    3D Truss Models
    1.5k Posts 31 Posters 978.0k Views 30 Watching
    • medeekM Offline
      medeek
      Version 3.1.9 - 11.25.2022
      • Enabled subtractive geometry for all shed rafter roofs.
      http://design.medeek.com/resources/trussplugin/images3/truss_su779_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.2.0 - 11.28.2022
        • Fixed a minor bug with the roof cladding thickness parameter when the materials option is toggled off.
        http://design.medeek.com/resources/trussplugin/images3/truss_su780_800.jpg
        Strange that I never noticed this bug before but I guess most of us turn on the materials option so that is probably why no one ever really noticed. I highly recommend turning on the materials options to get the full bang for your buck out of the plugin but in the rare chance you don't want to this bug fix will take care of the previous issue reported above.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.2.1 - 01.04.2024
          • Updated and adjusted the logging function and auto-update functions.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.2.2 - 01.11.2023
            • Enabled layer control integration with the Medeek Project extension.
            • Moved the Medeek Tools module to the Medeek Project extension.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.2.3 - 02.06.2023
              • Fixed an infinite loop bug for (full) roof returns on truss roofs.
              • Updated the subtract feature to include roof return rafters and gutter downspouts for truss roofs.
              http://design.medeek.com/resources/trussplugin/images3/truss_su781_800.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.2.4 - 02.09.2023
                • Enabled subtractive geometry for all complex rafter roofs.
                • Updated the subtract feature to include gutter downspouts for all rafter roofs.
                http://design.medeek.com/resources/trussplugin/images3/truss_su783_800.jpg
                http://design.medeek.com/resources/trussplugin/images3/truss_su782_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  !!!! BUG ALERT - SKETCHUP 2023 !!!!
                  I've just identified an issue with the Truss plugin and the current release of SU 2023.
                  Many of the tools within the Truss plugin still use the UI.inputbox module for simple menus, see example below:
                  https://global.discourse-cdn.com/sketchup/original/3X/3/9/393af1c82a2d55897198b1e8fc54b38533ace41b.jpeg
                  If you notice that this type of menu appears (not an HTML menu) then press alt-tab which will then require you to refocus on the menu with your mouse and will also allow it to function correctly.
                  I don't know all of the details however it appears that the backend framework has extensively changed and in the process a few focus bugs have slipped through and need to be ironed out with SU 2023. See status and more details at the thread below:
                  SketchUp 2023 - changes to UI.inputbox focus?
                  Question for the proper coders: A case of three ruby plugins; a plugin with a floating quad menu with my most-used commands - pressing items launches other plugins. a plugin that directly launches a UI.inputbox a plug…
                  SketchUp Community (forums.sketchup.com)
                  For now I would recommend staying with SU 2022 if you extensively use SketchUp combined with the Truss and Foundation plugins. However the alt-tab work around should also keep you up and running if you have already migrated to SU 2023.
                  I am hoping that minor update will be forthcoming in the near future from SketchUp, which will save me from having to rewrite a significant amount of code and pull me away from the Floor plugin development. If the bug is not fixed I will proceed to switch all remaining menus in the Truss and Foundation plugins to HTML dialog type menus, that process could take upwards of two to three weeks.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.2.5 - 06.17.2023
                    • Enabled a gable wall cut for attic trusses.
                    • Enabled a feature to selectively remove specific trusses from an attic truss assembly.
                    http://design.medeek.com/resources/trussplugin/images3/truss_su784_800.jpg
                    http://design.medeek.com/resources/trussplugin/images3/truss_su785_800.jpg
                    After making the tutorial video for the inclined walls yesterday it quickly became apparent to me that the features for dealing with attic trusses and their implementation are wholly inadequate.
                    The gable cut allows for one to then insert a hip wall into the opening created by the attic truss, which then further allows for windows and doors being inserted into the gable end of an attic truss.
