    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • pbacotP
      That's awesome. The accuracy is something anyone can appreciate if you are doing house models for real full house construction projects.
      Personally framing has only been a small special part of my modeling, but if that's where you want to go with it, this is really impressive in terms of building knowledge and ruby coding.
      • medeekM
        medeek
        I've got this far and the code is still less than 1 Mb, there is a lot more that is possible. Take a look at the typical output from Mitek's Sapphire program. This is the level it needs to get to in order for it to be useful.
        Valley sets
        Hip sets
        Transition trusses
        Girder trusses
        Gable end trusses
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • jujuJ
          juju
          this plugin is evolving to the extent where a short user manual will be useful
          • medeekM
            medeek
            Agreed, at the very least a document explaining the use and implications of each option and some simple diagrams and screenshots as needed. Also a glossary of terms.
            design.medeek.com
            • medeekM
              medeek
              I need to be able to select a face from a truss (truss top chord) even when the entire truss set is nested within a group -> component -> group. I'm going to assume this is possible, even though I don't know how to do this yet. If I can do this I can see a path to creating the valley set code which will allow one to insert a valley set behind a given truss set and have it frame over the main roof, conforming to the main pitch of the roof. At this point I'm only going to make it work if the two ridge lines are perpendicular. If they are different than 90 degrees the calculations are going to be a nightmare, I'll put that one on hold for a later time when I feel particularly ambitious.
              design.medeek.com
              • medeekM
                medeek
                Version 1.1.0 - 11.10.2015
                Gable end trusses enabled for the Fink truss type and all raised heel variants.
                I may need to adjust the vertical studs slightly for the raised heel with slider. I haven't yet determined the best way to frame that situation out.
                design.medeek.com
                • jujuJ
                  juju
                  @medeek said:
                  Version 1.1.0 - 11.08.2015
                  Added advanced roof options for Common, Scissor and Attic truss types.
                  Sheathing option enabled under advanced roof options.
                  Rake Board option enabled under advanced roof options.
                  Fascia (Flush, Dropped, Beveled) option enabled under advanced roof options.
                  Duplication of version numbers?
                  • medeekM
                    medeek
                    No, the change is pretty minor so I didn't think it needs its own rev.
                    design.medeek.com
                    • medeekM
                      medeek
                      Gable end trusses for Queen Post and Howe truss types.
                      I think it is time to start adding some more truss types.
                      design.medeek.com
                      • medeekM
                        medeek
                        On a slightly different note I'm thinking about creating a plugin for wall framing and other misc. framing related items for residential construction:
                        • Walls
                        • Floors
                        • Stairs
                        • Dormers
                        • Foundations
                        • Posts and Beams
                        • Square and Round Footings
                        Any great ideas on names. Its going to be something like Medeek Framer or Medeek Construction but I just don't want to make it too narrow in scope since I will probably wrap a number of things into it.
                        I like the housebuilder extension but I think a lot more can be done based on this initial concept.
                        Items I would like to see are more flexibility in defining openings, double trimmers, double king studs, double window sill plates.
                        I would also like to have the ability to create portal frames per the IRC standard. As well as classify certain wall segments as shearwalls and automatically insert the holdown components (Simpson HDU series) into the wall.
                        For structural engineers I've got some ideas for a plugin called Medeek Structure which will do lateral load analysis for wind and seismic similar to the Woodworks Shearwall software that I currently use on my local engineering projects.
                        design.medeek.com
                        • medeekM
                          medeek
                          I haven't even looked at traditional roof framing, its been all trusses and some floor joists until now.
                          Hip roof framing is very complicated especially with intersecting roof lines:
                          http://design.medeek.com/images/misc/hiproof1.jpg
                          and
                          http://cdn-7.carpentry-pro-framer.com/images/types-of-roof-rafters.gif
                          design.medeek.com
                          • medeekM
                            medeek
                            Actually let me rephrase that, any roof can get very complicated with intersecting roof lines whether it is framed out with trusses or more traditional rafters and beams.
                            If I incorporate traditional framing I would like for the user to be able to indicate the perimeter of the ext. walls and for the logic to be smart enough to handle any possible configuration. Consider the custom home with guest house below:
                            http://design.medeek.com/images/misc/HIPROOFSTUDY1.jpg
                            Just to determine the proper placement of the ridge and valley lines requires some serious algorithms. The technique I used to do it manually simply involves drawing isolines moving a fixed increment in from the ext. wall line. These are really no different than contour lines on a topographic map. The vertexes created by the intersection of these lines indicate the location of hip rafter, flying hip rafters and valley rafters. When the isolines merge into one line then you have a ridge board.
                            design.medeek.com
                            • medeekM
                              medeek
                              An interesting implementation of a straight line skeleton algorithm is at this link:
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.1.1 - 11.14.2015
                                • Gable end trusses enabled for all monopitch truss types.
                                • Added energy/raised heels for monopitch trusses (3 variants: wedge, slider and vertical w/ strut).
                                Currently there are only two versions of the monopitch truss available (2/2 and 3/3).
                                The truss set below shows a monopitch truss set with gable ends and a 36" raised heel.
                                http://design.medeek.com/resources/images/truss_su17_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I've also added advanced options for monopitch trusses (sheathing, rake and fascia).
                                  http://design.medeek.com/resources/images/truss_su18_800.jpg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.1.2 - 11.16.2015
                                    Metric input enabled for monopitch truss types.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Has anyone actually tried to manually create hip roof framing in SU. I had some questions about the geometry and the way certain angles come together so I started drawing a typical hip roof (rafters) and I quickly realized its not at all easy. I can probably do this sort of thing easier in AutoCAD or Solidworks but maybe that is because my familiarity with SU is still somewhat limited. The ability to create traditional hip rafter framing is now on my todo list for the plugin.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        An excellent video series on drawing a hip roof in SU:
                                        He pretty much has it down to an art. Now I just need to figure out how to mathematically model it so that all of this can be generated within a few seconds and three mouse clicks.
                                        So far with trusses or any other group/component I am creating everything has been 90 degrees so it is simply a matter of drawing a profile and using the push/pull function. With some of these more complicated geometries it is going to get a lot more interesting.
                                        design.medeek.com
                                        • P
                                          pcmoor
                                          Hi Nathaniel,
                                          I made a few Dynamics of hips, valley creepers (see my warehouse page) may help in working out pitching points and angles, or help to formulate your ideas
                                          https://3dwarehouse.sketchup.com/user.html?id=0838679030929007270242769
                                          philip
                                            Oh, 'THAT' type of TRUSS, sorry I thought you meant something else.......
                                            • 76
                                            • 77
                                            • 6 / 77
