    Subdividing with sketchup?
    7 Posts 4 Posters 997 Views 4 Watching
      DreamPsi
      ok so I know there are subdivide plugins for sketchup already like artisian tools and or that new one catmull tool, but it seems that both of these do subdive but the break the original
      form
      IE: When using it on a simple cube it turns the cube into a sphere. I just want to know if there is any way to just subdive the surfaces without transforming it.
      like in maya u can subdivide the number of faces per face... by the width of it x(axis) or just by its y and or z or combinations between them and it wont transform it it simple gives it more faces.
        or this less complex free one SplitUp by Rich O Brien / Tig (?)
        http://sketchucation.com/forums/download/file.php?id=135344
          Try this new one some complete! S4U Divide by Su4You 😉
            Face SPlit by Renderiza
            Split Tools by TIG
            TIG SPherizer
            Here Tig SPherizer
            http://sketchucation.com/forums/download/file.php?id=105085
              DreamPsi
              brilliant thanks
              • HornOxxH Offline
                HornOxx
                maybe Julia Christina Eneroth´s "Fractal Terrain Eroder" plugin could be interesting for you as well?
                In addition to subdividing by triangulation by a desired number of iterations, the plugin also is able to deform the chosen face(s).
                http://sketchucation.com/pluginstore?pln=ene_fractalTerrain_v1.0.0_2
                here is an example
                http://sketchucation.com/forums/viewtopic.php?f=81%26amp;t=62966
                never trust a skinny cook
                • panixiaP Offline
                  panixia
                  also take a look at "connect" tool from thomthom's quadface tools.. that gives you greater control on number/pinching/cornering of loops/topology!