                    When dormers are added to an attic truss as shown it is usually necessary to remove certain trusses that conflict with these dormers and then ladder framing is added to bridge the gap created. The selective truss removal feature will now allow for the removal of any specific number of trusses in a attic truss assembly. However note that it does not automatically insert any of the ladder framing for the roof or floor of the attic.
                    I will probably create a tutorial video explaining both of these features in more detail in the next couple of days.
                    design.medeek.com
                    • gullfoG Offline
                      gullfo
                      one consideration - a "half truss" for the section we're removing trusses - as the opposite roof section will still need a rafter at least, and potentially a cross-tie into the ridge beam on the doghouse?
                      Glenn
                      http://www.runnel.com
                      • medeekM Offline
                        medeek
                        Tutorial 21: Attic Trusses (14:26 min.)
                        A brief overview and demo of the Gable Wall Cut option and the selective truss removal feature.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.2.6 - 06.22.2023
                          • Enabled the "Edit Truss Assembly" function for all gambrel attic trusses.
                          • Enabled a gable wall cut for gambrel attic trusses.
                          • Enabled a feature to selectively remove specific trusses from gambrel attic truss assemblies.
                          http://design.medeek.com/resources/trussplugin/images3/truss_su787_800.jpg
                          http://design.medeek.com/resources/trussplugin/images3/truss_su788_800.jpg
                          There are still a number of advanced options that need to be completed for this truss type, namely soffit and fascia need to be added.
                          The ability to edit this truss type is a fairly significant upgrade.
                          design.medeek.com
                          • gullfoG Offline
                            gullfo
                            more thoughts on this - if you divide the trusses into parts - parta = main remaining assembly after section removal, part b = the vert roof (in this example), and part c = "flat roof" (in this example). and flip the truss (if possible) so only part of it needs to be componentized.
                            then you would have the trusses partly available for roof sections which would not have openings. the rest of the opening geometry would have to be manually assembled as part of adding the doghouse, access door etc.
                            Glenn
                            • medeekM Offline
                              medeek
                              Version 3.2.7 - 06.26.2023
                              • Fixed a bug with the truss removal feature.
                              • Enabled a feature to selectively remove specific trusses from common and monopitch truss assemblies.
                              http://design.medeek.com/resources/trussplugin/images3/truss_su789_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.2.7b - 06.28.2023
                                • Fixed a minor bug with the truss removal feature for all truss types.
                                *Note: This is a critical bug fix for common, monopitch, attic and gambrel attic trusses.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.2.8 - 07.05.2023
                                  • Enabled a ridge centering option for asymmetric gable rafter roofs.
                                  • Enabled a ridge centering option for asymmetric hip rafter roofs.
                                  http://design.medeek.com/resources/trussplugin/images3/ridge_center.gif
                                  http://design.medeek.com/resources/trussplugin/images3/truss_su794_800.jpg
                                  I think the non-centered ridge is the more correct of the two, but if you do want the centered ridge then it is also an option.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Tutorial 22: Asymmetric Roof Framing (8:17 min.)
                                    Centered vs. Non-centered ridges for asymmetric rafter roofs.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Tutorial 23: Licensing and Upgrades (11:59 min.)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Tutorial 24: Complex Roof Discussion and Limitations (10:43 min.)
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 3.2.9 - 08.28.2023
                                          Fixed a critical bug with the truss removal feature for truss sets.
                                          !!!! CRITICAL BUG FIX !!!!
                                          I highly recommend upgrading from versions 3.2.7 and 3.2.8.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 3.2.9b - 08.28.2023 thru 08.29.2023
                                            • Fixed a critical bug with the hip rafter roof module.
                                            Unfortunately I never noticed this error/bug because I usually test the plugin with the advanced options turned on automatically. If the advanced options are turned off and a hip roof is attempted and error will be thrown. This bug fix addresses that issue. I highly recommend upgrading to this latest version.
                                            design.medeek.com
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 72 / 76
