    3D Truss Models
    1.5k Posts 32 Posters 1.8m Views 31 Watching
    • medeekM
      medeek
      Version 1.1.5 - 11.25.2015
      • Added Double Fink common truss type.
      • Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Double Fink) truss type.
      http://design.medeek.com/resources/images/truss_su23_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.1.6 - 11.26.2015
        • Added Fan and Mod Queen common truss types.
        • Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Fan & Mod Queen) truss types.
        http://design.medeek.com/resources/images/truss_su24_800.jpg
        Four more common truss types still need to be added:
        • Double Howe (6/6)
        • Mod Fan (8/4)
        • Triple Fink (8/7)
        • Triple Howe (8/8)
        For very large buildings one could also consider:
        • Quad Fan (10/5)
        • Quad Fink (10/9)
        • Quad Howe (10/10)
        • Quin Fan (12/6) ...
        A quad fink truss (10/9) with a raised heel (slider):
        http://www.selecttrusses.com/wp-content/uploads/Ag1.jpg
        design.medeek.com
        • jujuJ
          juju
          Wow, seriously, wow. How is the manual coming along?
          • medeekM
            medeek
            What format would be the best for the manual? I am kind of thinking along the lines of HTML documentation similar to the way SketchUp help files are organized but I'm still thinking about this.
            The biggest problem right now is the plugin has been rapidly progressing and evolving so its a bit hard to set out a manual that won't need major revisions/rewrite in the very near future.
            I'm thinking though in another month or two I should have something together.
            design.medeek.com
              You must also think for Multi-languages of your UI ! πŸ˜‰
              • medeekM
                medeek
                Valley Sets are here:
                http://design.medeek.com/resources/images/truss_su25_800.jpg
                Proceed with caution though I just put it together so it is still a bit rough around the edges. Further testing and refinement is necessary but it seems to be working fairly decently.
                Currently the main roof plane and two points need to be selected rather carefully I'm not sure I can do much about that, if not I will need to document in some detail how to use this function.
                design.medeek.com
                • medeekM
                  medeek
                  I've been thinking about adding some global settings so one can set language, defaults and other misc. items.
                  design.medeek.com
                  • medeekM
                    medeek
                    I've addressed a few bugs with the valley set algorithm and tested it in as many configurations and orientations as possible. It it more solid now. I suggest downloading the latest version of 1.1.7 that I just uploaded to the server.
                    Note that the plane of the main roof that is selected needs to be a rectangular shape at the moment to properly register (1st point selected). I usually just select the top face of one of the top chords of the trusses. The second point should be at the centerline of the last truss of the secondary roof line and at the ridge (peak) of this truss, the third point is also at the ridge (peak) but at a point towards the main roof. I really need to put the manual together to document this feature and how to use it, or at least a video.
                    I also updated the geometry algorithm slightly so that it adds additional verts a 48" o/c when the valley trusses get too large. This is keeping in line with standard practice on these types of valley sets. I can also make this an input if someone requests that it be such.
                    This update was not that complicated (valley sets) other than trying to figure out how to place the set based only on a plane and two points. Obtaining this information and then figuring out the math and code to compute the vertical distance between the bottom of the first valley truss where it rests on the main roof plane and the peak of the secondary roof line was the slightly painful part. The actual geometry of the valley set was surprisingly easy to code.
                    The real challenge will begin when I try to add some hip sets, I may push that out for awhile.
                    design.medeek.com
                    • medeekM
                      medeek
                      Here is an example of a large valley set with a Monopitch Primary Roof and a Common Secondary Roof. Notice the pitch of the monopitch roof is 6:12 while the secondary roof is 12:12.
                      http://design.medeek.com/resources/images/truss_su26_800.jpg
                      Rather than calculate the overhang for the secondary roof it is just as easy to to trim the truss tails back and adjust the fascia so that it lines up with the fascia of the main roof after the fact.
                      Even with all the automation of certain tasks there is still a good bit of manual editing required when complex roof lines are involved however I find that SketchUp has a very intuitive interface for trimming solids and once the basic geometry is there the rest is usually not too much trouble.
                      design.medeek.com
                      • medeekM
                        medeek
                        With the main roof sheathing:
                        http://design.medeek.com/resources/images/truss_su27_800.jpg
                        http://design.medeek.com/resources/images/truss_su28_800.jpg
                        design.medeek.com
                        • jujuJ
                          juju
                          I think the most universal is probably to have the manual in PDF?
