    3D Truss Models
    1.5k Posts 31 Posters 1.2m Views 30 Watching
    • medeekM Offline
      medeek
      Tutorial 21: Attic Trusses (14:26 min.)
      A brief overview and demo of the Gable Wall Cut option and the selective truss removal feature.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.2.6 - 06.22.2023
        • Enabled the "Edit Truss Assembly" function for all gambrel attic trusses.
        • Enabled a gable wall cut for gambrel attic trusses.
        • Enabled a feature to selectively remove specific trusses from gambrel attic truss assemblies.
        http://design.medeek.com/resources/trussplugin/images3/truss_su787_800.jpg
        http://design.medeek.com/resources/trussplugin/images3/truss_su788_800.jpg
        There are still a number of advanced options that need to be completed for this truss type, namely soffit and fascia need to be added.
        The ability to edit this truss type is a fairly significant upgrade.
        design.medeek.com
        • gullfoG Offline
          gullfo
          more thoughts on this - if you divide the trusses into parts - parta = main remaining assembly after section removal, part b = the vert roof (in this example), and part c = "flat roof" (in this example). and flip the truss (if possible) so only part of it needs to be componentized.
          then you would have the trusses partly available for roof sections which would not have openings. the rest of the opening geometry would have to be manually assembled as part of adding the doghouse, access door etc.
          Glenn
          http://www.runnel.com
          • medeekM Offline
            medeek
            Version 3.2.7 - 06.26.2023
            • Fixed a bug with the truss removal feature.
            • Enabled a feature to selectively remove specific trusses from common and monopitch truss assemblies.
            http://design.medeek.com/resources/trussplugin/images3/truss_su789_800.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.2.7b - 06.28.2023
              • Fixed a minor bug with the truss removal feature for all truss types.
              *Note: This is a critical bug fix for common, monopitch, attic and gambrel attic trusses.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.2.8 - 07.05.2023
                • Enabled a ridge centering option for asymmetric gable rafter roofs.
                • Enabled a ridge centering option for asymmetric hip rafter roofs.
                http://design.medeek.com/resources/trussplugin/images3/ridge_center.gif
                http://design.medeek.com/resources/trussplugin/images3/truss_su794_800.jpg
                I think the non-centered ridge is the more correct of the two, but if you do want the centered ridge then it is also an option.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Tutorial 22: Asymmetric Roof Framing (8:17 min.)
                  Centered vs. Non-centered ridges for asymmetric rafter roofs.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Tutorial 23: Licensing and Upgrades (11:59 min.)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 24: Complex Roof Discussion and Limitations (10:43 min.)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.2.9 - 08.28.2023
                        Fixed a critical bug with the truss removal feature for truss sets.
                        !!!! CRITICAL BUG FIX !!!!
                        I highly recommend upgrading from versions 3.2.7 and 3.2.8.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.2.9b - 08.28.2023 thru 08.29.2023
                          • Fixed a critical bug with the hip rafter roof module.
                          Unfortunately I never noticed this error/bug because I usually test the plugin with the advanced options turned on automatically. If the advanced options are turned off and a hip roof is attempted and error will be thrown. This bug fix addresses that issue. I highly recommend upgrading to this latest version.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.2.9c - 08.30.2023
                            • Fixed the non-orthogonal rafter framing bug for complex roofs.
                            http://design.medeek.com/resources/trussplugin/images3/truss_su795_800.jpg
                            I think I have finally resolved the confounded non-orthogonal rafter framing issue (it has been almost two years). It turns out the fix was simply replacing a complex piece of logic with two lines of code, sometimes simple is better.
                            I highly recommend updating to this latest release. I apologize that it has taken this long to rectify the issue, I was made aware of it about 18 months ago but it has taken me a while to circle back and determine the cause and then the solution. Thank-you everyone for your patience.
                            P.S.
