    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      Outlookers enabled under advanced roof options for Monopitch truss types.
      http://design.medeek.com/resources/images/truss_su21_800.jpg
      Also fixed all truss types so that the outlookers are measured from the bottom. I also added the option to include outlookers at the peak.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Does anyone have any good resources for working with dynamic components within the API? I really would like to make the top chords dynamic so that the overhang can be adjusted after the fact if necessary.
        design.medeek.com
        • medeekM
          medeek
          Version 1.1.4 - 11.25.2015
          Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Fink) truss type.
          Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Fink) truss type with raised heel (vertical w/ strut).
          http://design.medeek.com/resources/images/truss_su22_800.jpg
          Notice that when structural outlookers are selected the top chord of the gable end truss is dropped accordingly. This may look simple now that I've got it working (at least for one type of common truss) but the amount of logic required to make sure everything comes out right is somewhat mind boggling.
          design.medeek.com
          • pbacotP
            Nice work. It is scary how much you are able to do and what goes into all this. The clean output is what we see--and so many options worked in.
            For texture I think you also have to look into ruby to find out how to orient it the way you want. It doesn't matter what texture you use.
            There are some good NPR wood textures in the Sketchucation store, but I am not sure if it contains one that would give you the fresh douglas fir look.
            • medeekM
              medeek
              Thank-you for the vote of confidence. Sometimes I feel like I am digging a bit deep when it comes to all of these options it certainly adds to the amount of code required and the complexity. Some options are also dependent on others so it becomes a tangled web that requires careful analysis to mare sure that certain options can still work when others are not enabled. The good news is that I've probably got most of the options added to the fink truss that I will ever add so further complexity should not be too much of a problem. Now it is just a matter of adding different truss types, and other related items, more breadth and less depth.
              If it can be mathematically modeled then it can be programmed into the plugin. What you are seeing on your screen or in SketchUp is a visual representation of a mathematical model of the truss group and associated framing.
              design.medeek.com
              • medeekM
                medeek
                Version 1.1.5 - 11.25.2015
                • Added Double Fink common truss type.
                • Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Double Fink) truss type.
                http://design.medeek.com/resources/images/truss_su23_800.jpg
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.1.6 - 11.26.2015
                  • Added Fan and Mod Queen common truss types.
                  • Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Fan & Mod Queen) truss types.
                  http://design.medeek.com/resources/images/truss_su24_800.jpg
                  Four more common truss types still need to be added:
                  • Double Howe (6/6)
                  • Mod Fan (8/4)
                  • Triple Fink (8/7)
                  • Triple Howe (8/8)
                  For very large buildings one could also consider:
                  • Quad Fan (10/5)
                  • Quad Fink (10/9)
                  • Quad Howe (10/10)
                  • Quin Fan (12/6) ...
                  A quad fink truss (10/9) with a raised heel (slider):
                  http://www.selecttrusses.com/wp-content/uploads/Ag1.jpg
                  design.medeek.com
                  • jujuJ
                    juju
                    Wow, seriously, wow. How is the manual coming along?
                    • medeekM
                      medeek
                      What format would be the best for the manual? I am kind of thinking along the lines of HTML documentation similar to the way SketchUp help files are organized but I'm still thinking about this.
                      The biggest problem right now is the plugin has been rapidly progressing and evolving so its a bit hard to set out a manual that won't need major revisions/rewrite in the very near future.
                      I'm thinking though in another month or two I should have something together.
                      design.medeek.com
                        You must also think for Multi-languages of your UI ! πŸ˜‰
                        • medeekM
                          medeek
                          Valley Sets are here:
                          http://design.medeek.com/resources/images/truss_su25_800.jpg
                          Proceed with caution though I just put it together so it is still a bit rough around the edges. Further testing and refinement is necessary but it seems to be working fairly decently.
                          Currently the main roof plane and two points need to be selected rather carefully I'm not sure I can do much about that, if not I will need to document in some detail how to use this function.
                          design.medeek.com
                          • medeekM
                            medeek
                            I've been thinking about adding some global settings so one can set language, defaults and other misc. items.
                            design.medeek.com
                            • medeekM
                              medeek
                              I've addressed a few bugs with the valley set algorithm and tested it in as many configurations and orientations as possible. It it more solid now. I suggest downloading the latest version of 1.1.7 that I just uploaded to the server.
