                      • Added TJI Rafter Roof with Glulam Beam (all advanced options enabled).
                      • Added dropped beam option for TJI Rafter Roof with Glulam Beam: Bevelled plate
                      http://design.medeek.com/resources/images/truss_su41_800.jpg
                      http://design.medeek.com/resources/images/truss_su42_800.jpg
                      Note, the birdsmouth cut at the lower bearing point. What I am not showing is the additional web blocking (stiffeners) required at this bearing point and at the ridge beam, see TJI-4000 for more details.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.2.2 - 12.23.2015
                        • Structural outlookers notched around TJI top flange when oriented vertically, as per TJI manufacturer's structural details.
                        http://design.medeek.com/resources/images/truss_su43_800.jpg
                        The tails of the TJI joists at the overhangs is left untrimmed however it is very easy to trim the tail of the rafters as shown below to customize to your particular roof requirements.
                        http://design.medeek.com/resources/images/truss_su44_800.jpg
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.2.3 - 12.29.2015
                          • Added Hip Rafter Roof.
                          http://design.medeek.com/resources/images/truss_su45_800.jpg
                          A square hip roof (pyramid):
                          http://design.medeek.com/resources/images/truss_su46_800.jpg
                          I still need to add in the advanced options for this roof type (sheathing, fascia etc...) I'm also thinking about ceiling joists and how best to configure them. For low pitch hip roofs the ceiling joists near the hip ends will clash with the hip jack rafters unless they are oriented parallel to the jack rafters.
                          design.medeek.com
                          • medeekM
                            medeek
                            A more complex hip roof combined with some trusses. Note I have not trimmed back all of the rafters in the top image.
                            http://design.medeek.com/resources/images/truss_su47_800.jpg
                            I initially generated the hip roofs (two rectangles) and then deleted the appropriate members and trimmed the common rafters to create the valley jack rafters and cripple jack rafters. The valley rafter was created by copying an instance of one of the hip rafters and moving it into place. The end result is:
                            http://design.medeek.com/resources/images/truss_su48_800.jpg
                            Overall the process has been simplified by having the hip roof feature in the plugin. Trimming the members is the most time consuming, perhaps a more efficient trim tool can be devised so that intersecting members can be easily trimmed back to clean up a complex roof. Ultimately it would be cool to have the plugin automatically handle even more complex roofs such as this but that would take some serious programming.
                            Also note that I used a raised heel for the trusses so that the heel height and gutter line of the trusses matches that of the rafters.
                            design.medeek.com
                            • medeekM
                              medeek
                              On my Google+ page I posted some recent screenshots of the truss plugin output. One particular individual went on a rather long diatribe on the inferior nature of SketchUp as a design tool, I quote,
                              "Well, if you are obsessive compulsive, sketchup is your tool. But for people who like to get projects done, there are tools that know what wood is, what lumber is, and know what the construction code is and draw in the meaningless details for you... like framing and rafters.
                              SketchUp doesn't know what a solid is. Doesn't do edge detection. Doesn't know what physics is. Can't self simply. Doesn't understand physical continuity. Doesn't understand region of focus. Can't deal with camera and material intersection. SketchUp has one intuitive tool, the extrusion tool, and somehow left everything else to confusion."
                              Some of his arguments I might agree with but it seems like the design community is starting to embrace SketchUp, at least more than I had realized. What made you as a designer or DIY'er decide to use SketchUp versus other design software?
                              design.medeek.com
                              • medeekM
                                medeek
                                Note the cripple or stub ceiling joists in this picture:
                                http://www.hearlihy.com/iCongoProductImages/iCg_36790TrueScaleHippedRoof.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Testing out the hip roof feature with some more complex roof lines:
                                  http://design.medeek.com/resources/images/truss_su49_800.jpg
                                  http://design.medeek.com/resources/images/truss_su50_800.jpg
                                  http://design.medeek.com/resources/images/truss_su51_800.jpg
                                  The thing that jumps out at me right away is the ease with which I can generate the basic roof lines and most of the rafters. This particular roof required (4) rectangular roofs to generate all of the lines. The only thing that is missing is the valley rafters. To make this feature more functional for complex roofs I only need to have a tool that can generate valley rafters and trim back members to create the cripple rafters.
                                  design.medeek.com
                                    driven
                                    I have a vivid memory of the first time I used SU back in 2003...
                                    Suddenly, I felt like I was out in the yard, working on the lawn under blue a sky, with the sun shining...
                                    This simple environment was so removed from any other 'cad' dungeon I had attempted to use that it got me hooked...
                                    then, I discovered 'FollowMe' and soon after plugins...
                                    I went off SU during the early Google era, but was drawn back by the Fredo, Tig, Kirell, Morrisdov and other plugins of the time...
                                    happy new year
                                    • medeekM
                                      medeek
                                      I worked in the Aerospace industry for about 6 years prior to changing my focus to residential design and structural engineering. I had the unfortunate opportunity of having to use CATIA. This 3D design program feels like a dinosaur compared to anything I have ever used, and hopefully I never have to use it again. I also worked a lot with Solidworks, which I find a lot more modern and much more fun to use. I have created complete 3D residential designs using Solidworks that are fully parametric:
                                      (design.medeek.com)
                                      The big problem I had with Solidworks is the 2D drawing generation required a number of details added to the drawing sheets manually. Solidworks is very slow and heavy with manual sketches so I ended up reverting to AutoCAD which can handle very complex 2D drawings without so much as a flicker.
                                      Lately, I have moved completely away from Solidworks as a design tool because of the time it takes to generate models and also AutoCAD is where I end up when it comes generating the drawing set. However, a 3D model is always nice to have for ISO views and other reasons. I've briefly played with Chief Architect as a Solidworks replacement but I find it too limiting and I was not overly impressed.
                                      The one thing I really like about SketchUp is I can pass the model on to the client and they can quickly download and install the program (lightweight) and be up and running almost instantly. I wish the software had a few more tools built in like a mirror function etc... but overall it is a pretty good package especially when you consider that you can just download it for free and most plugins are relatively inexpensive.
                                      The big architectural firms typically use products like Revit, but the casual user and smaller design firms don't have that amount of budget to dump into software.
                                      design.medeek.com
                                      • pbacotP
                                        That Solidworks house model is cool. I always just thought of SolidWorks for mechanical, industrial, and product design.
                                        • medeekM
                                          medeek
                                          This is unrelated to the functionality of the plugin but I managed after two days of pulling my hair out to somehow get the PayPal Express Checkout to work on the site. A number of clients had been requesting the PayPal option rather than use their credit cards over the internet.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Looking at cantilevered trusses tonight. The use of a wedge, slider or strut depends on the amount of the overhang and in some cases if the overhang (cantilever) is within the scarf cut of the top chord no additional member is required, see image below:
                                            http://design.medeek.com/images/misc/cantilevertruss2.jpg
                                            Notice how the web strut is centered over the point of bearing with the long cantilever. Also notice that the panel point placement of this fink truss was not altered with the addition of the cantilever.
                                            Basically this will be a new truss family and I'll start with the fink truss and take it from there. If anyone has shop drawing from truss plants they are willing to share that show different configurations of a cantilever truss, that would be very helpful.
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 76
                                            • 77
                                            • 10 / 77
