    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      After doing a bit of digging around on the internet I'm not sure standardized metric sizes will be something that is achievable.
      For example two different size tables for glulam beams from two different manufacturers in New Zealand (both conform to the AS/NZS 1328 Standard):
      http://design.medeek.com/images/misc/GLULAM_SIZES_NZ.jpg
      The various widths and depths are all over the board. Is there even a standardized ply thickness? Looking at these tables I cannot tell.
      Perhaps other countries in Europe, Asia and Africa have more standardized methods like the United States.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • facerF
        facer
        In Victoria Australia there are several sources that should be the
        same as NZ.
        One Example is noted below,
        Refer to p 10 - p 13 in the pdf document:
        http://www.wpv.org.au/docs/STPG.pdf
        Wood Products Victoria (WPV)
        The goal of Wood Products Victoria (WPV) is to ensure that sustainable timber and wood products grown, harvested, processed, manufactured or sold within Victoria or by Victorian-based businesses are supported by:
        › informed research
        › credible technical publications
        › comprehensive customer information, and
        › positive product and market development.
        Wood Products Victoria Ltd was established in June 2006.
        The Board of Directors includes representatives of timber growers, manufacturers, distributors and retailers who wish to ensure the ongoing viability of this sustainable, natural building resource.
        For further information about WPV and its activities please email info@wpv.org.au or
        call (61 3) 9611 9042.
        • medeekM
          medeek
          South Africa is a bit different, the two predominant laminated beam types appear to be Pine and Saligna.
          Pine laminated beams seem to be very standardized and straight forward.
          Widths: 27, 40, 65, 97, 135, 165.
          Depths range from 99 to 695
          with a 33mm ply thickness.
          Saligna beams are a bit more interesting.
          Widths: 25, 38, 50, 63, 89, 114, 140, 165
          Depths: 67, 89, 111, 133, 156, 178, 200, 222, 244, 267, 289, 311, 333, 356, 378, 400, 422, 444, 467, 489, 511, 533, 556, 578, 600...
          Ply thickness appears to be 22mm but you will notice it doesn't divide evenly into any of the depths. The actual ply thickness appears to be approximlately 7/8 inches or 22.225mm.
          Of course I did find some manufacturers whose widths and depths varied from these numbers but most manufacturers complying with SANS1460 generally follow the sizes above.
          design.medeek.com
          • medeekM
            medeek
            I may have spoken too soon on Australia and New Zealand. There is an interesting table at this link:
            Fastly error: unknown domain 151.101.66.216
            (www.woodsolutions.com.au)
            Which gives some standard sizes based on Grade. It states that these are the nominal beam widths and depths, I'm not sure if that is the actual size but I will assume so for now.
            Some of these depths would suggest that the typical ply thickness is 30mm however there are also quite a few depths where this 30mm does not work. Either there is a different ply thickness for these other depths or they are planing down the larger beams to get to this size.
            For example within GL18 the following depths exist: 270, 280, 300, 315, 330. 270, 300, and 330 fit nicely with a 30mm ply thickness, how is the 280 and 315 constructed?
            design.medeek.com
            • medeekM
              medeek
              Here is quick model of the wall framing associated with a gable roof with a glulam beam:
              Beam Pocket with 6x6 post:
              http://design.medeek.com/resources/images/truss_su32_800.jpg
              Gable wall and eave wall intersection:
              http://design.medeek.com/resources/images/truss_su33_800.jpg
              Overview of Model:
              http://design.medeek.com/resources/images/truss_su35_800.jpg
              design.medeek.com
              • medeekM
                medeek
                I've added an extra input for the beam which allows ones to specify the overhang of the beam from the outside of the wall. With zero overhang the beam will be flush with the wall framing and not exposed. If the beam overhang is less than the gable overhang, the fly will be as shown below (up to the roof peak). If the beam overhang is greater than the gable overhang it will project past and the fly will adjust accordingly. The beam overhang is not restricted in any manner.
                http://design.medeek.com/resources/images/truss_su36_800.jpg
                design.medeek.com
                • medeekM
                  medeek
                  I remember a few years back when I was in college and working a side job as a construction laborer we framed up a roof similar to this. The rafters were large I-Joists (TJI 560 equiv.) and were hangered from the glulam beam. The beam was probably almost 2 feet deep. I just remember I was glad I was cutting the blocking on the miter saw and not the one at the peak of the roof setting the rafters into the hangers.
                  With that being said I am wondering how often I-Joists are used in this type of application versus common lumber. I can probably add in an option to use them instead of common lumber. One question I have though is what to do at the other end, where they bear at the wall. I would need to study this further.
                  design.medeek.com
                  • pbacotP
                    The I-joists are used often here in northern California--I couldn't say HOW often. Not a great deal. I know that on the last project we tried to use them, due to the inability to cut them for various conditions, and the special requirements for bearing, and relative strength, we changed the design to microlams. They are also not as easy in fire rated assemblies.
                    You are making quite a huge extension! Are various members produced in components for modification afterwards? For example one were to modify all tails. I say this because, obviously you are getting close to realistic representation, but if one is seriously using this to show an actual structures, they will want to add modifications, which occur in every building and can't be put into a plugin.
                    • medeekM
                      medeek
                      Fortunately, someone pointed this out to me fairly early on so I have made it a point to make certain elements components and groups in a sensible fashion.
