    Is any plugin to create camera views all around an object ?
    12 Posts 8 Posters 1.6k Views 8 Watching
    • ely862meE Offline
      ely862me
      One I know it was flightpath and another way is to use a circle and cameras all around .
      http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=2583
      Elisei (sketchupper)
      Come and See EliseiDesign
      • cottyC Offline
        cotty
        You can create a template file with different scenes, see this example:
        my SketchUp gallery
        • ntxdaveN Offline
          ntxdave
          @derei said:
          I know it was a plugin which one could use to export a series of images taken all around a object, then you could embed that with a js code in a web page to have like a "turntable view" of that item.
          I am in need of such a plugin to set cameras (or scenes) around a object at regulate intervals.
          Maybe you can point me to one.
          Cheers.
          You might also consider another approach. Instead of a series of images and a js, you might want to look at tools that will present your model in a WebGL or similar format that can be displayed via links on a web page. I would suggest you explore something like:
          Spread3D: http://review.spread3d.com/
          SketchUcation's ED3GE: http://edg3d.io/
          CL3VR: https://www.cl3ver.com/
          SimLab Composer: http://simlab-soft.com/index.aspx (In particular their WebGL output)
          These 4 products allow you to rotate and pan your model through a web browser.
          You could also explore products like LumenRT, Lumion (in particular MyLumion) and Twinmotion. However, these 3 products are pretty expensive and you can only present you work on a web page as a movie. Well, I should say that the MyLumion will allow you to view your model (rotate) in a browser without being a movie.
          Hope this helps.............
          Press F1...thank me later
          • pbacotP Offline
            Not plugin, but if you are looking to have similar views from various sides: How about create a polygonal object like this, then "align view" to each side face. Then you can try the views and adjust the angle of the faces, raise, lower, or rotate the object, before you assign all the scenes. You can also export an animation.
            • dereiD Offline
              derei
              I believe I will have to go for such tricks eventually. That old plugin (made by google, i believe) is lost gone... if nobody remembers it.
              DESIGNER AND ARTIST DEREI.UK
                My oldie...
                http://sketchucation.com/pluginstore?pln=nudgeOrbit
                http://sketchucation.com/forums/viewtopic.php?p=238647#p238647
                Moves the camera around a specified point by preset angle increments - on button clicks, all you have to do each time, is to manually add a new scene-tab that will use that latest camera ...
                  driven
                  it's still available on-line https://code.google.com/p/swivel-viewer/downloads/detail?name=swivel-viewer-0.9.tar.gz
                  there are quite a few forum post about it as well, one even has most the code...
                  Web Exporter or swivel-viewer are good search terms...
                  • ntxdaveN Offline
                    ntxdave
                    I think we are each addressing a different aspect of the original post.
                    My response was concentrated more on the aspect of presenting the model via a web page/link. The tools I suggested provide the ability to view a SU model on a web page. In particular, the first set of tools I mentioned allow you to view, pan and rotate your model without doing anything special in SU (I.e your model can be a single scene). I think that the solutions are also more efficient in that you do not have to have a bunch of image files that you would then manipulate via javascript.
                    Again, just some thoughts 😎
                    • dereiD Offline
                      derei
                      Thanks. What I really needed was a way to set the cameras/scenes. Not to use it in web browser. But thanks for your idea. I may find it useful.
                      • dereiD Offline
                        derei
                        Thank you all for the solutions !
                        • sdmitchS Offline
                          sdmitch
                          Check out my "Spin It" plugin on my blog. It has options to spin the camera and record the scenes.
                          http://sdmitch.blogspot.com/
