Request: Quarry Tile
Does anyone have a quarry floor tile texture they are willing to share?
What exactly is a quarry floor?
It's a type of ceramic floor tile, usually red in color, 6x6 in size. Frequently used in commercial kitchens (in the U.S.)
I should have something useful. I'll check when I'll be back to my comp.
Ok, how about this one? Made it from scratch.
Massimo yet again to the rescue, dude you are the texture maestro.
Amazing Massimo and a nice large area
Thank you very much, Massimo. Can you share some hints how to combine them in one material in Thea?
No problem guys. Just a quick try and the maps have also some flaws.
Here you have something. Just a start. As you can see I played a lot with tonemapping for the maps in Thea. Of course the settings are related to the finish of the material you want to achieve and a lot scene-dependent. In this example I've used displacement so the normal map was not needed.
Quarry tiles.mat.zip -
Thank you again!
Thanks greatly, Massimo. That is exactly what I need.
Great.