                              Note that the plane of the main roof that is selected needs to be a rectangular shape at the moment to properly register (1st point selected). I usually just select the top face of one of the top chords of the trusses. The second point should be at the centerline of the last truss of the secondary roof line and at the ridge (peak) of this truss, the third point is also at the ridge (peak) but at a point towards the main roof. I really need to put the manual together to document this feature and how to use it, or at least a video.
                              I also updated the geometry algorithm slightly so that it adds additional verts a 48" o/c when the valley trusses get too large. This is keeping in line with standard practice on these types of valley sets. I can also make this an input if someone requests that it be such.
                              This update was not that complicated (valley sets) other than trying to figure out how to place the set based only on a plane and two points. Obtaining this information and then figuring out the math and code to compute the vertical distance between the bottom of the first valley truss where it rests on the main roof plane and the peak of the secondary roof line was the slightly painful part. The actual geometry of the valley set was surprisingly easy to code.
                              The real challenge will begin when I try to add some hip sets, I may push that out for awhile.
                              design.medeek.com
                              • medeekM
                                medeek
                                Here is an example of a large valley set with a Monopitch Primary Roof and a Common Secondary Roof. Notice the pitch of the monopitch roof is 6:12 while the secondary roof is 12:12.
                                http://design.medeek.com/resources/images/truss_su26_800.jpg
                                Rather than calculate the overhang for the secondary roof it is just as easy to to trim the truss tails back and adjust the fascia so that it lines up with the fascia of the main roof after the fact.
                                Even with all the automation of certain tasks there is still a good bit of manual editing required when complex roof lines are involved however I find that SketchUp has a very intuitive interface for trimming solids and once the basic geometry is there the rest is usually not too much trouble.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  With the main roof sheathing:
                                  http://design.medeek.com/resources/images/truss_su27_800.jpg
                                  http://design.medeek.com/resources/images/truss_su28_800.jpg
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    I think the most universal is probably to have the manual in PDF?
                                    • medeekM
                                      medeek
                                      I think I'll create in MS Word and then save it into PDF.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        This revised code seems to work:
                                        module Medeek_Engineering_Inc_Extensions
                                        	module MedeekTrussPluginModuleLoader
                                        	require 'sketchup.rb'
                                        	require 'extensions.rb'
                                        	require 'langhandler.rb'
                                        	# Show the Ruby Console at startup so we can
                                        	# see any programming errors we may make.
                                        	# SKETCHUP_CONSOLE.show
                                        	this_dir=File.dirname(__FILE__)
                                        	# Fix for ruby 2.0
                                        	if this_dir.respond_to?(;force_encoding)
                                        		this_dir=this_dir.dup.force_encoding("UTF-8")
                                        	PATH=this_dir
                                        	entries=Dir.entries(this_dir)
                                        	ext=".rbs"
                                        	# Add a toolbar item to launch our plugin.
                                        	toolbar = UI;;Toolbar.new "Medeek Truss"
                                             	cmd = UI;;Command.new("Draw Roof Truss") {
                                        		Sketchup.load(File.join(this_dir,"MEDEEK_ROOF_TRUSS.rbs"))
                                        		Medeek_Engineering_Inc_Extensions;;MedeekTrussPlugin;;MedeekMethods.roof_truss_family_menu
                                            		cmd.small_icon = "images/mdkplg_tool_icon16_2.png"
                                             		cmd.large_icon = "images/mdkplg_tool_icon24_2.png"
                                             		cmd.tooltip = "Medeek Truss"
                                            		cmd.status_bar_text = "Draw Roof Truss"
                                            		cmd.menu_text = "Roof Truss"
                                             		toolbar = toolbar.add_item cmd
                                             		# toolbar.show
                                        	cmd2 = UI;;Command.new("Draw Floor Truss") {
                                               		Sketchup.load(File.join(this_dir,"MEDEEK_FLOOR_TRUSS.rbs"))