                            After testing non-orthogonal roofs this afternoon I realized that it would be handy to have the ability to custom offset the rafter spacing for each roof plane. Sometimes the algorithm is not smart enough to correctly position the rafter exactly where one might want them. I will give this some additional consideration.
                            design.medeek.com
                            • gullfoG Offline
                              gullfo
                              or you'd run a "nailer" rafter between them for the rafters to attach too as expecting them to line up o.c. with differing roofs is low. if you were manually building it, you'd want a common nailer along that line to attach to while keep o.c. spacing. more complex roofs - each roof section is its own assembly if the single common nailer doesn't work.
                              Glenn
                              • medeekM Offline
                                medeek
                                Version 3.3.0 - 08.31.2023
                                • Added a rafter offset parameter for complex roof framing.
                                • Fixed a minor bug with complex roof framing for half hip roofs set to custom pitches.
                                http://design.medeek.com/resources/trussplugin/images3/truss_su796_800.jpg
                                The rafter offset parameter will now allow the user to offset the rafter framing any custom amount (positive or negative) for each roof plane independently.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  First look at a complex roof with the hips, flying hips and valleys drawn. The framing module still has quite a ways to go but at least this is a start on these elements:
                                  https://global.discourse-cdn.com/sketchup/original/3X/f/3/f3cbc0d8ad266ba2322be0b5a3950a074a814a45.jpeg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.3.1 - 09.03.2023
                                    • Added a hip, valley and flying hip rafters to the complex roof framing module.
                                    http://design.medeek.com/resources/trussplugin/images3/truss_su802_800.jpg
                                    The first thing you will notice is that the upper ends of the hip and valley rafters are not correctly trimmed, only the bottom ends. Also flying hips are not trimmed on their upper or lower ends. The trimming algorithm for these rafters is the next thing on my todo list.
                                    Unlike the lower end trimming, the upper end will require a much more sophisticated algorithm so it may take some time. The problem really is that there a number of possibilities for termination and the plugin needs to be be able to check for all of those possibilities. No one said complex roof are easy.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 3.3.1b - 09.04.2023
                                      • Refined the framing algorithm for hip, valley and flying hip rafters.
                                      http://design.medeek.com/resources/trussplugin/images3/truss_su804_800.jpg
                                      All of the major framing members are now being drawn however the trimming of certain rafters is still not quite correct, further refinement and correction will be necessary.
                                      I've also noticed that with certain large roof planes an occasional stray edge is generated (or left behind when the roof primitive is created), I will need to look into this further and rectify the issue. It does not appear to be a critical error but it does effectively split the roof plane into to separate faces which then makes the plugin treat the roof plane as two separate faces.
                                      With the flying hips terminating adjacent to valley rafters I'm not entirely sure how that is typically framed.
                                      Please download and test this latest release and then email me comments or suggestions directly.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 3.3.1c - 09.05.2023
                                        • Minor bug fix within the rafter framing module for complex roofs.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 3.3.1d - 09.09.2023
                                          • Fixed a bug within the global settings for complex roofs.
                                          • Updated the straight skeleton algorithm to better remove redundant edges within roof planes/faces.
                                          • Improved the robustness of the complex roof module (framing and cladding) for specific cases.
                                          http://design.medeek.com/resources/trussplugin/images3/truss_su806_800.jpg
                                          The complex roof module is now a bit more robust than it was and should be able to handle more cases than it did previously.
                                          However there still does exist the special cases where the fascia line is not all on one level that is still not possible to draw. The discussion on that topic is presented in this video:
                                          Hip and Ridge is still pending. Previously I was unable to fully work out the algorithm in order to deal specifically with flying hips. I will need to give this another hard look and see if my topological problem solving skills have improved since 2021.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 3.3.2 - 09.17.2023
                                            • Added statistics for complex roofs (Medeek Estimator integration).
                                            http://design.medeek.com/resources/trussplugin/images4/truss_su809_800.jpg
                                            design.medeek.com
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 72 / 76
