    SU 2016 Generate Report
    16 Posts 7 Posters 2.3k Views 7 Watching
    • ashscottA Offline
      ashscott
      As far as I can tell, to get quantities, I have to use the built in template and can't make my own template that includes quantities without copying the built-in one...
      Just some stuff I do with Sketchup.
        Did you try creating a new report (button at the bottom right) and adding Quantity as an attribute? This is just the start of creating a new report. I just added Quantity to the right hand column to include it in the report.
        • ashscottA Offline
          ashscott
          Yep, did that, but it simply shows the quantity as "1"
          Its as if there is another hidden attribute in the default quantity template
            I see. It's not so much that it shows the quantity as 1 but that it lists each component instance separately. Hmmm....
            • ashscottA Offline
              ashscott
              Exactly
              Bizarre functionality right?
                Yeah. I've not looked at this all that closely because I don't really need the capability for the work I do. I guess it's time to investigate, though.
                • ashscottA Offline
                  ashscott
                  I can definitely see the power that the Sketchup team has put into the reporting tool - maybe just needs a little polishing.
                  • jgbrock1J Offline
                    jgbrock1
                    with regards to reporting components, etc., you might find Estimator for SketchUp useful http://estimatorforsketchup.com
                    I needed a reporting solution and estimating system for my SketchUp models (as a home builder) so I created one to fill that void. We are offering premium members a 20% discount if interested (just started advertising on this site and will have the discount code posted soon) - not wanting to sound like a salesman, just offering a potential solution to check out, I know I was frustrated with the internal reporting capabilities natively in SU. My email address is john@estimatorforsketchup if you have any questions or need the promo code.
                    • jujuJ Offline
                      juju
                      John, there's absolutely no reason to be apologetic about creating a product that addresses a need and then making people aware of it. I hope you have some good sales!
                      • jgbrock1J Offline
                        jgbrock1
                        Thank you!
                        • TommyKT Offline
                          TommyK
                          In response to your problem with quantities. I had an issue where I used lots of instances of a component and many of the components had qty 1 and seemed to be duplicated. What caused this for me was that the instances of the components had different scales. So each unique scale created a new row in the report. This might be something that happens for all instances with different attributes (layers, name, etc?). Maybe it's something to look into? If you create a report and output all attributes, you might be able to spot the attribute that is differing for each instance.
                            Tommy, that is interesting although in the model I was using to check that, none of the instances had been scaled.
                            • ashscottA Offline
                              ashscott
                              Yeah im pretty confident that scaling is not the cause of the multiple instances...
                                Lê Việt Trường
                                I can make diffrence templates and run like in this video.
                                But how can i "export" these templates to run in another .skp file?
                                Does anyone know how, please help me,
                                https://www.youtube.com/watch?v=kwt7l2y4fUw