                                        		Medeek_Engineering_Inc_Extensions;;MedeekTrussPlugin;;FloorTruss;;MedeekMethods.floor_truss_family_menu
                                            		cmd2.small_icon = "images/mdkplg_tool_icon16_3.png"
                                             		cmd2.large_icon = "images/mdkplg_tool_icon24_3.png"
                                             		cmd2.tooltip = "Medeek Truss"
                                            		cmd2.status_bar_text = "Draw Floor Truss"
                                            		cmd2.menu_text = "Floor Truss"
                                             		toolbar = toolbar.add_item cmd2
                                             		# toolbar.show
                                        	cmd3 = UI;;Command.new("Draw Truss Set") {
                                               		Sketchup.load(File.join(this_dir,"MEDEEK_TRUSS_SET.rbs"))
                                        		Medeek_Engineering_Inc_Extensions;;MedeekTrussPlugin;;TrussSet;;MedeekMethods.truss_set_family_menu
                                            		cmd3.small_icon = "images/mdkplg_tool_icon16_4.png"
                                             		cmd3.large_icon = "images/mdkplg_tool_icon24_4.png"
                                             		cmd3.tooltip = "Medeek Truss"
                                            		cmd3.status_bar_text = "Draw Truss Set"
                                            		cmd3.menu_text = "Truss Set"
                                             		toolbar = toolbar.add_item cmd3
                                             		# toolbar.show
                                        	cmd4 = UI;;Command.new("Draw Roof Rafters") {
                                               		Sketchup.load(File.join(this_dir,"MEDEEK_ROOF_RAFTERS.rbs"))
                                        		Medeek_Engineering_Inc_Extensions;;MedeekTrussPlugin;;RoofRafters;;MedeekMethods.roof_rafters_family_menu
                                            		cmd4.small_icon = "images/mdkplg_tool_icon16_5.png"
                                             		cmd4.large_icon = "images/mdkplg_tool_icon24_5.png"
                                             		cmd4.tooltip = "Medeek Truss"
                                            		cmd4.status_bar_text = "Draw Roof Rafters"
                                            		cmd4.menu_text = "Roof Rafters"
                                             		toolbar = toolbar.add_item cmd4
                                             		toolbar.show
                                        	# Add a menu item to launch our plugin.
                                        	submenu = UI.menu("Plugins").add_submenu("Medeek Truss")
                                        	submenu.add_item(cmd)
                                        	submenu.add_item(cmd2)
                                        	submenu.add_item(cmd3)
                                        	submenu.add_item(cmd4)
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Now the largest file is only about 12,000 lines, a bit more manageable. If I spend some time cleaning it up and compressing redundant sections I can probably get it to half that amount.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Up until now I have maintained all of the code in one large file. However I keep adding more features so I need to split it out into multiple files to keep things manageable. My new load .rb file is attempting to use a method I found on another board but I'm getting a situation where the first click on the icon loads the plugin as it should however subsequent clicks on the menu or icon do nothing.
                                            The problem is that after the menu item runs once it will not fire again.
                                            Here is a snippet of the Medeek_Load.rb file :
                                            	# Fix for ruby 2.0
                                            	if this_dir.respond_to?(:force_encoding)
                                            	PATH=this_dir
                                            	ext=".rbs"
                                            	toolbar = UI::Toolbar.new "Medeek Truss"
                                            cmd = UI::Command.new("Draw Roof Truss") {
                                            	# toolbar.show
                                            	cmd2 = UI::Command.new("Draw Floor Truss") {
                                            	# toolbar.show
                                            	cmd3 = UI::Command.new("Draw Truss Set") {
                                            	toolbar.show
                                            	cmd4 = UI::Command.new("Draw Roof Rafters") {
                                            	toolbar.show
                                            	submenu.add_item("Roof Truss") { Sketchup.load(File.join(this_dir,"MEDEEK_ROOF_TRUSS.rbs")) }
                                            	submenu.add_item("Floor Truss") { Sketchup.load(File.join(this_dir,"MEDEEK_FLOOR_TRUSS.rbs")) }
                                            	submenu.add_item("Truss Set") { Sketchup.load(File.join(this_dir,"MEDEEK_TRUSS_SET.rbs")) }
                                            	submenu.add_item("Roof Rafters") { Sketchup.load(File.join(this_dir,"MEDEEK_ROOF_RAFTERS.rbs")) }
                                            design.medeek.com
                                            • 76
                                            • 77
                                            • 8 / 77