                      Common trusses and rafters are always components so that modifying tails etc... can be done quickly and easily. Other items such as fascia, outlookers, sheathing, beams etc... are not components but groups (solids).
                      Also now that I think about it the outlookers should also be components rather than just groups, added to the "todo" list.
                      design.medeek.com
                      • medeekM
                        medeek
                        Glulam beams in the UK seems to be fairly standardized:
                        Standard Widths: 90, 115, 140
                        Depths: 225, 270, 315,360, 405, 450, 495
                        Ply: 45mm
                        design.medeek.com
                        • medeekM
                          medeek
                          All of the pertinent details for I-Joists can be found here:
                          Site not found · DreamHost
                          The owner of this domain has not yet uploaded their website.
                          (www.woodbywy.com)
                          All have to think about this one. The problem with I-joists is the bevel cuts are more difficult since it requires more operations to model. The outlookers at the gable ends would need to notch around the top flange of the I-joist. A double or single bearing plate is required at the ridge or hangers from the beam, notching at the high end of the roof joist is not allowed. Birdsmouth cut at the low end of the joist is allowed but requires web stiffeners on both sides of the joist.
                          If I can figure out a good method of making the beveled cuts of complicated profiles that would greatly facilitate things.
                          Update:
                          I think if I actually model the I-Joist as three groups, make all the necessary cuts and then union them together I may be able to stick with my simple modeling method points -> face -> pushpull
                          design.medeek.com
                          • medeekM
                            medeek
                            With I-joist roofs don't think I would model in any of the web stiffeners, otherwise the model gets too heavy, same goes for small fasteners and hangers.
                            I haven't even considered the option yet with the rafters resting on top of the beam (dropped ridge). The I-joist manufacturers do not allow notching at the top end and therefore a beveled bearing plate or strip is required with web stiffeners on both sides of the I-joist. Their detail shows a strap across the tops of the I-joists tying them together across the beam, I'm pretty familiar with this detail from some local jobs I've done recently. However, I'm also wondering about the beveled strip on top of the ridge beam, how is it made, thickness at the butt etc...
                            With common sawn rafters how would you typically handle a dropped beam? Would you use a beveled strip or would you apply a birdsmouth cut at the ridge? I think I've seen both details but what is the preferred method if there is one.
                            The problem is I'm not out in the field enough so I never get to see this stuff actually go together very often.
                            design.medeek.com
                            • medeekM
                              medeek
                              When the plugin is loaded in a metric template it will now utilize a web dialog with metric sizes for glulam beams. The menu and glulam beam sizes are currently listed at the following link:
                              404 - File or directory not found.
                              (design.medeek.com)
                              I probably don't list every combination possible or manufactured in each respective country or jurisdiction but hopefully I list the most common sizes. So far I have entered in data for the United Kingdom (Great Britain), South Africa, and Australia (and New Zealand).
                              I can enter in more countries if provided the data (width, depth, locale name and ply thickness). Now that I have the web dialogs and html files setup it is not a big deal to add more entries.
                              When the plugin is loaded in inches or feet then the US sizes or AWC NDS tables are loaded. So far I have only found one country that still uses the old units.
                              (design.medeek.com)
                              design.medeek.com
                              • medeekM
                                medeek
                                Added dropped beam options for Gable Rafter Roof with Glulam Beam: Notched rafter and Bevelled plate.
                                http://design.medeek.com/resources/images/truss_su37_800.jpg
                                http://design.medeek.com/resources/images/truss_su38_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.2.0 - 12.13.2015
                                  • Added ceiling joist option for Gable Rafter Roof.
                                  http://design.medeek.com/resources/images/truss_su39_800.jpg
                                  Note: In the image shown I have raised the ceiling joist 24", the default is zero, or resting on the top plate of the wall.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    With regards to outlookers and I-joist roofs I also noticed in the TJ-4000 (Detail O) they only show the outlookers in a vertical orientation. Are we allowed to do a horizontal orientation (outlookers laid flat)? And if so how do we make that attachment?
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Various configurations of a cambered truss:
                                      http://design.medeek.com/resources/truss/GEOMETRY/CAMBERED1.jpg
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Things have been a little slow on the plugin development and also on visits to my plugin page the last few days as I have been busy working on some local engineering projects and have not had the time to work on any new features.
                                        Then all of sudden this morning I noticed things were going a little wild on the site with a ton of traffic. Turns out my plugin has somehow found its way to the top of the stack on Extension Warehouse:
                                        http://design.medeek.com/images/MISC/EXT_WAREHOUSE_12162015.jpg
                                        Not sure how it ended up there but my server has registered a serious uptick in traffic.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.2.1- 12.16.2015
                                          • Added gable end trusses (ladders) and ribbon boards to the floor truss type (Warren - System 42).
                                          • Sheathing option enabled under advanced floor options for floor trusses.
                                          http://design.medeek.com/resources/images/truss_su40_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.2.2 - 12.21.2015
                                            • Added TJI Rafter Roof with Glulam Beam (all advanced options enabled).
                                            • Added dropped beam option for TJI Rafter Roof with Glulam Beam: Bevelled plate
                                            http://design.medeek.com/resources/images/truss_su41_800.jpg
                                            http://design.medeek.com/resources/images/truss_su42_800.jpg
                                            Note, the birdsmouth cut at the lower bearing point. What I am not showing is the additional web blocking (stiffeners) required at this bearing point and at the ridge beam, see TJI-4000 for more details.
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 76
                                            • 77
                                            • 10 / 77