                          • medeekM
                            medeek
                            I think I'll create in MS Word and then save it into PDF.
                            design.medeek.com
                            • medeekM
                              medeek
                              This revised code seems to work:
                              module Medeek_Engineering_Inc_Extensions
                              	module MedeekTrussPluginModuleLoader
                              	require 'sketchup.rb'
                              	require 'extensions.rb'
                              	require 'langhandler.rb'
                              	# Show the Ruby Console at startup so we can
                              	# see any programming errors we may make.
                              	# SKETCHUP_CONSOLE.show
                              	this_dir=File.dirname(__FILE__)
                              	# Fix for ruby 2.0
                              	if this_dir.respond_to?(;force_encoding)
                              		this_dir=this_dir.dup.force_encoding("UTF-8")
                              	PATH=this_dir
                              	entries=Dir.entries(this_dir)
                              	ext=".rbs"
                              	# Add a toolbar item to launch our plugin.
                              	toolbar = UI;;Toolbar.new "Medeek Truss"
                                   	cmd = UI;;Command.new("Draw Roof Truss") {
                              		Sketchup.load(File.join(this_dir,"MEDEEK_ROOF_TRUSS.rbs"))
                              		Medeek_Engineering_Inc_Extensions;;MedeekTrussPlugin;;MedeekMethods.roof_truss_family_menu
                                  		cmd.small_icon = "images/mdkplg_tool_icon16_2.png"
                                   		cmd.large_icon = "images/mdkplg_tool_icon24_2.png"
                                   		cmd.tooltip = "Medeek Truss"
                                  		cmd.status_bar_text = "Draw Roof Truss"
                                  		cmd.menu_text = "Roof Truss"
                                   		toolbar = toolbar.add_item cmd
                                   		# toolbar.show
                              	cmd2 = UI;;Command.new("Draw Floor Truss") {
                                     		Sketchup.load(File.join(this_dir,"MEDEEK_FLOOR_TRUSS.rbs"))
                              		Medeek_Engineering_Inc_Extensions;;MedeekTrussPlugin;;FloorTruss;;MedeekMethods.floor_truss_family_menu
                                  		cmd2.small_icon = "images/mdkplg_tool_icon16_3.png"
                                   		cmd2.large_icon = "images/mdkplg_tool_icon24_3.png"
                                   		cmd2.tooltip = "Medeek Truss"
                                  		cmd2.status_bar_text = "Draw Floor Truss"
                                  		cmd2.menu_text = "Floor Truss"
                                   		toolbar = toolbar.add_item cmd2
                                   		# toolbar.show
                              	cmd3 = UI;;Command.new("Draw Truss Set") {
                                     		Sketchup.load(File.join(this_dir,"MEDEEK_TRUSS_SET.rbs"))
                              		Medeek_Engineering_Inc_Extensions;;MedeekTrussPlugin;;TrussSet;;MedeekMethods.truss_set_family_menu
                                  		cmd3.small_icon = "images/mdkplg_tool_icon16_4.png"
                                   		cmd3.large_icon = "images/mdkplg_tool_icon24_4.png"
                                   		cmd3.tooltip = "Medeek Truss"
                                  		cmd3.status_bar_text = "Draw Truss Set"
                                  		cmd3.menu_text = "Truss Set"
                                   		toolbar = toolbar.add_item cmd3
                                   		# toolbar.show
                              	cmd4 = UI;;Command.new("Draw Roof Rafters") {
                                     		Sketchup.load(File.join(this_dir,"MEDEEK_ROOF_RAFTERS.rbs"))
                              		Medeek_Engineering_Inc_Extensions;;MedeekTrussPlugin;;RoofRafters;;MedeekMethods.roof_rafters_family_menu
                                  		cmd4.small_icon = "images/mdkplg_tool_icon16_5.png"
                                   		cmd4.large_icon = "images/mdkplg_tool_icon24_5.png"
                                   		cmd4.tooltip = "Medeek Truss"
                                  		cmd4.status_bar_text = "Draw Roof Rafters"
                                  		cmd4.menu_text = "Roof Rafters"
                                   		toolbar = toolbar.add_item cmd4
                                   		toolbar.show
                              	# Add a menu item to launch our plugin.
                              	submenu = UI.menu("Plugins").add_submenu("Medeek Truss")
                              	submenu.add_item(cmd)
                              	submenu.add_item(cmd2)
                              	submenu.add_item(cmd3)
                              	submenu.add_item(cmd4)
                              design.medeek.com
                              • medeekM
                                medeek
                                Now the largest file is only about 12,000 lines, a bit more manageable. If I spend some time cleaning it up and compressing redundant sections I can probably get it to half that amount.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Up until now I have maintained all of the code in one large file. However I keep adding more features so I need to split it out into multiple files to keep things manageable. My new load .rb file is attempting to use a method I found on another board but I'm getting a situation where the first click on the icon loads the plugin as it should however subsequent clicks on the menu or icon do nothing.
                                  The problem is that after the menu item runs once it will not fire again.
                                  Here is a snippet of the Medeek_Load.rb file :
                                  	# Fix for ruby 2.0
                                  	if this_dir.respond_to?(:force_encoding)
                                  	PATH=this_dir
                                  	ext=".rbs"
                                  	toolbar = UI::Toolbar.new "Medeek Truss"
                                  cmd = UI::Command.new("Draw Roof Truss") {
                                  	# toolbar.show
                                  	cmd2 = UI::Command.new("Draw Floor Truss") {
                                  	# toolbar.show
                                  	cmd3 = UI::Command.new("Draw Truss Set") {
                                  	toolbar.show
                                  	cmd4 = UI::Command.new("Draw Roof Rafters") {
                                  	toolbar.show
                                  	submenu.add_item("Roof Truss") { Sketchup.load(File.join(this_dir,"MEDEEK_ROOF_TRUSS.rbs")) }
                                  	submenu.add_item("Floor Truss") { Sketchup.load(File.join(this_dir,"MEDEEK_FLOOR_TRUSS.rbs")) }
                                  	submenu.add_item("Truss Set") { Sketchup.load(File.join(this_dir,"MEDEEK_TRUSS_SET.rbs")) }
                                  	submenu.add_item("Roof Rafters") { Sketchup.load(File.join(this_dir,"MEDEEK_ROOF_RAFTERS.rbs")) }
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    Coding related queries will probably be addressed a lot faster if you post them in the developers section of the forum?
                                    404 Not Found
                                    (sketchucation.com)
                                    • medeekM
                                      medeek
                                      Version 1.1.8 - 12.07.2015
                                      • Added Gable Rafter Roof.
                                      • Advanced options enabled for gable rafter roofs (sub-fascia, outlookers, sheathing, and rakeboards).
                                      • New submenu item and toolbar icon added for rafter roof type.
                                      • Plugin divided into multiple files for ease of management.
                                      http://design.medeek.com/resources/images/truss_su29_800.jpg
                                      Structural outlookers for this type of a roof are still somewhat of a question. If they are horizontal it makes sense to notch the gable rafter but what if they are vertical?
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.1.8 - 12.08.2015
                                        • Structural Outlookers enabled for gable rafter roofs (vertical & horizontal).
                                        http://design.medeek.com/resources/images/truss_su30_800.jpg
                                        Notice in this case I have left the gable rafter in place but notched clean through it, so essentially it is blocking. However, I have also given the option for removing the gable rafter entirely. You will also notice that the gable rafter is the same depth as the outlookers, when you choose "CUSTOM" for the gable end rafter it allows one to specify the depth of this rafter.
                                        When structural outlookers are used in a vertical orientation it is common practice to have them bear directly on the double top plate of the gable wall (balloon framed to roof). If there is some configuration that is standard in your neck of the woods that I am missing please let me know. I am currently providing three different configurations for the gable end rafters.
                                        I think I am ready to now attack the gable rafter roof with glulam beam.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Admittedly the user interface is still very rough around the edges. One thing I've started working on is making the default values assume the last values inputted by the user. The code is fairly simple but updating all of the different menus is tedious because I have quite a few truss types now. This should make creating multiple truss sets in a document even quicker since parameters like roof pitch, overhangs and heel heights are typically the same for a given structure.
                                          To test this functionality currently, download the latest version 1.1.8 and test the common truss types (Imperial Units). I will be updating all menus so that this functionality is present.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            I'm wondering with my rafter roof if I should provide an option to draw ceiling joists?
                                            http://design.medeek.com/resources/images/SAMPLE_RAFTER.jpg
                                            design.medeek.com
                                            • 76
                                            • 77
                                            • 8 / 77
